How to combine program?? can someone help me with it
i want to combine my program with simon game n temp lcd …but i want the delay to be the same with the game…means it will run at the same time nt 1 by 1 …
SIMON GAME PROG
#include <Tone.h>
Tone speakerpin;
int starttune[] = {NOTE_C4, NOTE_F4, NOTE_C4, NOTE_F4, NOTE_C4, NOTE_F4, NOTE_C4, NOTE_F4, NOTE_G4, NOTE_F4, NOTE_E4, NOTE_F4, NOTE_G4};
int duration2[] = {100, 200, 100, 200, 100, 400, 100, 100, 100, 100, 200, 100, 500};
int note[] = {NOTE_C4, NOTE_C4, NOTE_G4, NOTE_C5, NOTE_G4, NOTE_C5};
int duration[] = {100, 100, 100, 300, 100, 300};
boolean button[] = {2, 3, 4, 5}; //The four button input pins
boolean ledpin[] = {8, 9, 10, 11};  // LED pins
int turn = 0;  // turn counter
int buttonstate = 0;  // button state checker
int randomArray[100]; //Intentionally long to store up to 100 inputs (doubtful anyone will get this far)
int inputArray[100];
  speakerpin.begin(13); // speaker is on pin 13
  for(int x=0; x<4; x++)  // LED pins are outputs
    pinMode(ledpin[x], OUTPUT);
    pinMode(button[x], INPUT);  // button pins are inputs
    digitalWrite(button[x], HIGH);  // enable internal pullup; buttons start in high position; logic reversed
  randomSeed(analogRead(0)); //Added to generate "more randomness" with the randomArray for the output function
  for (int thisNote = 0; thisNote < 13; thisNote ++) {
     // play the next note:
     speakerpin.play(starttune[thisNote]);
     // hold the note:
     if (thisNote==0 || thisNote==2 || thisNote==4 || thisNote== 6)
       digitalWrite(ledpin[0], HIGH);
     if (thisNote==1 || thisNote==3 || thisNote==5 || thisNote== 7 || thisNote==9 || thisNote==11)
       digitalWrite(ledpin[1], HIGH);
     if (thisNote==8 || thisNote==12)
       digitalWrite(ledpin[2], HIGH);
     if (thisNote==10)
       digitalWrite(ledpin[3], HIGH);
     delay(duration2[thisNote]);
     // stop for the next note:
     speakerpin.stop();
     digitalWrite(ledpin[0], LOW);
     digitalWrite(ledpin[1], LOW);
     digitalWrite(ledpin[2], LOW);
     digitalWrite(ledpin[3], LOW);
     delay(25);
  for (int y=0; y<=99; y++)
    //function for generating the array to be matched by the player
    for (int thisNote = 0; thisNote < 6; thisNote ++) {
     speakerpin.play(note[thisNote]);
     // hold the note:
     delay(duration[thisNote]);
     speakerpin.stop();
     delay(25);
    for (int y=turn; y <= turn; y++)
    { //Limited by the turn variable
      Serial.println(""); //Some serial output to follow along
      Serial.print("Turn: ");
      Serial.print(y);
      Serial.println("");
      randomArray[y] = random(1, 5); //Assigning a random number (1-4) to the randomArray[y], y being the turn count
      for (int x=0; x <= turn; x++)
        Serial.print(randomArray[x]);
        for(int y=0; y<4; y++)
          if (randomArray[x] == 1 && ledpin[y] == 8)
          {  //if statements to display the stored values in the array
            digitalWrite(ledpin[y], HIGH);
            speakerpin.play(NOTE_G3, 100);
            delay(400);
            digitalWrite(ledpin[y], LOW);
            delay(100);
          if (randomArray[x] == 2 && ledpin[y] == 9)
            speakerpin.play(NOTE_A3, 100);
            delay(400);
            delay(100);
          if (randomArray[x] == 3 && ledpin[y] == 10)
            speakerpin.play(NOTE_B3, 100);
            delay(400);
            delay(100);
          if (randomArray[x] == 4 && ledpin[y] == 11)
            speakerpin.play(NOTE_C4, 100);
            delay(400);
            delay(100);
    input();
void input() { //Function for allowing user input and checking input against the generated array
