How to clear a text before a new text is placed in some spot
Hi
i am using a Mega2560 R3 i have got a sketch that used an lcd but i have got a TFT Display
am trying to get the sketch to show 4 different text outputs but all in the same place on the screen, ihave got the sketch to work with case statments and it works but the text are all mixed on top of each other,
heres the code:
#include <Wire.h>
#include <EEPROM.h>
#include <TFT_HX8357.h> // Hardware-specific library
TFT_HX8357 tft = TFT_HX8357(); // Invoke custom library
#include "z_Free_Fonts.h" // Include the header file attached to this sketch
#define TFT_GREY1 0x8410 // New colour // HERE WE CORRECT THE GRAY COLOR !!!!! 11 0x8410 - GREEN LABEL 0x39E7 - YELLOW LABEL
const int audioSwitchPin = A11; // set up a constant for the Audio Filter switch
int audioSwitchState = 0; // variable to hold the value of the switchPin
int prevaudioSwitchState = 0; // variable to hold previous value of the switchpin
int buttonPushCounter = 0; // counter for the number of button presses //audiobuttonPushCounter
void setup() { // put your setup code here, to run once:
//Wire.begin();
pinMode(audioSwitchPin,INPUT_PULLUP); // set up the switch pin as an input
digitalWrite(audioSwitchPin, HIGH); // turn on pullup resistor
// display.clearDisplay();
//********* Setup Filter Outputs ************
pinMode(A12, OUTPUT); //Initiates off pin
pinMode(A13, OUTPUT); //Initiates 1.5Khz pin
pinMode(A14, OUTPUT); //Initiates 2.0Khz pin
pinMode(A15, OUTPUT); //Initiates 2.5Khz pin
//***************** display setting ************************
tft.init();
tft.setRotation(1); //3// 1 WORKS
tft.fillScreen(0x0000); // erase everything
//default_settings ();
//tft.fillRoundRect(72, 45, 55, 23, 5, TFT_WHITE);tft.setCursor(80, 62, 1);tft.println("ATT");}
//{tft.fillRoundRect(72, 45, 55, 23, 5, TFT_GREY1);tft.setCursor(80, 62, 1);tft.println("ATT");}
//menu (); // go to the service menu
//**************** PERMANENT INFO DISPLAY PROGRAM ****************
tft.fillScreen(TFT_BLACK);
tft.fillRect(225, 108, 48, 23, TFT_WHITE); // стираем старое x y width hight //(355, 117, 90, 23, TFT_BLACK)
tft.setTextColor(TFT_WHITE );
tft.setFreeFont(FF6);
//temp1= 56; // x coordinate
//tft.setTextColor(TFT_WHITE);
//tft.setFreeFont(FF33);//21
//tft.fillRect(+70 , 265, 21, 3, TFT_BLACK); //erase the line for numbers
//tft.fillRect(+150 , 265, 21, 3, TFT_BLACK);
//tft.fillRect(+230 , 265, 21, 3, TFT_BLACK);
//tft.fillRect(+310 , 265, 21, 3, TFT_BLACK);
tft.setCursor(152, 150, 1);// 285, 139, 1 //152, 150, 1
tft.println("MODE");
//tft.setCursor(285, 106, 1); //292, 106, 1
//tft.println("RIT ");
tft.setCursor(152, 125, 1);
tft.println("AUDIO"); // testing
//tft.setFreeFont(FF41); // 21
//tft.setCursor(10, 182, 1);
//tft.println("VCC - V");
tft.setFreeFont(FF26);//6
tft.drawRoundRect(140, 15, 334, 143, 5,TFT_BLUE); //x y width high radius color rectangle A
void loop() { // put your main code here, to run repeatedly:
audioSwitchState = digitalRead(audioSwitchPin); // check the status of the switc
if (audioSwitchState != prevaudioSwitchState) // compare the switchState to its previous state
