How to charge the battery of neo6 gps module
I have a GPS Neo6 module. I think the battery is down, and I don't know how to charge it.
Not all Neo6 modules are necessarily the same, but the one that I have claims:
  • The battery is recharged through a simple diode and resistor charger circuit from the onboard voltage regulator's 3.3V output.
All you need to do is keep the module powered continuously for say a few days, and it will recharge itself.
Can I recharge the module with Arduino's 3,3 volt output?
I would say no, because the on board regulator needs a minimum of 3.7V to give out 3.3V.
  • Input Supply Voltage Range: 3.7V-6V, onboard voltage regulator maintains 3.3V
Mine is powered by the Arduino 5V pin.
is the gps module can function without a battery ?
and how much time it takes to be charged ??
Yes
also it takes a lot of time (30-45minut) to connect to the signal , even i connected correctly and put it on the outdoor
I bought it a month ago. Can the battery be drained so quickly?
I have one of these from Adafruit and it just uses a common CR1220 coin cell. The battery that is in it has been running for over a year. Make sure your battery is rechargeable before trying to recharge it.
I also have one of these GPS modules and the tiny battery has never been an issue. As mentioned I am pretty sure when powered up the battery charges and should last for years of use.
Ron
If it takes that long to get a fix then either the GPS or its antenna are faulty.
A GPS with a good working antenna should get a fix, outdoors and with a good view of the sky in about 45 seconds. This is the case with or without a battery.
