how to change sim 908 gps location coordinates format ?
I use Sim908 module for record GPS location and Arduino.
Sim908 send the lat and lon in ddmm.mmmm format, but the major service of GPS location online (for example google earth) use the dd.dddd format.
So, How can modify my code to convert multiple coordinate that sim 908 send to dd.dddd format ?
Sim 908 Gsm Library Code
#include "gps.h"
char GPSGSM::getBattInf(char *str_perc, char *str_vol)
     char ret_val=0;
     char *p_char;
     char *p_char1;
     gsm.SimpleWriteln("AT+CBC");
     gsm.WaitResp(5000, 100, "OK");
     if(gsm.IsStringReceived("+CBC"))
          ret_val=1;
     //BCL
     p_char = strchr((char *)(gsm.comm_buf),',');
     p_char1 = p_char+1;  //we are on the first char of BCS
     p_char = strchr((char *)(p_char1), ',');
     if (p_char != NULL) {
          *p_char = 0;
     strcpy(str_perc, (char *)(p_char1));
     //Voltage
     p_char++;
     p_char1 = strchr((char *)(p_char), '\r');
     if (p_char1 != NULL) {
          *p_char1 = 0;
     strcpy(str_vol, (char *)(p_char));
     return ret_val;
char GPSGSM::getBattTVol(char *str_vol)
     char *p_char;
     char *p_char1;
     char ret_val=0;
     gsm.SimpleWriteln("AT+CBTE?");
     if(gsm.IsStringReceived("+CBTE"))
          ret_val=1;
     //BCL
     p_char = strchr((char *)(gsm.comm_buf),':');
     p_char1 = p_char+2;  //we are on the first char of BCS
     p_char = strchr((char *)(p_char1), '\r');
          *p_char = 0;
     strcpy(str_vol, (char *)(p_char1));
     return ret_val;
char GPSGSM::attachGPS()
     if(AT_RESP_ERR_DIF_RESP == gsm.SendATCmdWaitResp("AT+CGPSPWR=1", 500, 100, "OK", 5))
          return 0;
     if(AT_RESP_ERR_DIF_RESP == gsm.SendATCmdWaitResp("AT+CGPSRST=1", 500, 100, "OK", 5))
          return 0;
     return 1;
char GPSGSM::deattachGPS()
     if(AT_RESP_ERR_DIF_RESP == gsm.SendATCmdWaitResp("AT+CGPSPWR=0", 500, 100, "OK", 5))
          return 0;
     return 1;
char GPSGSM::getStat()
     char ret_val=-1;
     gsm.SimpleWriteln("AT+CGPSSTATUS?");
     if(gsm.IsStringReceived("Unknown")||gsm.IsStringReceived("unknown"))
          ret_val=0;
     else if(gsm.IsStringReceived("Not"))
          ret_val=1;
     else if(gsm.IsStringReceived("2D")||gsm.IsStringReceived("2d"))
          ret_val=2;
     else if(gsm.IsStringReceived("3D")||gsm.IsStringReceived("3d"))
          ret_val=3;
     return ret_val;
char GPSGSM::getPar(char *str_long, char *str_lat, char *str_alt, char *str_time, char *str_speed )
     char ret_val=0;
     char *p_char;
     char *p_char1;
     gsm.SimpleWriteln("AT+CGPSINF=0");
     if(gsm.IsStringReceived("OK"))
          ret_val=1;
     //longitude
     p_char1 = p_char+1;  //we are on the first char of longitude
          *p_char = 0;
     strcpy(str_long, (char *)(p_char1));
     // latitude
     p_char++;
     p_char1 = strchr((char *)(p_char), ',');
          *p_char1 = 0;
     strcpy(str_lat, (char *)(p_char));
     // altitude
     p_char1++;
          *p_char = 0;
     strcpy(str_alt, (char *)(p_char1));
     // UTC time
     p_char++;
          *p_char1 = 0;
     strcpy(str_time, (char *)(p_char));
     // TTFF
     p_char1++;
          *p_char = 0;
     // num
     p_char++;
          *p_char1 = 0;
     // speed
     p_char1++;
          *p_char = 0;
     strcpy(str_speed, (char *)(p_char1));
     return ret_val;
void parseTime(char *field, int *time)
     ////////////////Time////////////
     char tmp[4];
     tmp[2]=0; // Init tmp and null terminate
     tmp[0] = field[8];
     tmp[1] = field[9];
     time[0] = atoi(tmp); // Hours
     tmp[0] = field[10];
     tmp[1] = field[11];
     time[1] = atoi(tmp); // Minutes
     tmp[0] = field[12];
     tmp[1] = field[13];
     time[2] = atoi(tmp); // Seconds
     /////////////Date///////////////
     tmp[0] = field[0];
     tmp[1] = field[1];
     tmp[2] = field[2];
     tmp[3] = field[3];
     tmp[4]=0; // Init tmp and null terminate
     time[3] = atoi(tmp); // year
     tmp[0] = field[4];
     tmp[1] = field[5];
     time[4] = atoi(tmp); // month
     tmp[0] = field[6];
     tmp[1] = field[7];
     time[5] = atoi(tmp); // day
// Read the latitude in decimal format from a GGA string
double convertLat(char* latString)
     double latitude = atof(latString);                                    // convert to a double (precise)
     int deg = (int) latitude / 100;                               // extract the number of degrees
     double min = latitude - (100 * deg);                  // work out the number of minutes
     latitude = deg + (double) min/60.0;                   // convert to decimal format
     return latitude;
// Read the longitude in decimal format from a GGA string
double convertLong(char* longString)
     double longitude = atof(longString);                                  // convert to a double
     int deg = (int) longitude / 100;                              // extract the number of degrees
     double min = longitude - (100 * deg);                 // work out the number of minutes
     longitude = deg + (double) min/60.00;                 // convert to decimal format
     return longitude;
Do you know what the dd, mm, mmmm, and dddd bits mean? Using sscanf() to convert the string into dd, mm, and mmmm parts is easy enough. A little addition, multiplication and division will get you the dddd part from the mm and mmmm parts.
