Hello
I have a string of format: 20170729112303.000
How can I change this to a string or char-array of format: 2017-07-29T11:23:03.000 ?
Hello
Is it a string or a String ?
Because you know the input and output format, and the offsets are fixed, you can just move the characters around using memcpy/memmove:
while (!Serial);
char str[24] = "20170729112303.000"; // "2017-07-29T11:23:03.000" is 23 characters + terminating NULL
Serial.println(str);
memmove(&str[17], &str[12], 7); // seconds (dest and source overlap, so use memmove instead of memcpy)
str[16] = ':';
memcpy(&str[14], &str[10], 2); // minutes
str[13] = ':';
memcpy(&str[11], &str[8], 2); // hour
str[10] = 'T';
memcpy(&str[8], &str[6], 2); // day
str[7] = '-';
memcpy(&str[5], &str[4], 2); // month
str[4] = '-';
Serial.println("2017-07-29T11:23:03.000");
Serial.print(strcmp(str, "2017-07-29T11:23:03.000") ? "doesn't match" : "matches");
void loop() {}
Pieter
PieterP - Sorry for the late reply but... THANKS! Worked perfectly