if (audioSwitchState == LOW) // If the switch is pressed, count the press
buttonPushCounter ++;
buttonPushCounter %= 4;
switch (buttonPushCounter)
case 0: // Off
tft.setCursor(230, 125, 1); // SetCursor(230, 125, 1);
tft.setTextColor(TFT_BLACK); // Set up text color
tft.setFreeFont(FF29); // Set up Font Size
tft.println("OFF"); // print to display ("OFF")
digitalWrite(A12, HIGH);             // Output on
digitalWrite(A13, LOW);              // Output off
digitalWrite(A14, LOW);              // Output off
digitalWrite(A15, LOW);              // Output off
case 1: // 1.5Khz
tft.setCursor(275, 125, 1); // SetCursor(0, 0);
tft.setTextColor(TFT_GREEN); // Set up text color
tft.println("1.5K"); // print to display ("1.5K")
digitalWrite(A12, LOW);              // Output off
digitalWrite(A13, HIGH);             // Output on
case 2: // 2.0Khz
tft.setCursor(325, 125, 1); // SetCursor(0, 0);
tft.setTextColor(TFT_RED); // Set up text color
tft.println("2.0K"); // print to display ("2.0K")
digitalWrite(A14, HIGH);             // Output on
case 3: // 2.5Khz
tft.setCursor(375, 125, 1); // SetCursor(0, 0);
tft.setTextColor(TFT_YELLOW); // Set up text color
tft.println("2.5K"); // print to display ("2.5K")
digitalWrite(A15, HIGH);             // Output on
prevaudioSwitchState = audioSwitchState; // save the current switch state as the last state
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Ideas for you to try
1 - print the text that you want to remove but do it in the background colour
or
2 - print spaces over the text that you want to get rid off but do it in the background colour
Once the previous text has gone, print the new text
Hi like this i think lol :wink:
[code]
#include <Wire.h>
#include <EEPROM.h>
  //Wire.begin();
tft.init();
  case 0:                                // Off
  case 1:                                // 1.5Khz
  case 2:                                // 2.0Khz
  case 3:                                // 2.5Khz
[/code]
there is more....
this is from a seconed tab.
[code]
// Attach this header file to your sketch to use the GFX Free Fonts. You can write
// sketches without it, but it makes referencing them easier.
// This calls up ALL the fonts but they only get loaded if you actually
// use them in your sketch.
// No changes are needed to this header file unless new fonts are added to the
// HX8357 library "Fonts/GFXFF" folder.
// To save a lot of typing long names, each font can easily be referenced in the
// sketch in three ways, either with:
//    1. Font file name with the & in front such as &FreeSansBoldOblique24pt7b
//       an example being:
//       tft.setFreeFont(&FreeSansBoldOblique24pt7b);
//    2. FF# where # is a number determined by looking at the list below
//       tft.setFreeFont(FF32);
//    3. An abbreviation of the file name. Look at the list below to see
//       the abbreviations used, for example:
//       tft.setFreeFont(FSSBO24)
//       Where the letters mean:
//       F = Free font
//       M = Mono
//      SS = Sans Serif (double S to distinguish is form serif fonts)
