How to check for a particular condition for a specific amount of time?
I have a situation in which I have one ir sensor, if it detects it has to perform certain action and again if it detects it has to do other set of action, I am not sure how to perform the second task, Posting the code which I have tried.
pinMode(2, INPUT);// IR SENSOR
pinMode(3, OUTPUT);
pinMode((4, OUTPUT);
int a = digitalRead(2); // STORING IR SENSOR VALUE IN VARIABLE
if( a == 1) // CHECKING IF IT IS HIGH
digitalWrite(3, HIGH);// SOME ACTION
int  b = digitalRead(2); //storing the current value of ir sensor in another variable
if (b ==1)  //  if b is high, and now I want this part to keeping checking until the b is "1", how to //program it,
digitalWrite(3, LOW);
digitalWrite(4, HIGH);
delay(5000);
digitalWrite(4, LOW);
If "it".. What is it?
"it" has to... What is this it?
Wishy-washy statements like "perform some action" don't cut it. Something has to do something explicit. What, exactly, needs to be done? By what? When?
After what interval? I really don't understand this part, or what has to do what.
Which doesn't even compile.
What are the odds that reading the same sensor a few nanoseconds apart is going to result in different values?
If b is one, keep checking until b is one. I really think that you need to understand, or state, your requirements better.
Perhaps explain them in terms of real-world events.
Using single ir sensor I would have to perform two actions at two different timings, To be more clear,
At first,
  1. check ir sensor, if it is high
  2. switch motor1 ON
  3. delay(5000);
  4. switch motor1 OFF
    5.again check for same ir sensor, if it is high
  5. switch motor2 ON.
    7.delay(5000);
  6. switch motor2 OFF.
// coming back to 5th point, checking ir sensor, if the condition is low, it has to keep checking the state until the sensor turns high. I am not sure how to code it. and I have modified code a little bit
pinMode(3, OUTPUT);
delay(5000);
if (b ==1)
delay(5000);
Do you mean something like:
  1. check ir sensor until it is HIGH
In other words:
  1. Repeatedly check ir sensor for as long as it is LOW.
 while (digitalRead(2) == LOW) { /* do nothing */ }
Yeah you are right, Thanks for that, sorry if I have confused you in any way..
