In an IF statement, I need the arduino to stop looking at the MIDI.read(). So something like MIDI.read(off);
Any idea on how to do that?
tks
Seby
tks
Seby
Anyone please?
As MIDI.read() is a function you call then you simply don’t call it.
If you want to start again and skip those midi messages that were sent when you didn’t want to look at them then empty the buffer before calling it again.
Having said that your question does not make much sense. Why would want to do that?
Read the how to use this forum sticky post, it will tell you that just over an hour is an unacceptable time for bumping a thread. You have to leave it a minimum of 24 hours.
Grumpy_Mike:
If you want to start again and skip those midi messages that were sent when you didn’t want to look at them then empty the buffer before calling it again.Having said that your question does not make much sense. Why would want to do that?
Hi, tks for the answer, but that does not help me in my case. So I call it to start in a if, but IF in the ELSE , I want to cancel that call so the midi in wil not receive anything in.
tks
Seby
Sorry I can’t understand anything you said there.
Please post the code you have now and mark the place where you think you need to stop the MIDI from coming in. And if you can say why you need that it might also help.
Steve
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
// Setting up the counter
int reading = 0;
int lowest = 0;
int highest = 127;
int changeamnt = 1;
int ledPin = 13;
// Timing for polling the encoder
unsigned long currentTime;
unsigned long lastTime;
// Pin definitions
const int pinA = 8;
const int pinB = 9;
// Storing the readings
boolean encA;
boolean encB;
boolean lastA = false;
byte midiCh = 1; // MIDI channel to be used
byte note = 36; // Lowest MIDI note
byte cc = 1; // Lowest MIDI CC
pinMode(ledPin, OUTPUT);
// set the two pins as inputs with internal pullups
pinMode(pinA, INPUT_PULLUP);
pinMode(pinB, INPUT_PULLUP);
// Set up the timing of the polling
currentTime = millis();
lastTime = currentTime;
// Start the serial monitor for debugging
MIDI.begin();
MIDI.turnThruOff();
MIDI.setHandleControlChange(handleControlChange); // Listens to control change
//MIDI.setHandleNoteOn(handleNoteOn); // Listens to note ons
//MIDI.setHandleNoteOff(handleNoteOff); // Listens to note offs
MIDI.read();
// Read elapsed time
// Check if it's time to read
if(currentTime >= (lastTime + 5))
// read the two pins
encA = digitalRead(pinA);
encB = digitalRead(pinB);
// check if A has gone from high to low
if ((!encA) && (lastA))
// check if B is high
if (encB)
// clockwise
if (reading + changeamnt <= highest)
reading = reading + changeamnt;
// anti-clockwise
if (reading - changeamnt >= lowest)
reading = reading - changeamnt;
// Output reading for debugging
MIDI.sendControlChange(cc, reading, midiCh);
//Serial.println(reading);
// store reading of A and millis for next loop
lastA = encA;
// MIDI IN
void handleControlChange(byte channel, byte number, byte value) { // channel, CC, value
reading = value;
// Serial.println(value);
/* if (value != 0){
digitalWrite(ledPin, HIGH);
}else
digitalWrite(ledPin, LOW);
void handleNoteOn(byte channel, byte number, byte value) { // channel, note, velocity
void handleNoteOff(byte channel, byte number, byte value) { // channel, note, velocity
During the turning of the encoder, I want the arduino to stop listening because I have a midi feedback from the device i'm sending the midi to. This device is like in a thru mode and not possible to put it off. So I need a way to cancell the midi in while I'm turning the encoder. See in the MIDI IN section, I have a reading = value, wich I need but only when nothing is turned on the arduino.
tks
Seby
I see what you mean now, a bit of context helps enormously.
It is not MIDI.read() you want to turn off, as I said it dosn't make sense as it will only trigger any callback functions already received.
It seems to me what you want to do is to either stop MIDI being received in the first place, or flush the MIDI buffer to ignore any messages stored in the buffer.