//       S = Serif
//       B = Bold
//       O = Oblique (letter O not zero)
//       I = Italic
//       # =  point size, either 9, 12, 18 or 24
//  Setting the font to NULL will select the GLCD font:
//      tft.setFreeFont(NULL); // Set font to GLCD
// Use these when printing or drawing text in GLCD and high rendering speed fonts
#define GFXFF 1
#define GLCD  0
#define FONT2 2
#define FONT4 4
#define FONT6 6
#define FONT7 7
#define FONT8 8
#ifdef LOAD_GFXFF // Only include the fonts if LOAD_GFXFF is defined in User_Setup.h
// Use the followinf when calling setFont()
// Reserved for GLCD font  // FF0
// Mono spaced fonts
#include <Fonts/GFXFF/FreeMono9pt7b.h>  // FF1 or FM9
#include <Fonts/GFXFF/FreeMono12pt7b.h> // FF2 or FM12
#include <Fonts/GFXFF/FreeMono18pt7b.h> // FF3 or FM18
#include <Fonts/GFXFF/FreeMono24pt7b.h> // FF4 or FM24
#include <Fonts/GFXFF/FreeMonoOblique9pt7b.h>  // FF5 or FMO9
#include <Fonts/GFXFF/FreeMonoOblique12pt7b.h> // FF6 or FMO12
#include <Fonts/GFXFF/FreeMonoOblique18pt7b.h> // FF7 or FMO18
#include <Fonts/GFXFF/FreeMonoOblique24pt7b.h> // FF8 or FMO24
#include <Fonts/GFXFF/FreeMonoBold9pt7b.h>  // FF9  or FMB9
#include <Fonts/GFXFF/FreeMonoBold12pt7b.h> // FF10 or FMB12
#include <Fonts/GFXFF/FreeMonoBold18pt7b.h> // FF11 or FMB18
#include <Fonts/GFXFF/FreeMonoBold24pt7b.h> // FF12 or FMB24
#include <Fonts/GFXFF/FreeMonoBoldOblique9pt7b.h>  // FF13 or FMBO9
#include <Fonts/GFXFF/FreeMonoBoldOblique12pt7b.h> // FF14 or FMBO12  bold italic
#include <Fonts/GFXFF/FreeMonoBoldOblique18pt7b.h> // FF15 or FMBO18
#include <Fonts/GFXFF/FreeMonoBoldOblique24pt7b.h> // FF16 or FMBO24
// Sans serif fonts
#include <Fonts/GFXFF/FreeSans9pt7b.h>  // FF17 or FSS9         обычный шрифт
#include <Fonts/GFXFF/FreeSans12pt7b.h> // FF18 or FSS12
#include <Fonts/GFXFF/FreeSans18pt7b.h> // FF19 or FSS18
#include <Fonts/GFXFF/FreeSans24pt7b.h> // FF20 or FSS24
#include <Fonts/GFXFF/FreeSansOblique9pt7b.h>  // FF21 or FSSO9    bold жирный шрифт
#include <Fonts/GFXFF/FreeSansOblique12pt7b.h> // FF22 or FSSO12
#include <Fonts/GFXFF/FreeSansOblique18pt7b.h> // FF23 or FSSO18
#include <Fonts/GFXFF/FreeSansOblique24pt7b.h> // FF24 or FSSO24
#include <Fonts/GFXFF/FreeSansBold9pt7b.h>  // FF25 or FSSB9         italic  курсивный шрифт
#include <Fonts/GFXFF/FreeSansBold12pt7b.h> // FF26 or FSSB12
#include <Fonts/GFXFF/FreeSansBold18pt7b.h> // FF27 or FSSB18
#include <Fonts/GFXFF/FreeSansBold24pt7b.h> // FF28 or FSSB24
#include <Fonts/GFXFF/FreeSansBoldOblique9pt7b.h>  // FF29 or FSSBO9  bold italic курсивный и жирный шрифт
#include <Fonts/GFXFF/FreeSansBoldOblique12pt7b.h> // FF30 or FSSBO12
#include <Fonts/GFXFF/FreeSansBoldOblique18pt7b.h> // FF31 or FSSBO18
#include <Fonts/GFXFF/FreeSansBoldOblique24pt7b.h> // FF32 or FSSBO24
// Serif fonts
#include <Fonts/GFXFF/FreeSerif9pt7b.h>  // FF33 or FS9
#include <Fonts/GFXFF/FreeSerif12pt7b.h> // FF34 or FS12
#include <Fonts/GFXFF/FreeSerif18pt7b.h> // FF35 or FS18
#include <Fonts/GFXFF/FreeSerif24pt7b.h> // FF36 or FS24
#include <Fonts/GFXFF/FreeSerifItalic9pt7b.h>  // FF37 or FSI9
