To avoid voltage drop when operating use a diode across Vin to GND. Its normally reverse biased and dissipates a trivial amount of leakage current, there is no voltage drop.
On reverse polarity the diode is essentially a short circuit to ground, so there MUST be something upstream (fuse, circuit breaker, polyswitch, etc.) to remove power.
