How to choose suitable I2C multiplexer
My project is aimed to use at least four LRA, and I use Adafruit DRV2605 as the drivers
The microcontroller I choose is Arduino DUE as it has two pairs of I2C port. The DRV2605 drivers have the same address, so I consider to use I2C multiplexer. But I know very few about his chip, can someone give me some suggestion? Thank you in advance.
Maybe you can get by, by using the EN-pin?
The EN pin must
be high to write I
2C device registers. However, if the EN pin is low the DRV2605 device can still acknowledge
(ACK) during an I
2C transaction, however, no read or write is possible. To completely reset the device to the
powerup state, set the DEV_RESET bit in register 0x01
// Per.
As Zapro suggested, you don't need an multiplexer for I2C, just one for EN pin. When you want to talk to talk to a specific LRA, you activate its EN line.
Zapro:
// Per.
Thank you very much. This is the circuit diagram I drew as you suggested. Is that correct? And which pins are better to be set as EN pins?
florinc:
Thank you so much, I am trying to use this method for my project.