#include <Fonts/GFXFF/FreeSerifItalic12pt7b.h> // FF38 or FSI12
#include <Fonts/GFXFF/FreeSerifItalic18pt7b.h> // FF39 or FSI18
#include <Fonts/GFXFF/FreeSerifItalic24pt7b.h> // FF40 or FSI24
#include <Fonts/GFXFF/FreeSerifBold9pt7b.h>  // FF41 or FSB9
#include <Fonts/GFXFF/FreeSerifBold12pt7b.h> // FF42 or FSB12
#include <Fonts/GFXFF/FreeSerifBold18pt7b.h> // FF43 or FSB18
#include <Fonts/GFXFF/FreeSerifBold24pt7b.h> // FF44 or FSB24
#include <Fonts/GFXFF/FreeSerifBoldItalic9pt7b.h>  // FF45 or FSBI9
#include <Fonts/GFXFF/FreeSerifBoldItalic12pt7b.h> // FF46 or FSBI12
#include <Fonts/GFXFF/FreeSerifBoldItalic18pt7b.h> // FF47 or FSBI18
#include <Fonts/GFXFF/FreeSerifBoldItalic24pt7b.h> // FF48 or FSBI24
#define FM9 &FreeMono9pt7b
#define FM12 &FreeMono12pt7b
#define FM18 &FreeMono18pt7b
#define FM24 &FreeMono24pt7b
#define FMB9 &FreeMonoBold9pt7b
#define FMB12 &FreeMonoBold12pt7b
#define FMB18 &FreeMonoBold18pt7b
#define FMB24 &FreeMonoBold24pt7b
#define FMO9 &FreeMonoOblique9pt7b
#define FMO12 &FreeMonoOblique12pt7b
#define FMO18 &FreeMonoOblique18pt7b
#define FMO24 &FreeMonoOblique24pt7b
#define FMBO9 &FreeMonoBoldOblique9pt7b
#define FMBO12 &FreeMonoBoldOblique12pt7b
#define FMBO18 &FreeMonoBoldOblique18pt7b
#define FMBO24 &FreeMonoBoldOblique24pt7b
#define FSS9 &FreeSans9pt7b
#define FSS12 &FreeSans12pt7b
#define FSS18 &FreeSans18pt7b
#define FSS24 &FreeSans24pt7b
#define FSSB9 &FreeSansBold9pt7b
#define FSSB12 &FreeSansBold12pt7b
#define FSSB18 &FreeSansBold18pt7b
#define FSSB24 &FreeSansBold24pt7b
#define FSSO9 &FreeSansOblique9pt7b
#define FSSO12 &FreeSansOblique12pt7b
#define FSSO18 &FreeSansOblique18pt7b
#define FSSO24 &FreeSansOblique24pt7b
#define FSSBO9 &FreeSansBoldOblique9pt7b
#define FSSBO12 &FreeSansBoldOblique12pt7b
#define FSSBO18 &FreeSansBoldOblique18pt7b
#define FSSBO24 &FreeSansBoldOblique24pt7b
#define FS9 &FreeSerif9pt7b
#define FS12 &FreeSerif12pt7b
#define FS18 &FreeSerif18pt7b
#define FS24 &FreeSerif24pt7b
#define FSI9 &FreeSerifItalic9pt7b
#define FSI12 &FreeSerifItalic12pt7b
#define FSI19 &FreeSerifItalic18pt7b
#define FSI24 &FreeSerifItalic24pt7b
#define FSB9 &FreeSerifBold9pt7b
#define FSB12 &FreeSerifBold12pt7b
#define FSB18 &FreeSerifBold18pt7b
#define FSB24 &FreeSerifBold24pt7b
#define FSBI9 &FreeSerifBoldItalic9pt7b
#define FSBI12 &FreeSerifBoldItalic12pt7b
#define FSBI18 &FreeSerifBoldItalic18pt7b
#define FSBI24 &FreeSerifBoldItalic24pt7b
#define FF0 NULL //ff0 reserved for GLCD
#define FF1 &FreeMono9pt7b
#define FF2 &FreeMono12pt7b
#define FF3 &FreeMono18pt7b
#define FF4 &FreeMono24pt7b
#define FF5 &FreeMonoBold9pt7b
#define FF6 &FreeMonoBold12pt7b
#define FF7 &FreeMonoBold18pt7b
#define FF8 &FreeMonoBold24pt7b
#define FF9 &FreeMonoOblique9pt7b
#define FF10 &FreeMonoOblique12pt7b
#define FF11 &FreeMonoOblique18pt7b
#define FF12 &FreeMonoOblique24pt7b
#define FF13 &FreeMonoBoldOblique9pt7b
#define FF14 &FreeMonoBoldOblique12pt7b
#define FF15 &FreeMonoBoldOblique18pt7b
#define FF16 &FreeMonoBoldOblique24pt7b
#define FF17 &FreeSans9pt7b
#define FF18 &FreeSans12pt7b
#define FF19 &FreeSans18pt7b
