How to: Coding an ARRAY of UDT - STRUCTS
Hello
I´ve coded two structs:
struct ELEMENT {
  unsigned long duration;
  byte colour[3];
containing the general data structure.
The following structs are used to built the needed sequences:
struct SEQUENCE4_1 {
  ELEMENT element[2];
struct SEQUENCE4_2{
  ELEMENT element[4];
struct SEQUENCE4_3 {
  ELEMENT element[6];
And the initialization of the datasets from oc1 to oc4:
SEQUENCE4_1  oc1{1000,{0,0,0,},1000,{0,0,0}};
SEQUENCE4_2  oc2{1000,{0,0,0,},1000,{0,0,0},1000,{0,0,0,},1000,{0,0,0}};
SEQUENCE4_3  oc3{1000,{0,0,0,},1000,{0,0,0},1000,{0,0,0,},1000,{0,0,0},1000,{0,0,0,},1000,{0,0,0}};
How to build an ARRAY containing the information to have access to the specified UDT, oc1 to oc3, within a for-each-loop?
Many thanks for sharing know how.
Here is an example of an array of structs which, judging from the variable names, I wrote to illustrate the principle in the context of a truck racing sketch
const byte numberOfTrucks = 4;
struct trucks
  unsigned long ignoreStart;
  boolean currentlyIgnored = true;
  int lapCount = 0;
} truckData[numberOfTrucks];
  truckData[0].currentlyIgnored = true;
  truckData[1].currentlyIgnored = false;
  truckData[2].currentlyIgnored = false;
  truckData[3].currentlyIgnored = true;
  for (int truck = 0; truck < numberOfTrucks; truck++)
    Serial.print(truck);
    Serial.println(truckData[truck].currentlyIgnored ? " currently ignored" : " timing in progress");
Note that like all arrays, the members of an array of structs must be identical
following output from code below
    1000 - 0, 0, 0
    1001 - 0, 0, 0
    2000 - 0, 0, 0
    2001 - 0, 0, 0
    2002 - 0, 0, 0
    2003 - 0, 0, 0
    3000 - 0, 0, 0
    3001 - 0, 0, 0
    3002 - 0, 0, 0
    3003 - 0, 0, 0
    3004 - 0, 0, 0
    3005 - 0, 0, 0
struct ELEMENT {
  byte colour[3];
ELEMENT seq1 [] = {
    { 1000, {0,0,0} },
    { 1001, {0,0,0} },
ELEMENT seq2 [] = {
    { 2000, {0,0,0} },
    { 2001, {0,0,0} },
    { 2002, {0,0,0} },
    { 2003, {0,0,0} },
ELEMENT seq3 [] = {
    { 3000, {0,0,0} },
    { 3001, {0,0,0} },
    { 3002, {0,0,0} },
    { 3003, {0,0,0} },
    { 3004, {0,0,0} },
    { 3005, {0,0,0} },
char s [80];
void
dispElement (
    ELEMENT  *p )
    for ( ; p->duration; p++)  {
        sprintf (s, "  %6ld - %d, %d, %d",
            p->duration, p->colour [0], p->colour [1], p->colour [2] );
        Serial.println (s);
    Serial.println ();
void setup (void) {
    Serial.begin (9600);
    dispElement (seq1);
    dispElement (seq2);
    dispElement (seq3);
void loop (void) {
