How to check the time a user is allowed to click - memory game
Hi everyone, I came to this forum because I have a question about my project. I have to make a memory game for school and this has worked out quite well. But now also want to add time. The maximum time a user has to push a sequence. When this time has elapsed --> GAME OVER. I've already tried to work with the mills function myself. But now I've noticed that my function Get_sequence actually stops my Mills function. I think this is because of my Get_Sequence function and the while in it. Now, I've tried to get that mils function in the Get_sequence function. And i put them in other places, but right now I'm a bit stuck. If anyone knows a solution to this problem, I'd love to hear it! Thank you so much Barballon
(Arduino code and C++ is also totally new to me, so if the solution is simple don't attack me please XD :grinning:)
// Define pins
byte pinnen[] = {8, 9, 10, 11};
byte knoppen[] = {4, 5, 6, 7};
// Sound
byte buzzer = 3;
// Pinnen
byte knop_geel = 4;
byte knop_groen = 5;
byte knop_rood = 6;
byte knop_blauw = 7;
// Levels
const int MAX_LEVEL = 100;
int patroon[MAX_LEVEL];
int ingevuld_patroon[MAX_LEVEL];
// Current level level
int level = 1;
int flag = 0;
// Wait variabels
bool wacht = true;
bool instellingen_bool = true;
int snelheid = 2000;
long startWaitMillis;      //some global variables available anywhere in the program
long period = 5000; //the value is a number of milliseconds
int test;
  // PINMODE
  // Buttons --> Input pullup
  for (byte i = 0; i < 4; i++)
    pinMode(knoppen[i], INPUT_PULLUP);
  // Pinnen / Leds --> Output
    pinMode(pinnen[i], OUTPUT);
  // Pinmode buzzer
  pinMode(buzzer, OUTPUT);
  // Initieer Mils()
  // Flash function --> Parameter --> Aantal keer
  flash(1);
  // ALLE PINNNE IN SETUP LOW ZETTEN
  // Alle pinnen op low zetten --> Parameter --> LOW/HIGH/WAARDE
  writeAllPins(LOW);
  // Buzzer low
  digitalWrite(buzzer, LOW);
  // Serial
  Serial.println("GAME READY");
  Serial.println("========================================================== \n Hoe moeilijk wil je de game maken?\n Geef een cijfer in tussen 1 - 3\n 1 --> Makelijk\n 1 --> Medium\n 3 --> Hard\n==========================================================");
  if (instellingen_bool == true)
    instellingen();
  if (wacht == true && instellingen_bool == false)
    //genereer een patroon;
    generate_sequence();
    // Sequence showen aan de gebruiker
    show_sequence();
    startWaitMillis = millis();
    Serial.println("startWaitMillis:" + String(startWaitMillis));
    // wacht op false zetten omdat arduino code heeft uitgevoerd
    wacht = false;
  // Speler doet dingen
  else if (wacht == false)
    // User plays game.
    Serial.println("Tussentijds" + String(millis() - startWaitMillis));
    if (millis() - startWaitMillis > period)
      Serial.println(millis() - startWaitMillis);
      Serial.println("Ok passed");
      wrong_sequence();
      wacht = true;
    get_sequence();
// FUNCTIES
// Instellingen
void instellingen()
  if (Serial.available() > 0)
    String inKomend = Serial.readString();
    // Comando's
    if (inKomend == "1")
      Serial.println("==========================================================\n Gekozen mode --> Makelijk");
      snelheid = 2000;
      Serial.println("LET OP SPEL GAAT BEGINT NA HET FLIKKEREN VAN LEDS! \n==========================================================");
      flash(3);
      instellingen_bool = false;
    else if (inKomend == "2")
      Serial.println("==========================================================\n Gekozen mode --> Medium");
      snelheid = 1334;
      flash(3);
    else if (inKomend == "3")
      Serial.println("==========================================================\n Gekozen mode --> Moeilijk");
      snelheid = 668;
      flash(3);
// Sequence showen
void show_sequence()
  writeAllPins(LOW);
  for (int i = 0; i < level; i++)
    digitalWrite(patroon[i], HIGH);
    delay(snelheid);
    digitalWrite(patroon[i], LOW);
// Sequence controleren
void get_sequence()
    flag = 0;
    while (flag == 0)
      if (digitalRead(4) == LOW)
        digitalWrite(8, HIGH);
        ingevuld_patroon[i] = 8;
        flag = 1;
        delay(200);
        if (ingevuld_patroon[i] != patroon[i])
          wrong_sequence();
          return;
        digitalWrite(8, LOW);
      if (digitalRead(5) == LOW)
        digitalWrite(9, HIGH);
        ingevuld_patroon[i] = 9;
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
        digitalWrite(9, LOW);
      if (digitalRead(6) == LOW)
        digitalWrite(10, HIGH);
        ingevuld_patroon[i] = 10;
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
        digitalWrite(10, LOW);
      if (digitalRead(7) == LOW)
        digitalWrite(11, HIGH);
        ingevuld_patroon[i] = 11;
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
        digitalWrite(11, LOW);
  right_sequence();
  wacht = true;
String juiste_volgorde_to_string()
  String patroon_string = "";
    if (patroon[i] == 8)
      patroon_string = patroon_string + "geel";
    if (patroon[i] == 9)
      patroon_string = patroon_string + "groen";
    if (patroon[i] == 10)
      patroon_string = patroon_string + "rood";
    if (patroon[i] == 11)
      patroon_string = patroon_string + "blauw";
  return patroon_string;
// Sequence genereren
void generate_sequence()
  // Genereer patroon
  randomSeed(millis());
  for (int i = 0; i < MAX_LEVEL; i++)
    patroon[i] = random(8, 12);
// Code voor verkeerde volgorde
void wrong_sequence()
  flash(3);
  level = 1;
  wacht = true;
  Serial.println("========================================================== \n Helaas Je GAME OVER! Om opnieuw te starten geef je een cijfer tussen 1-3 in\nGeef een cijfer in tussen 1 - 3\n 1 --> Makelijk\n 1 --> Medium\n 3 --> Hard\n==========================================================");
// Code voor de juiste volgorde
void right_sequence()
  flash(2);
  if (level < MAX_LEVEL)
    level++;
  snelheid -= 50; // Verminderd wachttijd tussen leds
// Lichten laten flikkeren functie
void flash(byte aantalkeer)
  for (int i = 0; i < aantalkeer; i++)
    writeAllPins(HIGH);
    writeAllPins(LOW);
    writeAllPins(LOW);
void wrong_sequence_sound()
  tone(buzzer, 277);
  noTone(buzzer);
  noTone(buzzer);
// Alle pins op zelvde output/input zetten
void writeAllPins(byte waarde)
    digitalWrite(pinnen[i], waarde);
I have now found the solution to my problem myself. For all those who still have the problem in the future, here I have found the solution in my case. I just tweaked my Get_Sequence function a bit.
void get_sequence()
    flag = 0;
    while (flag == 0)
      Serial.println("Hier loopt hij wel");
      Serial.println("Tussentijds: " + String(millis() - startWaitMillis));
        Serial.println("Ok out of time");
        wrong_sequence();
        return;
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
  right_sequence();
  wacht = true;
