How to clr lcd 16x2 after its disconnected
Hi All;
I am looking for some advice or pointers programming the arduino. I just started working with the arduino mega256, osepp 16x2 lcd keypad shield and I am trying to used this as a voltmeter. I have connected everything correct electrically and the small program that i wrote does indicate the correct voltage, however when I disconnect the power supply on the lcd panel still shows numbers.
I tried using the lcd.clear(), but this clears the whole display and I just want to clear the last viewed voltage displayed. I would like to only display V1 and V2 on the lcd panel. Any suggestions on how I can do that??
Also, on the lcd panel do i need to setup the reset button? Or is that a given to always be enabled? For some reason the reset button does not work with this code, but if i use an example code the reset works fine…
oid setup() {
  //this setups up the variables to 0
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  //this is added for testing to see what is happening
  int const OVERVOLTAGE    = 5.30;
  int const NOMINALVOLTAGE = 4.85;
  int const UNDERVOLTAGE   = 4.30;
  //need to display voltage from tp1 to tp2
  // read the input on analog pin 15:
 int sensorValue = analogRead(A15);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
   float voltage = sensorValue * (5.0 / 1023.0);
  //print out the value you read:
    Serial.println(voltage);
//need a loop that chks for voltage of 4.00V and 5.30V to blink, blinking indicates an error
  if (voltage < UNDERVOLTAGE)
     lcd.setCursor(0, 0);
     lcd.print("V1: "); + lcd.print(voltage);
     delay (5000);
 //added for testing
  Serial.println(voltage); + Serial.println("V1");
  Serial.println("V1 only");
  delay (5000);
    else if (OVERVOLTAGE > voltage)
    lcd.setCursor(1, 1);
    lcd.print("V2: "); + lcd.print(voltage);
 //added for testing
     Serial.println("V2"); + Serial.println(voltage);
     delay (5000);
      else if (voltage == NOMINALVOLTAGE)
        lcd.setCursor(9, 1);
     //added for testing
       delay (5000);
So, print space over the currently displayed values. It is not that difficult.
What is up with the horrid indenting in your code?
Use Tools + Auto Format before posting code again.
How is the Arduino supposed to know that you are done viewing the last displayed values?
If you just want to clear out a couple of characters then just go back and print spaces over them.
