Hello, i need help for my project. I am trying to combine coding for pir sensor and rtc (real time clock). The problem is the program does not read the rtc time correctly. i need help! this is an urgent project. help!!
This is the Pir Sensor Code
int calibrationTime = 30; //time for sensor to calibrate 30s
int ledPin = 13; //choose the pin for the LED
int inputPin = 2; //choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected.
int val = 0; //variable for reading the pin status
int pinSpeaker = 10; // set up speaker
long unsigned int pause = 5000;
void setup(){
pinMode(ledPin, OUTPUT); //declare LED as Output
pinMode(inputPin, INPUT); //declare PIR Sensor as Input
pinMode(pinSpeaker, OUTPUT); //declare Speaker as Output parallel to LED
//PIR Sensor will calibrate for 30s first before start using it
Serial.print("Calibrating Sensor");
for(int i=0 ; i < calibrationTime; i++){
Serial.print(".");
Serial.print("done");
Serial.print("SENSOR ACTIVE");
delay(50);
void loop(){
val = digitalRead(inputPin); //read Input value
if (val == HIGH){ //check if the Input is HIGH
digitalWrite(ledPin, HIGH); //turn LED ON
playTone(300,160); //turn the Speaker ON
delay (150);
if (pirState == LOW){ //motion detected at what time
Serial.println("Motion detected!");
Serial.println("Motion detected at");
Serial.println(millis()/1000);
Serial.println("sec");
delay(50);
pirState = HIGH;
else{
digitalWrite(ledPin, LOW); //turn LED OFF
playTone(0,0);
delay(300);
if(pirState == HIGH){ //motion ended at what time
Serial.println("Motion ended!");
Serial.println("Motion ended at");
Serial.println((millis() - pause)/1000);
delay (50);
pirState = LOW;
//duration in mSecs, freuency in hertz
void playTone(long duration, int freq){
duration *= 1000;
int period = (1.0/freq) * 1000000;
long elapsed_time = 0;
while (elapsed_time < duration){
digitalWrite(pinSpeaker, HIGH);
delayMicroseconds(period/2);
digitalWrite(pinSpeaker, LOW);
elapsed_time += (period);
This is the rtc code
#include "Wire.h"
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
void setup(){
Wire.begin();
setDateTime(); //MUST CONFIGURE IN FUNCTION
void loop(){
printDate();
void setDateTime(){
byte second = 30; //0-59
byte minute = 16; //0-59
byte hour = 16; //0-23
byte weekDay = 2; //1-7
byte monthDay = 8; //1-31
byte month = 3; //1-12
byte year = 13; //0-99
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write(zero); //stop Oscillator
Wire.write(decToBcd(second));
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(decToBcd(weekDay));
Wire.write(decToBcd(monthDay));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.write(zero); //start
Wire.endTransmission();
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val) {
// Convert binary coded decimal to normal decimal numbers
return ( (val/16*10) + (val%16) );
void printDate(){
// Reset the register pointer
Wire.write(zero);
Wire.requestFrom(DS1307_ADDRESS, 7);
int second = bcdToDec(Wire.read());
int minute = bcdToDec(Wire.read());
int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
int monthDay = bcdToDec(Wire.read());
int month = bcdToDec(Wire.read());
int year = bcdToDec(Wire.read());
//print the date EG 3/1/11 23:59:59
Serial.print(month);
Serial.print("/");
Serial.print(monthDay);
Serial.print("/");
Serial.print(year);
Serial.print(" ");
Serial.print(hour);
Serial.print(":");
Serial.print(minute);
Serial.print(":");
Serial.println(second);
This is the combine code. I know is not that neat and tidy. But there still nothing wrong during the compiling.
#include "Wire.h"
#include "RTClib.h"
byte zero = 0x00;
int ledPin = 13;
int inputPin = 2;
int pirState = LOW;
int val = 0;
void setup(){
Serial.println("Calibrating Sensor");
Serial.print(".");
Serial.println(" ");
Serial.println("done");
Serial.println("SENSOR ACTIVE");
delay(50);
void loop(){
if (val == HIGH){
playTone(300,160);
delay (50);
rtc(); //Serial.print(millis()/1000);
//Serial.println("sec");
delay(50);
pirState = HIGH;
else{
playTone(0,0);
delay(50);
rtc(); //Serial.print((millis() - pause)/1000);
delay (50);
pirState = LOW;
duration *= 1000;
void rtc(){
printDate();
void setDateTime(){
byte minute = 01; //0-59
byte hour = 12; //0-23
byte weekDay = 1; //1-7
byte monthDay = 4; //1-31
byte month = 4; //1-12
void printDate(){
Wire.write(zero);
Serial.print("/");
Serial.print("/");
Serial.print(year);
Serial.print(" ");
Serial.print(hour);
Serial.print(":");
Serial.print(":");
Now the problem is as shown in the picture below. it does not detect the correct date and time.
I really need ur help. You may also correct me if there's anything wrong with the coding. Its a process of learning for me. But still i need to finish my project asap! waaaa!!! :'(( I really appreciate ur help!