#define FF20 &FreeSans24pt7b
#define FF21 &FreeSansBold9pt7b
#define FF22 &FreeSansBold12pt7b
#define FF23 &FreeSansBold18pt7b
#define FF24 &FreeSansBold24pt7b
#define FF25 &FreeSansOblique9pt7b
#define FF26 &FreeSansOblique12pt7b
#define FF27 &FreeSansOblique18pt7b
#define FF28 &FreeSansOblique24pt7b
#define FF29 &FreeSansBoldOblique9pt7b
#define FF30 &FreeSansBoldOblique12pt7b
#define FF31 &FreeSansBoldOblique18pt7b
#define FF32 &FreeSansBoldOblique24pt7b
#define FF33 &FreeSerif9pt7b
#define FF34 &FreeSerif12pt7b
#define FF35 &FreeSerif18pt7b
#define FF36 &FreeSerif24pt7b
#define FF37 &FreeSerifItalic9pt7b
#define FF38 &FreeSerifItalic12pt7b
#define FF39 &FreeSerifItalic18pt7b
#define FF40 &FreeSerifItalic24pt7b
#define FF41 &FreeSerifBold9pt7b
#define FF42 &FreeSerifBold12pt7b
#define FF43 &FreeSerifBold18pt7b
#define FF44 &FreeSerifBold24pt7b
#define FF45 &FreeSerifBoldItalic9pt7b
#define FF46 &FreeSerifBoldItalic12pt7b
#define FF47 &FreeSerifBoldItalic18pt7b
#define FF48 &FreeSerifBoldItalic24pt7b
#else // LOAD_GFXFF not defined so setup defaults to prevent error messages
// Free fonts are not loaded in User_Setup.h so define as font 1 (GLCD)
// to prevent compile error messages
#define GLCD  1
#define GFXFF  1
#define FF0 1
#define FF1 1
#define FF2 1
#define FF3 1
#define FF4 1
#define FF5 1
#define FF6 1
#define FF7 1
#define FF8 1
#define FF9 1
#define FF10 1
#define FF11 1
#define FF12 1
#define FF13 1
#define FF14 1
#define FF15 1
#define FF16 1
#define FF17 1
#define FF18 1
#define FF19 1
#define FF20 1
#define FF21 1
#define FF22 1
#define FF23 1
#define FF24 1
#define FF25 1
#define FF26 1
#define FF27 1
#define FF28 1
#define FF29 1
#define FF30 1
#define FF31 1
#define FF32 1
#define FF33 1
#define FF34 1
#define FF35 1
#define FF36 1
#define FF37 1
#define FF38 1
#define FF39 1
#define FF40 1
#define FF41 1
#define FF42 1
#define FF43 1
#define FF44 1
#define FF45 1
#define FF46 1
#define FF47 1
#define FF48 1
#define FM9  1
#define FM12 1
#define FM18 1
#define FM24 1
#define FMB9  1
#define FMB12 1
#define FMB18 1
#define FMB24 1
#define FMO9  1
#define FMO12 1
#define FMO18 1
#define FMO24 1
#define FMBO9  1
#define FMBO12 1
#define FMBO18 1
#define FMBO24 1
#define FSS9  1
#define FSS12 1
#define FSS18 1
#define FSS24 1
#define FSSB9  1
#define FSSB12 1
#define FSSB18 1
#define FSSB24 1
#define FSSO9  1
#define FSSO12 1
#define FSSO18 1
#define FSSO24 1
#define FSSBO9  1
#define FSSBO12 1
#define FSSBO18 1
#define FSSBO24 1
#define FS9  1
#define FS12 1
#define FS18 1
#define FS24 1
#define FSI9  1
#define FSI12 1
#define FSI19 1
#define FSI24 1
#define FSB9  1
#define FSB12 1
#define FSB18 1
#define FSB24 1
#define FSBI9  1
#define FSBI12 1
#define FSBI18 1
#define FSBI24 1
#endif // LOAD_GFXFF
[/code]
#1 typically works well, #2 can have problems if the font is not fixed-pitch because space may be narrower than some characters. You can also draw a solid-color box in the background color that covers the area needed for the largest text - usually slower than method #1, but does not require knowing what the previous text was.
