How to change the default pin assignment in a library.
I'm working with the arduino nano v3.0 and I have done a PCB.
I did a mistake and I will like to know how to change pin assignment in a library so that my analog 0 become 3
1 become 4
2 become 5
3 become 6 and
4 become 7
I'm working with the glcd ks0108
Thank you
Math
Use an array.
Can you explain more plz?? Thk
const byte analogLUT [] = {3, 4, 5, 6  }; or whatever.
Or you could edit the source of the library.
You can't use A6 or A7 in place of A3 or A4 because (unlike A0-A5) they don't have a matching digital I/O pin. They are for analog input only.
Time to cut traces and run wires to correct your circuit board.
Damn! That bad I gonna need to reprint my pcb. :~
It depends what you're trying to do with them, doesn't it?
AWOL:
The GLCD library documentation calls for them to be used for D_I (Data In?) and EN (Enable?) signals, pretty clearly digital signals.
After you download the library you can find the wiring diagram at:
Arduino/libraries/glcd/doc/html/page_ks0108_family.html
