How to change cid on SD card
Hi guys, who can tell me, is it possible to change cid on SD card using arduino. I know how to read CID with arduino.
But im very need to change it on no cid sd card
I was looking for a question to test out chat.openai.com and so I tried your question and got the below answer from it:
"It is possible to change the CID (Card Identification) of an SD card using an Arduino, but it requires some additional hardware and programming knowledge.
The CID is a unique identification number that is stored on the SD card and used by the host device to identify the card. It is stored in a non-rewritable area of the card and cannot be modified by the user.
To change the CID of an SD card, you would need to use a device called an SD card programmer. These devices are designed specifically for programming and modifying SD cards and can be used to change the CID, as well as other information stored on the card.
To use an SD card programmer with an Arduino, you would need to connect the programmer to the Arduino using a serial interface, such as the Arduino's serial port or an external serial-to-USB adapter. You would then need to write a program using the Arduino software development environment (IDE) to communicate with the programmer and issue commands to change the CID.
It is important to note that modifying the CID of an SD card can have unintended consequences and may cause the card to be unrecognized by some devices. It is also generally not recommended to modify the CID of an SD card as it can violate the terms of use for the card and may void the warranty."
Can you explain why you need to change the CID as there may be an alternative solution.
Did you do a google search on the subject?
