Hello,
I´m a newbie in arduino and did just a few projects, but now I had an idea and whant to know if it is feasable.
I work in the industry and need to know how much time a machine is working during the day.
My idea is to use a current monitoring with non-invasive sensor to check when the machine is working.
Then I need to send this data to a computer by wi-fi.
In the computer I will analyse how long the machine worked and compare it whit the time that it could had worked.
Is it feasable?
Is there a easy whay to do it?
Regards
Rafael
rafaelmw:
Is it feasible?
Depends on what machine it is, and depends on what you mean by 'working'. When a machine is powered 'on', you could consider it to be working as well. So it all depends on ----- what's your definition of working? As in .... doing some computations? Moving? A motor turning on? etc.
Southpark:
It´s a welding machine and my idea is to put a sensor in the wire feeder.
A light sensor glued onto the machine's power light is the easiest and safest way.
There are lots of examples of Arduinos with light sensors.
MorganS:
A light sensor glued onto the machine’s power light is the easiest and safest way.
Nice,
I didn´t thought it and its a sensor that I already have.
Realy appreciate your idea, i will look for more information
Thank you
I did it with a nodemcu and a light sensor.
I update the value of sensor to google sheets, but the nodemcu crashes after some time and i need to reset it.
I´m thinking in other possibilities, may be I could store the values into the nodemcu (with a sdcard ou not, I don´t know the storage size) and in the end of the day send this values to the google sheets.
Will it be the best way?
