First you'll need sealed deep-cycle batteries, not standard vehicle batteries.
Secondly you're going to have to work out the mechanics in order to estimate
torque and speed for motors - factors include gearing ratios, friction losses,
maximum incline required to climb, maximum speed on the flat. Do you have
ideas about drive gearing etc and friction in the treads?
[ you may be into the range of a few horsepower BTW ]
Aha! just learned something, i did not knew there were another kind of batteries now i know i am going to need boat batteries and not motorcycle ones.
Do you have ideas about drive gearing etc and friction in the treads?
Not a clue! I was thinking in budding around the motors since i no experience building hardware, if it does not work for my goal its ok, i will learn from it and move on.
First goal is to make the Arduino move two motors. I got one to move, well i got a servo to move. But it seen simple to move the DC motor. Step motor i believe it is harder and require extra shield (I calling the board that controls the step motor shied correct?)
Is there any benefit in using a step motor to a remote controlled tank?
Can you point where i can buy motors and give me your best guess for a model that will be sufficient to start my project of world domination?
You have to understand mechanics and motor sizing to choose the motor for the task.
I suggest you start with a much smaller build first, the heavy stuff is expensive
and guesswork isn't enough, educated guesswork (back of the envelope calculations
are required). Make cheaper mistakes!
i don't where to start, no even to a smaller version. Can you at least provide a link to any store that sells motors? or should i go for RC modeling stuff?
Cordless drills are another good source of powerful motors. You can get old ones from junk shops when the built in rechargeable battery has failed or is not so good.