DDD° MM.MMM’ Degrees and Decimal Minutes .
DDD.DDDDD° Decimal Degrees
i didnt understand what u mean !?
i have this part from another code but i didn’t know how to modified my GSM Library Code which i wrote on the top.
/* convert2Degrees ( input ) - performs the conversion from input
 * parameters in  DD°MM.mmm’ notation to DD.dddddd° notation.
 * Sign '+' is set for positive latitudes/longitudes (North, East)
 * Sign '-' is set for negative latitudes/longitudes (South, West)
int8_t convert2Degrees(char* input){
    float deg;
    float minutes;
    boolean neg = false;
    //auxiliar variable
    char aux[10];
    if (input[0] == '-')
        neg = true;
        strcpy(aux, strtok(input+1, "."));
        strcpy(aux, strtok(input, "."));
    // convert string to integer and add it to final float variable
    deg = atof(aux);
    strcpy(aux, strtok(NULL, '\0'));
    minutes=atof(aux);
    minutes/=1000000;
    if (deg < 100)
        minutes += deg;
        deg = 0;
        minutes += int(deg) % 100;
        deg = int(deg) / 100;
    // add minutes to degrees
    deg=deg+minutes/60;
    if (neg == true)
        deg*=-1.0;
    neg = false;
    if( deg < 0 ){
        neg = true;
        deg*=-1;
    float numeroFloat=deg;
    int parteEntera[10];
    int cifra;
    long numero=(long)numeroFloat;
    int size=0;
    while(1){
        size=size+1;
        cifra=numero%10;
        numero=numero/10;
        parteEntera[size-1]=cifra;
        if (numero==0){
    int indice=0;
    if( neg ){
        indice++;
        input[0]='-';
    for (int i=size-1; i >= 0; i--)
        input[indice]=parteEntera[i]+'0';
        indice++;
    input[indice]='.';
    indice++;
    numeroFloat=(numeroFloat-(int)numeroFloat);
    for (int i=1; i<=6 ; i++)
        numeroFloat=numeroFloat*10;
        cifra= (long)numeroFloat;
        numeroFloat=numeroFloat-cifra;
        input[indice]=char(cifra)+48;
        indice++;
    input[indice]='\0';
That function is defined to return a value, but has no return statement(s).
I don’t understand this:
    if (neg == true)
        deg*=-1.0;
    neg = false;
    if( deg < 0 ){
        neg = true;
        deg*=-1;
It seems like you can’t make up your mind whether the value is supposed to be positive or negative.
What you are doing after that is not at all clear. dtostrf() will convert the float to a string in much less code, and do it properly.
Thank you , iam beginner in this . so i didn't understand that . i just want the code to do that .
regards
Finally i found a solution . every think is okay now .
My Final Code.
// Arduino code is available to download - link below the video.
#include "SIM900.h"
#include <SoftwareSerial.h>
#include <Wire.h>
#include <ADXL345.h>
Flame sensor      Arduino
VCC                 5V
GND                 GND
D0                  D2 (Digital pin 2)
tx   2
rx   3
#include "gps.h"
#include "sms.h"
ADXL345 adxl; //variable adxl is an instance of the ADXL345 library
char aux_str[30];
char aux;
char latitude[15];
char longitude[15];
int x,y,z;
int rawX, rawY, rawZ;
float X, Y, Z;
float rollrad, pitchrad;
float rolldeg, pitchdeg;
SMSGSM sms;
int D2 = 5; // digital pin 2
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20]="0599122910";
GPSGSM gps;
char lon[15];
char lat[15];
char alt[15];
char time[20];
char vel[15];
char msg1[5];
char msg2[5];
char text[20];
char stat;
char inSerial[20];
int i=0;
   adxl.powerOn();
  pinMode(D2,INPUT);
        //Serial connection.
     Serial.println("GSM Shield testing.");
     //Start configuration of shield with baudrate.
