How to check and compare the MAC address (of an ESP32)
Dear all
I have tailored my sketch for three different ESP32. I would like to perform certain code only if the mac address corresponds with the respective hardware. How to do that?
Thanks a lot.
error: invalid operands of types ‘’ and ‘int’ to binary ‘operator==’
error: expected ‘)’ before ‘:’ token
  WiFi.mode(WIFI_MODE_STA);
  Serial.println(WiFi.macAddress());
  if (WiFi.macAddress == 24:XX:YY:ZZ:66:55)
  Serial.println("Hello, I am ESP32 No1");
WiFi.macAddress is a string.
You left out the '()' after the function name so you were trying to compare to the function address. The function returns a String which you can compare with a string literal.
Change:
to
if (WiFi.macAddress() == "24:XX:YY:ZZ:66:55")
johnwasser:
Depends if OP plans to provide actual numbers for XX, YY, and ZZ. If he / she is thinking those form a match-anything wildcard, then it ain't going to work.
Thank you all very much for your help and explanations. It works now with the query corrected by johnwasser.
