How to change the time each sampling time?
I used edge impulse to train the voice recognition model. I find the sampling time is quite fast and in 1 minute the number of samples taken is quite a lot. I want to change two house parameters, how do I do that?
// If your target is limited in memory remove this macro to save 10K RAM
#define EIDSP_QUANTIZE_FILTERBANK   0
#define EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW 4
/* Includes ---------------------------------------------------------------- */
#include <PDM.h>
#include <khoaluan1_inferencing.h>
#include <HardwareSerial.h>
/** Audio buffers, pointers and selectors */
typedef struct {
    signed short *buffers[2];
    unsigned char buf_select;
    unsigned char buf_ready;
    unsigned int buf_count;
    unsigned int n_samples;
} inference_t;
static inference_t inference;
static bool record_ready = false;
static signed short *sampleBuffer;
static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
static int print_results = -(EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW);
 * @brief      Arduino setup function
    Serial1.begin(9600);
    // comment out the below line to cancel the wait for USB connection (needed for native USB)
    while (!Serial);
    Serial.println("Edge Impulse Inferencing Demo");
    pinMode(LED_GREEN, OUTPUT);
    // summary of inferencing settings (from model_metadata.h)
    ei_printf("Inferencing settings:\n");
    ei_printf("\tInterval: %.2f ms.\n", (float)EI_CLASSIFIER_INTERVAL_MS);
    ei_printf("\tFrame size: %d\n", EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE);
    ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
    ei_printf("\tNo. of classes: %d\n", sizeof(ei_classifier_inferencing_categories) /
                                            sizeof(ei_classifier_inferencing_categories[0]));
    run_classifier_init();
    if (microphone_inference_start(EI_CLASSIFIER_SLICE_SIZE) == false) {
        ei_printf("ERR: Could not allocate audio buffer (size %d), this could be due to the window length of your model\r\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT);
        return;
 * @brief      Arduino main function. Runs the inferencing loop.
    bool m = microphone_inference_record();
    if (!m) {
        ei_printf("ERR: Failed to record audio...\n");
        return;
    signal_t signal;
    signal.total_length = EI_CLASSIFIER_SLICE_SIZE;
    signal.get_data = &microphone_audio_signal_get_data;
    ei_impulse_result_t result = {0};
    EI_IMPULSE_ERROR r = run_classifier_continuous(&signal, &result, debug_nn);
    if (r != EI_IMPULSE_OK) {
        ei_printf("ERR: Failed to run classifier (%d)\n", r);
        return;
    if (++print_results >= (EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)) {
        // print the predictions
        ei_printf("Predictions ");
        ei_printf("(DSP: %d ms., Classification: %d ms., Anomaly: %d ms.)",
            result.timing.dsp, result.timing.classification, result.timing.anomaly);
        ei_printf(": \n");
        int pred_index = 4;     // added, Initialize pred_index
        float pred_value = 0.8;   // added, Initialize pred_value
        for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
            ei_printf("    %s: %.5f\n", result.classification[ix].label,
                      result.classification[ix].value);
          if(result.classification[ix].value > pred_value)
              pred_index = ix;
              pred_value = result.classification[ix].value;
              sendData(pred_index);
            // ei_printf(": \n");
            // ei_printf("%d",pred_index);
#if EI_CLASSIFIER_HAS_ANOMALY == 1
        ei_printf("    anomaly score: %.3f\n", result.anomaly);
#endif
        print_results = 0;
 * @brief      PDM buffer full callback
 *             Get data and call audio thread callback
static void pdm_data_ready_inference_callback(void)
    int bytesAvailable = PDM.available();
    // read into the sample buffer
    int bytesRead = PDM.read((char *)&sampleBuffer[0], bytesAvailable);
    if (record_ready == true) {
        for (int i = 0; i<bytesRead>> 1; i++) {
            inference.buffers[inference.buf_select][inference.buf_count++] = sampleBuffer[i];
            if (inference.buf_count >= inference.n_samples) {
                inference.buf_select ^= 1;
                inference.buf_count = 0;
                inference.buf_ready = 1;
 * @brief      Init inferencing struct and setup/start PDM
 * @param[in]  n_samples  The n samples
 * @return     { description_of_the_return_value }
static bool microphone_inference_start(uint32_t n_samples)
    inference.buffers[0] = (signed short *)malloc(n_samples * sizeof(signed short));
    if (inference.buffers[0] == NULL) {
        return false;
    inference.buffers[1] = (signed short *)malloc(n_samples * sizeof(signed short));
    if (inference.buffers[1] == NULL) {
        free(inference.buffers[0]);
        return false;
    sampleBuffer = (signed short *)malloc((n_samples >> 1) * sizeof(signed short));
    if (sampleBuffer == NULL) {
        free(inference.buffers[1]);
        return false;
    inference.buf_select = 0;
    inference.n_samples = n_samples;
    inference.buf_ready = 0;
    // configure the data receive callback
    PDM.onReceive(&pdm_data_ready_inference_callback);
    PDM.setBufferSize((n_samples >> 1) * sizeof(int16_t));
    // initialize PDM with:
    // - one channel (mono mode)
    // - a 16 kHz sample rate
    if (!PDM.begin(1, EI_CLASSIFIER_FREQUENCY)) {
        ei_printf("Failed to start PDM!");
    // set the gain, defaults to 20
    PDM.setGain(127);
    record_ready = true;
    return true;
 * @brief      Wait on new data
 * @return     True when finished
static bool microphone_inference_record(void)
    bool ret = true;
    if (inference.buf_ready == 1) {
        ei_printf(
            "Error sample buffer overrun. Decrease the number of slices per model window "
            "(EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)\n");
        ret = false;
    while (inference.buf_ready == 0) {
        delay(1);
    return ret;
 * Get raw audio signal data
static int microphone_audio_signal_get_data(size_t offset, size_t length, float *out_ptr)
    numpy::int16_to_float(&inference.buffers[inference.buf_select ^ 1][offset], out_ptr, length);
    return 0;
 * @brief      Stop PDM and release buffers
static void microphone_inference_end(void)
    PDM.end();
    free(sampleBuffer);
void sendData(int pred_index){
    switch (pred_index){
    case 0: // "denchum"
      Serial1.println("0");
    case 1: // "dieuhoa"
      Serial1.println("1");
    case 2: // quattran
      Serial1.println("2");
    case 3: //tivi
      Serial1.println("3");
    case 4:
      Serial1.println("4");
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
Is this sound "envelope" parameters?