Hi
Well it seems to work but the text is strobing
this is what i have changed so far
[code]
//tft.fillScreen(TFT_BLACK);
tft.fillRect(225, 108, 48, 23, TFT_BLACK); // стираем старое    x y width hight //(355, 117, 90, 23, TFT_BLACK)
  case 0:                                // Off
    tft.setTextColor(TFT_WHITE);          // Set up text color
  case 1:                                // 1.5Khz
    tft.setCursor(230, 125, 1);          // SetCursor(0, 0);
  case 2:                                // 2.0Khz
  case 3:                                // 2.5Khz
[/code]
Thanks for ya help for now
Howard
You are displaying the text then immediately overwriting it. Leave the text on the display, overwrite it immediately before displaying the new text.
Hi like at the top of the following case insted of at the end ???
Right before the tft.println is the best place. You will probably still have a slight flicker, have you tried just printing spaces, that is a bit faster than fillrect.
how do you fill spaces lol
Just realised spaces will not work, if the old characters are showing through, then a space will not cover anything. Only other option is to keep track of whatever was previously printed and reprint that in the background color.
Good night all
had enough going to bed ...prob wont get any sleep :sleeping: :cold_sweat:
Howard
Hi all
Well after a short break am back to trying to sort this problem out.
Here is the new code that i have been trying, the attanSwitch
part has not been tested yet, will deal with that later.
i also have a short video of the display showing the pulsing\flickering
if i can work out how to send it lol.
Thanks for looking
Howard
[code]
#include <Wire.h>
#include <EEPROM.h>
//#define TFT_GREY1 0x8410         // New colour  // HERE WE CORRECT THE GRAY COLOR !!!!! 11 0x8410 - GREEN LABEL 0x39E7 - YELLOW LABEL
int audioSwitch = A11;             // set up a constant for the Audio Filter switch
int audioSwitchCounter = 0;        // counter for the number of button presses //audiobuttonPushCounter
//int attanSwitch = ;             // set up a constant for the Audio Filter switch
//int attanSwitchState = 0;          // variable to hold the value of the switchPin
//int prevattanSwitchState = 0;      // variable to hold previous value of the switchpin
//int attanSwitchCounter = 0;        // counter for the number of button presses //audiobuttonPushCounter
void setup() {   // PUT YOUR SETUP CODE HERE, TO RUN ONCE:
  delay (100);
  Wire.begin();
tft.init();
//tft.fillRect(225, 108, 50, 23, TFT_GREY1); // стираем старое    x y width hight //(355, 117, 90, 23, TFT_BLACK)
//tft.setFreeFont(FF6);
tft.setFreeFont(FF41);//6
//tft.fillRoundRect(72, 45, 55, 23, 5, TFT_GREY1);tft.setCursor(80, 62, 1);tft.println("ATT");
tft.setCursor(300, 139, 1);   // 285, 139, 1 //152, 150, 1 //
tft.println("MODE"); //
//tft.setCursor(60, 17, 1);
tft.setCursor(300, 106, 1); //292, 106, 1
//tft.setFreeFont(FF26);//6
tft.drawRoundRect(140, 15, 334, 143, 5,TFT_BLUE ); // x,y,width,high,radius,color, rectangle A
//********* Setup Inputs And Outputs ************
pinMode(audioSwitch,INPUT);        // set up the switch pin as an input [ INPUT_PULLUP ]
digitalWrite(audioSwitch,HIGH);    // turn on pullup resistor
pinMode(A12, OUTPUT);      // Initiates off pin
