How to check if this is a repairable issue vs fried Nano
Beginner hobbyist here. One of my Nanos got fried (literally- I spotted the smoke and killed the power but unfortunately late). I'm assuming it was due to some shorting of the power supply since I was a little careless with the connector.
But now this has happened with two other Nanos. I highly doubt it was due to the above electrical issue. This is the error message I get. My question is, is there a way to determine whether this is a fixable issue vs this is a destroyed Nano?
This may or may not be relevant but I have been testing some EEPROM read/writes on the 2 Nanos that stopped working. They were operating fine for the past few days. I don't know if the software EEPROM operations may have contributed to the destruction.
Arduino: 1.8.12 (Mac OS X), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Users/MyUsername/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/MyUsername/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-14610 -b57600 -D -Uflash:w:/var/folders/d5/8dyjzbl51kjg64x4gx_5b8bsmn1qt7/T/arduino_build_493246/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/MyUsername/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/Users/MyUsername/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbserial-14610
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
How is everything connected? Could you post a diagram or picture?
Check your wiring, cables, check for shorts (bad cable?)
is anything back-feeding voltage with the Nano's power off?
