How to check if nano board is in use?
I'm trying to add a check in the code to make sure that the proper board has been selected.
This code work fine for Mega 2560:
#if !defined(__AVR_ATmega2560__)
#error Must use ATMEGA 2560
#endif
I tried this for the nano board:
#if !defined(__AVR_ATmega328P__) || !defined(__AVR_ATmega328__)
#error Must use a Nano
#endif
but when checking the code the error message "Must use a nano" is trigged even if the board "Arduino Nano" is selected.
Suggestions?
328P is an uno
Dont know the Definition of nano though. Try out without p since the CPU is only 328
Where did you find the board constant names AVR_ATmega328P and AVR_ATmega328 ?
aarg:
By searching the .h files. But it does not seem to be the correct name.
ARDUINO_AVR_UNO works for uno. but i can't find a list of others
i see it used as a compiler -D option.
thehardwareman:
...and which .h file is it in?
Arduino\hardware\tools\avr\avr\include\avr\io.h
Turn on verbose mode
Build ANY sketch targeted to NANO
Look at the options passed to the compiler, find the -D option containing "BOARD" and "NANO"
Many boards use 328P not only Nano. You need the BOARD define, NOT the CPU define.
Regards,
Ray L.
RayLivingston:
Regards,
Ray L.
Did not thought about that - thanks.
Found
.... -DARDUINO=10812 -DARDUINO_AVR_NANO ...
#endif
The if statement would only be false when both AVR_ATmega328P and AVR_ATmega328 were defined.