pinMode(A13, OUTPUT);      // Initiates 1.5Khz pin
pinMode(A14, OUTPUT);      // Initiates 2.0Khz pin
pinMode(A15, OUTPUT);      // Initiates 2.5Khz pin
//pinMode(attanSwitch,INPUT);        // set up the switch pin as an input [ INPUT_PULLUP ]
//digitalWrite(attanSwitch,HIGH);    // turn on pullup resistor
//pinMode(A12, OUTPUT);     // Initiates off pin
//pinMode(A13, OUTPUT);     // Initiates 10dB pin
//pinMode(A14, OUTPUT);     // Initiates 20dB pin
//pinMode(A15, OUTPUT);     // Initiates 30dB pin
void loop() {   // PUT YOUR MAIN CODE HERE, TO RUN REPEATEDLY:
audioSwitchState = digitalRead(audioSwitch);        // check the status of the switch
    audioSwitchCounter ++;
    audioSwitchCounter %= 4;
    switch (audioSwitchCounter)
  case 0: // Off
    tft.fillRoundRect(225, 108, 60, 23, 5, TFT_WHITE);tft.setCursor(230, 125, 1);tft.println(" OFF");
    tft.fillRoundRect(225, 108, 60, 23, 5, TFT_BLACK);tft.setCursor(230, 125, 1);tft.println(" OFF");
    //tft.setCursor(230, 125, 1);           // SetCursor(230, 125, 1);
    //tft.setTextColor(TFT_WHITE);          // Set up text color
    //tft.setFreeFont(FF41);                // Set up Font Size
    //tft.println("OFF");                   // print to display ("OFF")
    //tft.setTextColor(TFT_BLACK);
  case 1: // 1.5Khz
    tft.fillRoundRect(225, 108, 60, 23, 5, TFT_WHITE);tft.setCursor(230, 125, 1);tft.println("1.5Khz");
    tft.fillRoundRect(225, 108, 60, 23, 5, TFT_BLACK);tft.setCursor(230, 125, 1);tft.println("1.5Khz");
    //tft.setCursor(230, 125, 1);           // SetCursor(0, 0);
    //tft.println("1.5K");                  // print to display ("1.5K")
    //tft.fillRect(225, 108, 75, 33, TFT_BLACK);  //225, 108, 48, 23, TFT_BLACK
  case 2: // 2.0Khz
    tft.fillRoundRect(225, 108, 60, 23, 5, TFT_WHITE);tft.setCursor(230, 125, 1);tft.println("2.0Khz");
    tft.fillRoundRect(225, 108, 60, 23, 5, TFT_BLACK);tft.setCursor(230, 125, 1);tft.println("2.0Khz");
    //tft.println("2.0K");                  // print to display ("2.0K")
  case 3: // 2.5Khz
    tft.fillRoundRect(225, 108, 60, 23, 5, TFT_WHITE);tft.setCursor(230, 125, 1);tft.println("2.5Khz");
    tft.fillRoundRect(225, 108, 60, 23, 5, TFT_BLACK);tft.setCursor(230, 125, 1);tft.println("2.5Khz");
    //tft.println("2.5K");                   // print to display ("2.5K")
//attanSwitchState = digitalRead(attanSwitch);        // check the status of the switch
    //if (attanSwitchState != prevattanSwitchState)   // compare the switchState to its previous state
    //if (attanSwitchState == LOW)                    // If the switch is pressed, count the press
    //attanSwitchCounter ++;
    //attanSwitchCounter %= 4;
    //switch (attanSwitchCounter)
  //case 0: // Off
    //tft.fillRoundRect(225, 108, 50, 23, 5, TFT_WHITE);tft.setCursor(230, 125, 1);tft.println("OFF");
    //tft.fillRoundRect(225, 108, 50, 23, 5, TFT_BLACK);tft.setCursor(230, 125, 1);tft.println("OFF");
    //digitalWrite(A12, HIGH);              // Output on
    //digitalWrite(A13, LOW);               // Output off
    //digitalWrite(A14, LOW);               // Output off
    //digitalWrite(A15, LOW);               // Output off
    //break;
  //case 1: //10dB
    //tft.fillRoundRect(225, 108, 50, 23, 5, TFT_WHITE);tft.setCursor(230, 125, 1);tft.println("10dB");
