How to Clear Interrupt pin 3 for mpu 6050?
I would like to clear the MPU 6050 gyroscope interrupt pin 3. I am aware you have to do it manually using arduino interrupt register. I do not know where actually to access this information. What datasheet should I be looking at? If any of you have a link for that, I would be pleased.
What exactly do you mean by this ? Set it to a particular state or what ?
Are you perhaps confusing interrupts on the Arduino with the INT pin on the 6050 ? How did you become aware of the need to do this, whatever it is ?
From Arduino Playground - MPU-6050
The FIFO buffer is used together with the interrupt signal. If the MPU-6050 places data in the FIFO buffer, it signals the Arduino with the interrupt signal so the Arduino knows that there is data in the FIFO buffer waiting to be read.