I haven't tried this myself, but a good place to start would be to try something like this:-
MIDI.disconnectCallbackFromType(midi::ControlChange);
MIDI.read(); // look at all the messages and ignore the CC ones
MIDI.setHandleControlChange(handleControlChange); // re enable the call back function
Grumpy_Mike:
It is not MIDI.read() you want to turn off, as I said it dosn't make sense as it will only trigger any callback functions already received.It seems to me what you want to do is to either stop MIDI being received in the first place, or flush the MIDI buffer to ignore any messages stored in the buffer.
hi, tks for the answer, but where do I put those in my code please. lol. I'm a noob in coding. But from what I see, when I MIDI.setHandleControlChange(handleControlChange); the loop is so fast, it's like it's always enabled.
tks
Seby
EDIT: The loop is too fast with this try
#include <MIDI.h>
int reading = 0;
int lowest = 0;
int highest = 127;
int changeamnt = 1;
int ledPin = 13;
// Pin definitions
const int pinA = 8;
const int pinB = 9;
boolean encA;
boolean encB;
MIDI.begin();
MIDI.turnThruOff();
MIDI.read();
if (encB)
// clockwise
// anti-clockwise
lastA = encA;
}else{
// MIDI IN
reading = value;
/* if (value != 0){
}else
You do this when you want to flush the buffer. If it is too fast then add a small delay after the read and before you reenable the call back functions
Grumpy_Mike:
Probably I do it wrong, cause when Iput a delay, everything stop.
tks
Seby
seby20:
tks
Seby
Yes you probably did it wrong. But who knows what is wrong because you haven’t posted your code.
Look, only you have access to your system, we can only go off what you tell us and what you show us. To date you have been pretty vague about things.
When you post code you should say what you want it to do and what it actually does. For example when you said:-
You were not saying what it did. You were saying what you thought was wrong. Given that you previously said:-
How on earth can you make a diagnosis like that?
Ok, here's exactly whatr I'm trying to do. Thank you very much for your help and your time, I really appreciate it.
Seby
Thanks for that.
Please post code according to the rules in How to use this forum as we don't like going off site for code. This is what as posted.
#include <MIDI.h>
int reading = 0;
int lowest = 0;
int highest = 127;
int changeamnt = 1;
int ledPin = 13;
// Pin definitions
const int pinA = 8;
const int pinB = 9;
boolean encA;
boolean encB;
MIDI.begin();
MIDI.turnThruOff();
if(lastTime <= (currentTime ))
MIDI.read();
if (encB)
// clockwise
// anti-clockwise
lastA = encA;
// MIDI IN
reading = value;
/* if (value != 0){
}else
I must admit I am having difficulties in seeing how this code addresses what you are trying to do. Also I am not convinced that what you are trying to do will actually address your problem.
The way I see it is you are using a rotary encoder to change a parameter in a VI and changing that parameter is causing the VI to output data as if it came from the VI itself, which if I have it right, is what should happen.
However I can not make sense of your code. You seem to be disabling the call back function while you check the rotary encoder, I can't see how that will help with your problem.
If I have it right the problem is that conceptually you are stuck in a loop of cause and effect, if so there is no way out of it.
Grumpy_Mike:
Thanks for that.
Please post code according to the rules in How to use this forum as we don't like going off site for code. This is what as posted.#include <MIDI.h>
int reading = 0;
int lowest = 0;
int highest = 127;
int changeamnt = 1;
int ledPin = 13;
// Pin definitions
const int pinA = 8;
const int pinB = 9;
boolean encA;
boolean encB;
MIDI.begin();
MIDI.turnThruOff();
MIDI.read();
if (encB)
// clockwise
// anti-clockwise
lastA = encA;
// MIDI IN
reading = value;
/* if (value != 0){
}else
I must admit I am having difficulties in seeing how this code addresses what you are trying to do. Also I am not convinced that what you are trying to do will actually address your problem. The way I see it is you are using a rotary encoder to change a parameter in a VI and changing that parameter is causing the VI to output data as if it came from the VI itself, which if I have it right, is what should happen. However I can not make sense of your code. You seem to be disabling the call back function while you check the rotary encoder, I can't see how that will help with your problem. If I have it right the problem is that conceptually you are stuck in a loop of cause and effect, if so there is no way out of it.
