How to change port value of webserver from the EEPROM ?
The following are excerpts form the Web_HolloWorld sample code:
static uint8_t ip[] = { 192, 168, 1, 1 };
‪#‎define‬ PREFIX ""
WebServer webserver(PREFIX, 80);
void helloCmd(WebServer &server, WebServer::ConnectionType type, char *, bool){
My question is :
WebServer webserver (PREFIX, 80)
How to move the "port 80" to the setup () or other section and re-declare?
Because I want to read port value from the EEPROM before WebServer start.
With a bit of luck this might work
WebServer webserver (PREFIX, EEPROM.read (port_address)) ;
(if the EEPROM library functions early in initialization, that is).
Note you need to define an EEPROM address for the port, and you'll need 2 bytes if you
want ports above 255, and you'll have to setup the EEPROM too.
MarkT:
Thank you very much MarkT, it's work !!!
