Hello guys,,, i have 2 source code, there are DMD (dot matrix display) source code and GPRS code,,, my problem is how to mix this 2 code, so the data that i get from GPRS will show in DMD...
my meterials :
-Arduino Uno R3
-GPRS Shield V2 from seeedstudio.com
-DMD (dot Matrix Display)
Please Help me to mixing the code guys,,
this dot matrix display (dmd) code :
#include <SPI.h> //SPI.h must be included as DMD is written by SPI (the IDE complains otherwise)
#include <DMD.h> //
#include <TimerOne.h> //
#include "SystemFont5x7.h"
#include "Arial_black_16.h"
//Fire up the DMD library as dmd
#define DISPLAYS_ACROSS 1
#define DISPLAYS_DOWN 1
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
Interrupt handler for Timer1 (TimerOne) driven DMD refresh scanning, this gets
called at the period set in Timer1.initialize();
void ScanDMD()
dmd.scanDisplayBySPI();
setup
Called by the Arduino architecture before the main loop begins
//initialize TimerOne's interrupt/CPU usage used to scan and refresh the display
Timer1.initialize( 5000 ); //period in microseconds to call ScanDMD. Anything longer than 5000 (5ms) and you can see flicker.
Timer1.attachInterrupt( ScanDMD ); //attach the Timer1 interrupt to ScanDMD which goes to dmd.scanDisplayBySPI()
//clear/init the DMD pixels held in RAM
dmd.clearScreen( true ); //true is normal (all pixels off), false is negative (all pixels on)
loop
Arduino architecture main loop
// 10 x 14 font clock, including demo of OR and NOR modes for pixels so that the flashing colon can be overlayed
dmd.selectFont(Arial_Black_16);
dmd.drawMarquee("Scrolling Text",14,(32*DISPLAYS_ACROSS)-1,0);
long start=millis();
long timer=start;
boolean ret=false;
while(!ret){
if ((timer+30) < millis()) {
ret=dmd.stepMarquee(-1,0);
timer=millis();
And This is GPRS Shield Code :
/* http get example */
#include <SoftwareSerial.h>
SoftwareSerial gprsSerial(7, 8);
gprsSerial.begin(19200);
Serial.println("Config SIM900...");
delay(2000);
Serial.println("Done!...");
gprsSerial.flush();
Serial.flush();
// signal quality
gprsSerial.println("AT+CSQ");
delay(100);
toSerial();
// attach or detach from GPRS service
gprsSerial.println("AT+CGATT?");
delay(100);
toSerial();
// bearer settings
gprsSerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");
delay(2000);
toSerial();
// bearer settings
gprsSerial.println("AT+SAPBR=3,1,\"APN\",\"epc.tmobile.com\"");
delay(2000);
toSerial();
// bearer settings
gprsSerial.println("AT+SAPBR=1,1");
delay(2000);
toSerial();
// initialize http service
gprsSerial.println("AT+HTTPINIT");
delay(2000);
toSerial();
// set http param value
gprsSerial.println("AT+HTTPPARA=\"URL\",\"http://mysite.com/info.log\"");
delay(2000);
toSerial();
// set http action type 0 = GET, 1 = POST, 2 = HEAD
gprsSerial.println("AT+HTTPACTION=0");
delay(6000);
toSerial();
// read server response
gprsSerial.println("AT+HTTPREAD");
toSerial();
gprsSerial.println("");
gprsSerial.println("AT+HTTPTERM");
toSerial();
delay(300);
delay(10000);
void toSerial()
while(gprsSerial.available()!=0)
Serial.write(gprsSerial.read());
Any Help will be apreciated