    //tft.fillRoundRect(225, 108, 50, 23, 5, TFT_BLACK);tft.setCursor(230, 125, 1);tft.println("10dB");
    //digitalWrite(A12, LOW);               // Output off
    //digitalWrite(A13, HIGH);              // Output on
    //break;
  //case 2: //20dB
    //tft.fillRoundRect(225, 108, 50, 23, 5, TFT_WHITE);tft.setCursor(230, 125, 1);tft.println("20dB");
    //tft.fillRoundRect(225, 108, 50, 23, 5, TFT_BLACK);tft.setCursor(230, 125, 1);tft.println("20dB");
    //digitalWrite(A14, HIGH);              // Output on
    //break;
  //case 3: //30dB
    //tft.fillRoundRect(225, 108, 50, 23, 5, TFT_WHITE);tft.setCursor(230, 125, 1);tft.println("30dB");
    //tft.fillRoundRect(225, 108, 50, 23, 5, TFT_BLACK);tft.setCursor(230, 125, 1);tft.println("30dB");
    //digitalWrite(A15, HIGH);              // Output on
    //break;
    //prevattanSwitchState = attanSwitchState; // save the current switch state as the last state
[/code]
Heres the video
20211108_202717_1_001.zip (2.6 MB)
Howard
Two problems I see.
First, you are updating the display every time through loop, repeatedly erasing the text and rewriting it when it has not changed.
Second, erasing and redrawing the box around the text is a slow process.
I'm not sure what color you want the text or background, but you can try this code and see if it works properly. You really do not need the case statement for the text but I've left it close to how you had it written.
#include <Wire.h>
#include <EEPROM.h>
int prevAudioSwitchCounter = -1;   // dummy value so that text displays the first time
const char audio_text[][7] = {
  " OFF",
  "1.5Khz",
  "2.0Khz",
  "2.5Khz",
int prev_text;
  delay (100);
  Wire.begin();
  tft.init();
  tft.drawRoundRect(140, 15, 334, 143, 5, TFT_BLUE ); // x,y,width,high,radius,color, rectangle A
  pinMode(audioSwitch, INPUT);       // set up the switch pin as an input [ INPUT_PULLUP ]
  digitalWrite(audioSwitch, HIGH);   // turn on pullup resistor
  // only need to update display if audioSwitchCounter has changed
  if (audioSwitchCounter != prevAudioSwitchCounter)
    prevAudioSwitchCounter = audioSwitchCounter;
      case 0: // Off
        tft.setTextColor(TFT_BLACK);          // Set text to background color
        tft.println(audio_text[prev_text]);   // Overwrite old text
        tft.setCursor(230, 125, 1);           // Reposition cursor
        tft.setTextColor(TFT_WHITE);          // Set text color
        tft.println(audio_text[0]);           // Print new text
        prev_text = 0;                        // Save pointer to text currently displayed
      case 1: // 1.5Khz
        tft.println(audio_text[1]);           // Print new text
        prev_text = 1;                        // Save pointer to text currently displayed
      case 2: // 2.0Khz
        tft.println(audio_text[2]);           // Print new text
        prev_text = 2;                        // Save pointer to text currently displayed
      case 3: // 2.5Khz
        tft.println(audio_text[3]);           // Print new text
        prev_text = 3;                        // Save pointer to text currently displayed
Hi David
Well it do work great thank you for ya help
You say that there is a way to do a better case statement for the text
Could you please explane to me ?
Thanks again
Howard
