everything is fine one problem is
How would you do to clear up the matrix 8 x 8 on 2 x shift registers 595. If I press switch case of 1. I am not sure how to set up to rid off the old leds replace to blank led as a function for the next case of 2.
the switch case 1 is a clock diagram.
the switch case 2 is a Random LEDs lighting down.
I am trying to put the function as blankLed(); inside the case 1. It refused clear the leds for the next one.
one thing i dont like wait for the frames 11 to clear up the whole led. to do next one.
How would you set up any frame to clear up ?
// switch case project 2
// Project 20
#include <TimerOne.h>
int latchPin = 8; //Pin connected to Pin 12 of 74HC595 (Latch) RED JUMPER CONNECT TO MIDDLE
int clockPin = 12; //Pin connected to Pin 11 of 74HC595 (Clock)BROWN JUMMPER CONNT TO RIGHT
int dataPin = 11; //Pin connected to Pin 14 of 74HC595 (Data) BLACK JUMPER CONNECT TO LEFT
int led13 = 13;
int buttonPin = 7;
int state = 0;
int counter = 0;
byte frame = 0; // variable to store the current frame being displayed
int LEDclear[8][8] = {
{0, 0, 0, 0, 0, 0, 0, 0},
byte led[11][11] = { // the first array is bottom, the last array is top
{1, 56, 92, 158, 158, 130, 68, 56}, // 11 frames of an animation
{2, 56, 124, 186, 146, 130, 68, 56},
{4, 56, 116, 242, 242, 130, 68, 56},
{8, 56, 68, 226, 242, 226, 68, 56},
{16, 56, 68, 130, 242, 242, 116, 56},
{32, 56, 68, 130, 146, 186, 124, 56},
{64, 56, 68, 130, 158, 158, 92, 56},
{128, 56, 68, 142, 158, 142, 68, 56},
{1,255,1,1,1,56,255,254},
{16,56,124,254,254,254,238,68},
int LED2[8][8] = {
pinMode(latchPin, OUTPUT); // set the 3 digital pins to outputs
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(led13, OUTPUT); // 13 LED
pinMode(buttonPin, INPUT);//this time we will set the pin as INPUT
Serial.begin(9600);//initialize Serial connection
Timer1.initialize(10000); // set a timer of length 10000 microseconds
Timer1.attachInterrupt(screenUpdate); // attach the screenUpdate function
switch(state){
case 1:
Serial.println(" Pressed");
for (int i=0; i<11; i++) { // loop through all 11 frames of the animation
for (int j=0; j<11; j++) { // loop through the 8 rows per frame
led[i][j]; // = led[i][j] << 1 | led[i][j] >> 7; // bitwise rotation , repeat back begining to left side from right side.
frame++; // go to the next frame in the animation
if (frame > 10)
frame = 0;
} // make sure we go back to frame 0 once past 7
delay(500); // wait a bit between frames
if(digitalRead(buttonPin) == HIGH ){
// blankLED(); wont work
// led[11][10]; wont work
state += 1;
delay(100);
case 2:
Serial.println(" blinking 1000");
// www.insidegadgets.com/2010/11/07/fun-with-8x8-led-matrix/
// LED Matrix - Random LEDs lighting up
LED2[random(8)][random(8)] = 1;
if (counter > 200) {
blankLED();
counter = 0;
lightLED();
counter++;
state += 1;
blankLED();
delay(100);
default:
// Serial.println("blinking 500 millis");
Serial.println("press a button please");
digitalWrite(led13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(led13, LOW); // turn the LED off by making the voltage LOW
delay(100);
// press the button increment case swtich
state += 1;
Serial.println("The case would be number" );
}// end switch
if(state == 3){
state = 0;
void screenUpdate() { // function to display image
byte row = B10000000; // row 1
for (byte k = 0; k < 9; k++) {
digitalWrite(latchPin, LOW); // open latch ready to receive data
shiftIt(~led[frame][k] ); // LED array (inverted)
shiftIt(row); // row binary number
// Close the latch, sending the data in the registers out to the matrix
digitalWrite(latchPin, HIGH);
row = row >> 1; // bitshift right
void shiftIt(byte dataOut) {
// Shift out 8 bits LSB first, on rising edge of clock
boolean pinState;
//clear shift register read for sending data
digitalWrite(dataPin, LOW);
// for each bit in dataOut send out a bit
for (int i=0; i<8; i++) {
//set clockPin to LOW prior to sending bit
digitalWrite(clockPin, LOW);
// if the value of DataOut and (logical AND) a bitmask
// are true, set pinState to 1 (HIGH)
if ( dataOut & (1<<i) ) {
pinState = HIGH;
else {
pinState = LOW;
//sets dataPin to HIGH or LOW depending on pinState
digitalWrite(dataPin, pinState);
//send bit out on rising edge of clock
digitalWrite(clockPin, HIGH);
digitalWrite(clockPin, LOW); //stop shifting
void blankLED() {
int x = 0;
int y = 0;
for (x = 0; x < 8; x++) {
for (y = 0; y < 8; y ++) {
LED2[x][y] = 0;
void lightLED() {
byte columnbitsToSend = 0;
byte rowbitsToSend = 0;
int x = 0;
int y = 0;
rowbitsToSend = 0;
if (LED2[x][y] == 1) {
bitWrite(columnbitsToSend, y, HIGH);
bitWrite(rowbitsToSend, x, HIGH);
shiftOut(dataPin, clockPin, MSBFIRST, columnbitsToSend);
shiftOut(dataPin, clockPin, MSBFIRST, rowbitsToSend);
delay(2);
