Hello!
I have a simple newbie question: How to choose a potentiometer?
I already used one I had, but can I use any, for example a 5O kOhm one?
Will it react differently than a 10 kOhm one?
Thanks!
Hello!
Thanks!
So long as all you're using them for is a voltage dividers as inputs to the A/Ds, then a 50k is as good as a 10k.
The only other thing to watch out for is whether the pot is a log (usually used for volume controls) or linear.
Ok, thank you!
The value of the pot is not critical, as mentioned above. But you should avoid very low values (less than about 1k Ohms) and very high values (more than about 50k Ohms). Stick to using linear pots, not logarithmic ones (i.e. don't use audio volume controls). As for the physical form of the pot, use whatever suits you application! You can get "pre-set" pots, which are turned with a screwdriver, rotary pots that have a knob attached, or slider pots that look like faders on a mixing desk.
Yes, then 50 kOhm should be ok. BTW, I just saw that the rotary one I have is 50k!
I was looking for faders, so if those are linear - what I think - it will be good
Hm, "Audio slide pot" is written, I'm waiting for his answer!
That eBay description tells you everything except whether they are LOG or LIN pots! But if they are intended for audio volume or level controls, they will be LOG, and therefore no good for the Arduino.
50k will certainly work but the datasheet for the arduino chip recommends 20k or less. higher than 20k may slow down the conversion time - if you need to purchase pots, go with 10k or 20k.
Ok, but I live in the south of France and don't see how to get faders at a good price...
Here the 50k one seem to be fast enough, I see no delay?!
were talking microseconds - you won't notice anyting unless you have a very time critical application
Have fun!
Isn't there a French equivalent of a supplier like Farnell?
@mem: It's quite time critical, but 1 millisecond is ok too!
@Anachrocomputer: I got the answer from the eBay seller, and those are log...
Farnell sells in France but:
Or do you have other ideas?
Edit: Mouser's price are very good, but 20? shipping... :o
[u]these[/u] are a little cheaper
and get 10k ones if you have a choice.
Yes thank you, they make shipping discount so it is 11,15? for 5 with shipping... that's perhaps the best solution.