     //For http uses is raccomanded to use 4800 or slower.
     if (gsm.begin(2400)) {
          Serial.println("\nstatus=READY");
          started=true;
            gsm.forceON();
     } else Serial.println("\nstatus=IDLE");
  int sensorReading = digitalRead(D2); // read the sensor on digital D2
  Serial.print(sensorReading);
    adxl.readAccel(&x, &y, &z); //read the accelerometer values and store them in variables  x,y,z
  // Output (x,y,z) on horizontal plane should be approximately (0,0,255)
  // the following 3 lines is for an offset
  rawX=x-7;
  rawY=y-6;
  rawZ=z+10;
  X = rawX/256.00; // used for angle calculations
  Y = rawY/256.00; // used for angle calculations
  Z = rawZ/256.00; // used for angle calculations
  rollrad = atan(Y/sqrt(X*X+Z*Z));  // calculated angle in radians
  pitchrad = atan(X/sqrt(Y*Y+Z*Z)); // calculated angle in radians
  rolldeg = 180*(atan(Y/sqrt(X*X+Z*Z)))/PI; // calculated angle in degrees
  pitchdeg = 180*(atan(X/sqrt(Y*Y+Z*Z)))/PI; // calculated angle in degrees
  if (sensorReading==1  ) {       // No Flames Detected
    Serial.println(" - No Flames Near Sensor");
      Serial.print("\t Angle according to x axis (Roll(deg)) = "); Serial.print(rolldeg);      // calculated angle in degrees
  Serial.print("\t Angle according to y axis (Pitch(deg)) = "); Serial.println(pitchdeg);  // calculated angle in degrees
  else {                       // Flames detected
    Serial.println(" - Flame Detected!");
        if(started) {
             //GPS attach
          if (gps.attachGPS())
               Serial.println("status=GPSREADY");
          else Serial.println("status=ERROR");
          delay(20000);	//Time for fixing
          stat=gps.getStat();
          if(stat==1)
               Serial.println("NOT FIXED");
          else if(stat==0)
               Serial.println("GPS OFF");
          else if(stat==2)
               Serial.println("2D FIXED");
          else if(stat==3)
               Serial.println("3D FIXED");
          delay(5000);
          //Get data from GPS
          gps.getPar(lon,lat,alt,time,vel);
convert2Degrees(lat);
 convert2Degrees(lon);
  Serial.print(lat); Serial.print(",");Serial.print(lon);
          smsbuffer[0]='\0';
   strcat(smsbuffer," It was found in the fire site: ");
   strcat(smsbuffer,text);
  strcat(smsbuffer," latitude: ");
   strcat(smsbuffer,lat);
   strcat(smsbuffer,"longitude:  ");
   strcat(smsbuffer,lon);
     strcat(smsbuffer,"time:");
    strcat(smsbuffer,time);
  sms.SendSMS("0599122910", smsbuffer);
          if ( rolldeg >80&&pitchdeg >6 ){
          smsbuffer[0]='\0';
           //and write them on NewSoftSerial.
     serialhwread();
     //Read for new byte on NewSoftSerial.
     serialswread();
     if(started) {
          //Read if there are messages on SIM card and print them.
          if(gsm.readSMS(smsbuffer, 160, n, 20)) {
               Serial.println(n);
               Serial.println(smsbuffer);
void serialhwread()
     i=0;
     if (Serial.available() > 0) {
          while (Serial.available() > 0) {
               inSerial[i]=(Serial.read());
               delay(10);
               i++;
          inSerial[i]='\0';
          if(!strcmp(inSerial,"/END")) {
               Serial.println("_");
               inSerial[0]=0x1a;
               inSerial[1]='\0';
               gsm.SimpleWriteln(inSerial);
          //Send a saved AT command using serial port.
          if(!strcmp(inSerial,"TEST")) {
//      Serial.println("BATTERY TEST 1");
//      gps.getBattInf(msg1,msg2);
//      Serial.println(msg1);
//      Serial.println(msg2);
//      Serial.println("BATTERY TEST 2");
//      gps.getBattTVol(msg1);
               stat=gps.getStat();
               if(stat==1)
               else if(stat==0)
               else if(stat==2)
               else if(stat==3)
          //Read last message saved.
          if(!strcmp(inSerial,"MSG")) {
               Serial.println(inSerial);
          inSerial[0]='\0';
void serialswread()
     gsm.SimpleRead();
    float deg;
    float minutes;
    //auxiliar variable
    char aux[10];
        neg = true;
    deg = atof(aux);
    minutes=atof(aux);
    minutes/=1000000;
    if (deg < 100)
        minutes += deg;
        deg = 0;
    deg=deg+minutes/60;
    if (neg == true)
        deg*=-1.0;
    neg = false;
    if( deg < 0 ){
        neg = true;
        deg*=-1;
    int cifra;
    int size=0;
    while(1){
        size=size+1;
        cifra=numero%10;
        numero=numero/10;
        if (numero==0){
    int indice=0;
    if( neg ){
        indice++;
        input[0]='-';
        indice++;
    input[indice]='.';
    indice++;
        indice++;
        input[indice]='\0';