Grumpy_Mike:
Thanks for that.
int reading = 0;
int lowest = 0;
int highest = 127;
int changeamnt = 1;
int ledPin = 13;
// Pin definitions
const int pinA = 8;
const int pinB = 9;
boolean encA;
boolean encB;
MIDI.begin();
MIDI.turnThruOff();
MIDI.read();
if (encB)
// clockwise
// anti-clockwise
lastA = encA;
// MIDI IN
reading = value;
/* if (value != 0){
}else
What I want is when I turn the encoder is to NOT receive anything from midi in and then still listen for maybe 1 seconf after there's no more movement. If no more movement, then BREAK the while/loop and then continue and re-enable the midi in.
tks
Seby
This is the way I would go about this in code. It compiles but I have not tried it out so it might need some tweaking.
#include <MIDI.h>
int reading = 0;
int lastReading = 0;
int lowest = 0;
int highest = 127;
int changeamnt = 1;
int ledPin = 13;
boolean moveing = false;
unsigned long restartTime = 0;
// Pin definitions
const int pinA = 8;
const int pinB = 9;
boolean encA;
boolean encB;
byte midiCh = 1; // MIDI channel to be used which is Channel 2
MIDI.begin();
MIDI.turnThruOff();
// Serial.begin(9600); // I don't thing you can do this with the MIDI.h libiary
if( ! moveing ) MIDI.read(); // real MIDI read
if(millis() > restartTime && moveing){ // restore call back
moveing = false;
if(readEncoder() != -1){ // a change in the reading has occoured
restartTime = millis() + 7; // or what ever
moveing = true;
delay(2); // to allow time for echo
MIDI.read(); // to flush out the buffer
int readEncoder(){ // see if the encoder has moved
reading = lastReading;
if (encB)
// clockwise
} // end of checking 1
// anti-clockwise
// ristrain the reading value
if( reading < 0) reading = 0;
if( reading > 127) reading = 127;
lastA = encA;
if(reading != lastReading){
lastReading=reading;
return reading;
else{
return -1; // if there is no change
// MIDI IN
reading = value;
/* if (value != 0){
}else
Grumpy_Mike:
This is the way I would go about this in code. It compiles but I have not tried it out so it might need some tweaking.#include <MIDI.h>
int reading = 0;
int lowest = 0;
int highest = 127;
int changeamnt = 1;
int ledPin = 13;
// Pin definitions
const int pinA = 8;
const int pinB = 9;
boolean encA;
boolean encB;
MIDI.begin();
MIDI.turnThruOff();
moveing = false;
moveing = true;
if (encB)
// clockwise
// anti-clockwise
lastA = encA;
return reading;
else{
// MIDI IN
reading = value;
/* if (value != 0){
}else
Hi, here's the result that I got from your code.
Tks from your help
Seby
OK. The minus one comes from the readEncoder function. It returns -1 when their is no change between the reading from the encoders and the reading last time.
The line
Calls the readEncoder() function and compares it to -1. If it is NOT -1 then that means their has been a change in the value of the reading and hence sends out the data.
The fact that the readEncoder at first sight appears not to be sending back -1 would suggest that there is something wrong with that function. I just took the code you wrote and moved it into a function to make the code a lot tidier. I must admit I did not understand your logic with this code. I did add code to prevent it going above 127, the MIDI maximum and below 0 the MIDI minimum value for the number you sent.
As a test replace
return reading;
with
return -1;
If that doesn't stop the continuous send then the problem is elsewhere.
Using 9600 baud for hairless is a bit slow, set this to 11520 baud at both ends. This will not immediately solve the current problem but will prevent problems further down the line.
I just had a quick look at the readEncoder function and I think there is a misplaced bracket. Try using this one:-
if (encB)
// clockwise
// anti-clockwise
lastA = encA;
return reading;
else{
Grumpy_Mike:
I just had a quick look at the readEncoder function and I think there is a misplaced bracket. Try using this one:-int readEncoder(){ // see if the encoder has moved
if (encB)
// clockwise
// anti-clockwise
lastA = encA;
return reading;
else{
Ok, tks again, I change my code for the one above, now, the problem, is when I turn the encoder, nothing is happening. But no more loop.
