How to clear 3 digit on LCD?
Hello, I’m back with another problem. Using a LCD display I have amps displaying fairly well - except for when the amps roll over 10 amps to display 10.4, then drops back to <10 amps. The 3rd digit “4” doesn’t clear. I have got it to clear by using lcd.clear(); with a 1 millis delay, then printing again.
Maybe the comments will help make clear what I’m trying to say.
// variables for input pin and control LED
#include <LiquidCrystal.h>
int amp_pin = 4;   //pin 27
//This is resistors used on for divider circuit
float R1 = 6695.0;    //  resistance of R1
float R2 = 2974.0;     //  resistance of R2
// variable to store the value
float ampraw = 0;
float amp = 0.0;
float ampV = 0;
LiquidCrystal lcd(7, 6, 5, 4, 3, 2); // (RS, Enable, data lines)this meets the include LiquidCrystal.h above
  pinMode(amp_pin, INPUT);  // declaration of pin modes
  lcd.begin(16,2); // setup to send to LCD with 16 columns and 2 lines.
//this must be inside it's own brackets in "void setup()"
void printTenths(int value)
  lcd.print(value / 10);
  lcd.print(".");
  lcd.print(value % 10);
  for (int i = 0; i < 20; i++)   // read the value on analog input for the number of spanamp, then devide by 20 to average.
    ampraw = ampraw+analogRead(amp_pin);
  ampraw = ampraw / 20;
  ampV = ((ampraw * 4.5) / 1024.0);   //this calculates the actual input voltage on the pin
  amp = ampV; // - 2.482;  //2.482 is the offset - at this point amps = zero
  //this little section causes display to show A=0.0 steady - without this section, it bounces around above and below zero.
  if (amp < .01)
    amp = 0;
  else (amp >= .01);
  amp = (amp/.04);  //40mA output for each amp of current
  lcd.setCursor(0,0);
  lcd.print("A=");
  printTenths(amp);
  lcd.clear(); //when LCD reads more than A=10.4 (3 spaces) then drops back to amps is 9.9 (2 spaces) the 3rd space is not cleared "A=9.94"
  delay(1);  //this statement clears the display for 1 millis, then next group prints it back so the 3rd space is cleared, and only reads A=9.9
  lcd.setCursor(0,0);
  lcd.print("A=");
  printTenths(amp);
This works, but does cause a slight flicker on the display. Is there a more elegant way of doing this?
Thank ya’ll for any help and suggestions. If anything is seen on other sections of code I’d appreciate help there also.
Ken H.
I think this will fix the problem without the lcd.clear():
  int units;
  units = value / 10;
  if (units < 10)
    lcd.print(" ");
  lcd.print(units);
  lcd.print(".");
Regards,
-Mike
Thanks Mike - that works like a champ. I like the way it prints better also, the decimal stays at the same spot with your code makes the results look better.
You folks sure are GREAT!! Thanks,
Ken H>
You're welcome, Ken. I'm especially glad to help out a fellow Alabamian.
-Mike
Just for info, I had a similar problem the other day with an uptime counter.
I am no programmer, but a pal who is told me to avoid division like the plague as it’s resource hungry if you don’t have a maths co-processor. My sketch is quite big so I took his advice.
I wanted leading zero’s added i.e.
01
02
03
10
11
12
if (seconds == 0) {
  lcd.setCursor(18,3);
  lcd.print("00");
  } else if (seconds < 10) {
  lcd.setCursor(18,3); lcd.print("0"); lcd.print(seconds);
  } else if (seconds < 100) {
  lcd.setCursor(18,3); lcd.print(seconds);
I did similar for days, hours & minutes to give:-
Uptime=####:##:##:##
Ian.
Interesting to avoid division as it's resource hungry - my code is all so small the extra load isn't a problem.... maybe someday my programs will get that large:)
Good idea on how to get leading zeros - simple but very effective - thanks.
Ken H>
