Hello,
I am fairly new to Arduino and Coding alltogether so I am sorry if this is a silly question.
But I wanted to make a Pneumatic System, nothing big, just a small pump powered by a motor, and a servo motor which controlls the Air Switch. Now, currently via Serial Communication Ive got it to make a Pneumatic Cylinder to Push and Pull or just staying depending on a button I press on my Keyboard.
All is well and fine with that.
Code is here:
#include <Servo.h>
int motorPin = 9;
Servo myservo;
int pos = 0; // variable to store the servo position
myservo.attach(10); // attaches the servo on pin 10 to the servo object
pinMode(motorPin, OUTPUT);
while(Serial.available() == 0);
int val = Serial.read() - '0';
if( val == 1)
Serial.println("Pull");
analogWrite(motorPin, 255); // Motor Speed for the Air Pump
myservo.write(10); // Moves the Servo to the Degree neccessary to move the Switch Shaft
else if(val == 2)
Serial.println("Neutral");
analogWrite(motorPin, 0); // Since the Cylinder is in a Neutral state which doesnt Move the Motor is not Moving
myservo.write(60); // Moves the Servo to the Degree neccessary to move the Switch Shaft
else if(val == 3)
Serial.println("Push");
myservo.write(120); // Moves the Servo to the Degree neccessary to move the Switch Shaft
Serial.println("INVALID");
Now I would like some more Controll over this using actual buttons, three of them actualy which are supposed to do the same as what the above Code shows, One for Pushing, one for Pulling, one for Neutral position.
However I have only used simple LED Button Controll code and Wiring so far with a SINGULAR Button.
int switchPin = 8;
int ledPin = 11;
boolean lastButton = LOW;
boolean currentButton = LOW;
int ledLevel = 0;
pinMode (switchPin, INPUT);
pinMode (ledPin,OUTPUT);
//Boolean to debounce the Button
boolean debounce(boolean last)
boolean current = digitalRead(switchPin);
if (last!= current)
{delay(5);
return current;
// Detecting whether the Last button that was pressed was On or not in Order to change the LED Brightness
currentButton = debounce(lastButton);
if ( lastButton == LOW && currentButton == HIGH)
ledLevel = ledLevel + 25;
lastButton = currentButton;
if (ledLevel > 250) ledLevel = 0;
analogWrite(ledPin, ledLevel);
Now I know how to Wire the Buttons up but I dont know what to transfer from the 2nd Code into the 1st Code and how often and what I need to adjust.
I can Imagine that the booleans and the if sentence in the void loop are supposed to be used, however I dont quite understand what I need to adjust on it and if I even need to reuse them several times or whether Im fine with just using that singular one.
If theres anything that you dont understand, Im sorry however I will answer any questions.
I can sadly not take a Photo of the Wiring since I dont have a camera.
Ive looked in the Internet already but all there was were complicated and not very overlookable examples.
Thanks in Advance if someone is able to help me.
P.S Sorry for my English grammar I know it is not the best.
