How to clear the contents of a char array.
Hello everyone !
I have the below code which is a fragment of a bigger code. It receives NMEA from 2 GPS receivers and writes it into GPS1rcvdChars char array and GPS2rcvdChars char array respectively. I was wondering if there is an easy way to clear their contents after i am done parsing it in order to prepare it receive new data rather than overwrite it with the new data.
for example if it was a string i could do : GPS1rcvdChars = "";
Is there some similar way of doing it ?
Thanks !
const byte numChars = 100;
char GPS1rcvdChars[numChars];
char GPS2rcvdChars[numChars];
char GPS1GGA[numChars];
char GPS2GGA[numChars];
unsigned long GPS1tMark1 = 0;   // Καταγραφή χρόνου του τελευταίου GSA.
unsigned long GPS1tMark2 = 0;   // Χρόνος κατα τον οποίο εκτελείτε ο έλεγχος
unsigned long GPS2tMark1 = 0;
unsigned long GPS2tMark2 = 0;
const unsigned long TimeLimit = 1500; // Χρόνος μετα την πάροδο του οποίου το GPS θεωρείτε ανενεργό.
float GPS1satCount = 0.0;
float GPS2satCount = 0.0;
bool GPS1newData = false;
bool GPS2newData = false;
bool GPS1foundGGA = false;
bool GPS2foundGGA = false;
bool GPS1noGGA = false;
bool GPS2noGGA = false;
bool GPS1timeout = false;
bool GPS2timeout = false;
bool GPS1badFix = false;
bool GPS2badFix = false;
  Serial1.begin(4800);
  Serial3.begin(4800);
  ReceiveGPS1();
  ReceiveGPS2();
  GPS1lookNMEA();
  GPS2lookNMEA();
void ReceiveGPS1()
  static bool GPS1rcvInProgress = false;
  static byte GPS1ndx = 0;
  char startMarker = '
  char endMarker = '\n';
  char rc;
  while (Serial1.available() > 0 && GPS1newData == false)
    rc = Serial1.read();
    if (GPS1rcvInProgress == true)
      GPS1tMark1 = millis();
      if (rc != endMarker)
        GPS1rcvdChars[GPS1ndx] = rc;
        GPS1ndx++;
        if (GPS1ndx >= numChars)
          GPS1ndx = numChars - 1;
        GPS1rcvdChars[GPS1ndx] = '\0'; // terminate the string
        GPS1ndx = 0;
        GPS1newData = true;
    else if (rc == startMarker)
      GPS1rcvInProgress = true;
void ReceiveGPS2()
  static bool GPS2rcvInProgress = false;
  static byte GPS2ndx = 0;
  char rc;
  while (Serial3.available() > 0 && GPS2newData == false)
    rc = Serial3.read();
    if (GPS2rcvInProgress == true)
      GPS2tMark1 = millis();            //Μηδενισμός χρονομέτρου Timeout για το GPS.
        GPS2rcvdChars[GPS2ndx] = rc;
        GPS2ndx++;
        if (GPS2ndx >= numChars)
          GPS2ndx = numChars - 1;
        GPS2rcvdChars[GPS2ndx] = '\0'; // terminate the string
        GPS2ndx = 0;
        GPS2newData = true;
      GPS2rcvInProgress = true;
void GPS1lookNMEA()
  GPS1tMark2 = millis();
  if ((GPS1tMark2 - GPS1tMark1) > TimeLimit)
    GPS1timeout = true;
  if (GPS1newData == true)
    if (GPS1rcvdChars[2]=='G')
      delay (2);
      if (GPS1rcvdChars[3]=='G')
        delay (2);
        if (GPS1rcvdChars[4]=='A')
        delay (2);
        strcpy (GPS1GGA, GPS1rcvdChars);
        GPS1noGGAcount = 0;
        GPS1foundGGA = true;
        GPS1noGGA = false;
        GPS1parseData();
    if (GPS1foundGGA == false)
      if (GPS1noGGAcount >= 0 and GPS1noGGAcount < 15)  // Αν περάσουν ανω των 15 προτάσεων χωρίς GSA τότε η συσκευή
      {                                                               // δεν εκπέμπει την πρόταση GSA.
        GPS1noGGAcount++ ;
      if (GPS1noGGAcount == 15)
        GPS1noGGA = true;
void GPS2lookNMEA()
  GPS2tMark2 = millis();
  if ((GPS2tMark2 - GPS2tMark1) > TimeLimit) //Έλεγχος αν το GPS εκπέμπει πληροφορίες εντος προβλεπόμενου χρονικού πλαισίου.
    GPS2timeout = true;
  if (GPS2newData == true)
    if (GPS2rcvdChars[2]=='G')
      delay (2);
      if (GPS2rcvdChars[3]=='G')
        delay (2);
        if (GPS2rcvdChars[4]=='A')
        delay (2);
        strcpy (GPS2GGA, GPS2rcvdChars);
        GPS2noGGAcount = 0;
        GPS2foundGGA = true;
        GPS2noGGA = false;
        GPS2parseData();
    if (GPS2foundGGA == false)
      if (GPS2noGGAcount >= 0 and GPS2noGGAcount < 15)  // Αν περάσουν ανω των 15 προτάσεων χωρίς GSA τότε η συσκευή
        GPS2noGGAcount++ ;
      if (GPS2noGGAcount == 15)
        GPS2noGGA = true;
void GPS1parseData()
  char *strtokIndx;
  strtokIndx = strtok(GPS1GGA, ",");  //Πεδίο 0 GPGGA.
  strtokIndx = strtok(NULL, ",");     //Πεδίο 1 ώρα.
  strtokIndx = strtok(NULL, ",");     //Πεδίο 2
  strtokIndx = strtok(NULL, ",");     //Πεδίο 3 Ν.
  strtokIndx = strtok(NULL, ",");     //Περίο 4
  strtokIndx = strtok(NULL, ",");     //Πεδίο 5 E
  strtokIndx = strtok(NULL, ",");     //Πεδίο 6 A,V
  GPS1satCount = atof(strtokIndx);
  GPS1dopVal = atof(strtokIndx);
  if (GPS1satCount < 4.0)
    GPS1badFix = true;
    GPS1badFix = false;
void GPS2parseData()
 char *strtokIndx;
  strtokIndx = strtok(GPS2GGA, ",");  //Πεδίο 0 GPGGA.
  GPS2satCount = atof(strtokIndx);
  GPS2dopVal = atof(strtokIndx);
  if (GPS2satCount < 4.0)
    GPS2badFix = true;
    GPS2badFix = false;
HellasT:
Why?
But.....
GPS1rcvdChars[0] = '\0';
GPS2rcvdChars[0] = '\0';
memset()
address of array, sizeof array, value to fill
gfvalvo:
Why?
But.....
Mostly because i just wanted to know how to do it :slight_smile:
but also to hava no data inside it in case some string fails to be properly terminated and returns junk.
I still do not know how to use the memset() function but i can google it !
Thank you all !
