How to combine MAX30100 sensor with DS18B20 temperature sensor
hello,
I am trying to use MAX30100 sensor with DS18B20 temperature sensor with LCD screen using arduino mega, when I tried each sensor separately it works, but when I combine two sensors, the temperature sensor work but MAX30100 does not work.
This is my code:
// First we include the libraries
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
// Data wire for TMP is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
//Buzzer is pluged into pin 11 & GND(Negative)
#define buzzer 11
// Temp at which it beeps at
#define alarmTemp 30
#define maxHR 150
#define maxSpO2 80
LiquidCrystal_I2C lcd(0x27,20,4);
#define REPORTING_PERIOD_MS     1000
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
PulseOximeter pox;
uint32_t tsLastReport = 0;
void onBeatDetected()
   Serial.println("Beat!");
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
   Serial.print("Initializing pulse oximeter..");
   lcd.backlight();
   lcd.begin(16,2);
   lcd.print("Initializing...");
   delay(3000);
   lcd.clear();
   // Initialize the PulseOximeter instance
   // Failures are generally due to an improper I2C wiring, missing power supply
   // or wrong target chip
   if (!pox.begin()) {
       Serial.println("FAILED");
       for(;;);
       Serial.println("SUCCESS");
    pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
   // Register a callback for the beat detection
   pox.setOnBeatDetectedCallback(onBeatDetected);
// Make sure to call update as fast as possible
   pox.update();
   if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
       Serial.print("Heart rate:");
       Serial.print(pox.getHeartRate());
       Serial.print("bpm / SpO2:");
       Serial.print(pox.getSpO2());
       Serial.println("%");
       lcd.clear();
       lcd.setCursor(0,0);
       lcd.print("BPM : ");
       lcd.print(pox.getHeartRate());
       lcd.setCursor(0,1);
       lcd.print("SpO2: ");
       lcd.print(pox.getSpO2());
       lcd.print("%");
       tsLastReport = millis();
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print(" Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperature readings
Serial.println("DONE");
Serial.print("Temperature is: ");
Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
  // You can have more than one DS18B20 on the same bus.
  // 0 refers to the first IC on the wire
  if (sensors.getTempCByIndex(0) > alarmTemp || pox.getHeartRate() > maxHR || pox.getSpO2() > maxSpO2 ) { //If the temp reaches above alarm temp:
    tone(buzzer, 1000, 250);
    delay(250);
    delay(250);
    delay(250);
    delay(250);
  delay(250);
Provide a GitHub link to where we can find 'MAX30100_PulseOximeter.h'
gfvalvo:
Is there some minimum rate you are supposed to all pox.update()? You have a 250 millisecond delay() at the bottom of loop(). Try getting rid of the delay.
