I have set up an interrupt timer, using a prescaler of 8 to give 0.5 microsecond resolution. I have the interrupt set to start at 1000 microseconds and decrease by 10 microseconds per step.
I'm struggling to understand if I have everything correct, as when checking against "micros()" I'm seeing a fluctuation in the time the interrupt runs. I don't know whether it's truly running off, or whether it's just down to error introduced by the "cli(); sei();" blocks stopping the micros timer.
Setup..
1000
996 // should be 990
980
972 // should be 970
960
952 // should be 950
as you can see, it's not giving the round numbers expected. Can anyone shed any light on whether this is correct? I only need to be sure the actual interrupt routine is running on time, I don't need to log the time accurately but right now I'm unsure where I stand.
cli();
TCCR1B = B00000000; // clear timer register from arduino use
TCCR1A = B00000000; // same as above
TCNT1 = 0; // zero the count
OCR1A = 1999; // set top value of count
TIMSK1 |= B00000010; // enable output compare A match interrupt
TCCR1A = B01000000; // set OC1A (PB1) to toggle on match
TCCR1B = B00001010; // set CTC and prescalar
sei();
DDRB |= B00000010; // set PB1 to output
This will toggle PB1 high 500 times and low 500 times, giving you a 500Hz waveform, which can be seen on an oscilliscope.
I see, yes it's zero indexed which I missed. Thanks. To be honest I'm a bit out of my depth, your initial reply went over my head. I appreciate the explanation.
I have used the wowki simulator, it's really good. Surprised it is accessible without an account. The problem is I don't know if the results I am seeing is correct.
Using OCR1A = 1999 (for 1microsecond), in PulseView I get a consistent pulse of 1001.47 uSeconds. I'm not sure if this is being affected by the simulation, the time it takes to set the pin state or something else?
Here's the code I'm using in wowki (on a mega board, with the logic analyser attached to pin 53):
I figured it out, I was being lazy and setting the pin inside the ISR. I changed it to set a flag and then set the pin state in the loop and I'm now getting a 999.936us pulse which is close enough for me
So far my experience with wokwi has led me away from assuming it is at fault…
They even simulate switch bounce in the pushbuttons.
My confidence is approaching the same I have in modern compilers, which to a first approximation are never the problem.
I haven't looked into every corner of wokwi, and probably couldn't, but it seems to be built on a mercilessly accurate simulation engine of some kind.
I haven't looked into how one would select particular IDE versions, tool chains and library versions or other ubtleties like that
There is a responsive community on the discord. I think this thing can only get better.
One thing I would like is a way to control real time - watching things for minute or hours can be a drag, it seems like one could have a speed control on that and move things along a bit when desirable.
Use CTC mode and use OCR1A toggle, as I first instructed. This achieves the same thing, a state toggle on one of the pins, without all the pin lookup and mcu clock cycles... as it's built into the timer hardware, parallel to the mcu. From there, knowing you've got it almost right, you can tune your gate using precision/variable caps or a TXCO etc. to get more precise. You will only ever get as accurate as your crystal oscillator.
Forgive my ignorance, would it be possible to alter the "delay" on each hit with that approach? From what I saw running your code it produces a fixed frequency output. I need to be able to calculate and change the time for the next interrupt on each event.
As an aside, I tried your code on a Mega 2560 using pin 52 which according to the reference is PB1 yet nothing was output. The code worked on the Uno. Where would I look to see what needs altering between the boards?
whenever i've had to set up hardware timers, i usually verify it by counting some number of events and looking at a wall clock with a second hand. for example, there should be some # of events in 5 minutes
I actually have a clock like that! And have done the same. Man does it get old fastslow soon enough.
I also use the counter setting on an instrument I have, either when a longer period of personal observation is untenable or the events are too frequent to count manually.