  for (int x=0; x <= turn;)
  { //Statement controlled by turn count
      buttonstate = digitalRead(button[y]);
      if (buttonstate == LOW && button[y] == 2)
      { //Checking for button push
        delay(200);
        inputArray[x] = 1;
        delay(250);
        Serial.print(" ");
        Serial.print(1);
        if (inputArray[x] != randomArray[x]) { //Checks value input by user and checks it against
          fail();                              //the value in the same spot on the generated array
        }                                      //The fail function is called if it does not match
        x++;
       if (buttonstate == LOW && button[y] == 3)
        delay(200);
        inputArray[x] = 2;
        delay(250);
        Serial.print(" ");
        Serial.print(2);
          fail();
        x++;
      if (buttonstate == LOW && button[y] == 4)
        delay(200);
        inputArray[x] = 3;
        delay(250);
        Serial.print(" ");
        Serial.print(3);
          fail();
        x++;
      if (buttonstate == LOW && button[y] == 5)
        delay(200);
        inputArray[x] = 4;
        delay(250);
        Serial.print(" ");
        Serial.print(4);
          fail();
        x++;
  turn++; //Increments the turn count, also the last action before starting the output function over again
void fail() { //Function used if the player fails to match the sequence
  for (int y=0; y<=2; y++)
  { //Flashes lights for failure
    speakerpin.play(NOTE_G3, 300);
    delay(200);
    speakerpin.play(NOTE_C3, 300);
    delay(200);
  turn = -1; //Resets turn value so the game starts over without need for a reset button
TEMP SENSOR LCD Program
#include <LiquidCrystal.h>  // include the LCD driver library
//declare variables
float tempC = 0;  // variable for holding Celcius temp (floating for decimal points precision)
float tempf = 0;  // variable for holding Fareghneit temp
int tempPin = 0;  // Declaring the Analog input to be 0 (A0) of Arduino board.
float samples[8]; // array to hold 8 samples for Average temp calculation
float maxi = -100,mini = 100; // max/min temperature variables with initial values. LM35 in simple setup only measures Temp above 0.
int i;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(28, 29, 30, 31, 32, 33);
  Serial.begin(9600); // start serial communication
  lcd.begin(16, 2); // set up the LCD's number of columns and rows:
  lcd.setCursor(0, 0); // set LCD cursor position (column, row)
  lcd.print("Hello "); // print text to LCD
  lcd.setCursor(0, 1);
  lcd.print("Elderly project");
  delay(5000); // wait 500ms
  lcd.clear(); // clear LCD display
  lcd.print("LCD Temp");
  lcd.print(" Digital Monitor ");
  delay(4000);
  lcd.clear();
  Serial.println(analogRead(tempPin));
for(i = 0;i<=7;i++){ // gets 8 samples of temperature
samples[i] = ( 4.4 * analogRead(tempPin) * 100.0) / 1024.0;
Serial.print(".");
lcd.print("Current T: "); // print to LCD
lcd.setCursor(12, 0);
lcd.print(samples[i]);
tempC = tempC + samples[i];
  delay(800);
Serial.println(""); // Like and CR at serial monitor
Serial.println("");
tempC = tempC/8.0; // better precision
tempf = (tempC* 9)/ 5 + 32; // converts to fahrenheit
if(tempC > maxi) {maxi = tempC;} // set max temperature
if(tempC < mini) {mini = tempC;} // set min temperature
// Send Results to Serial Monitor
Serial.println("New measurement");
Serial.print(" Average Temperature in Celcius is " );             //send the data to the computer
Serial.println(tempC);//send the data to the computer
Serial.print(" Average Temperature in Farenait is " );             //send the data to the computer
Serial.println(tempf);//send the data to the computer
Serial.print(" MAX Temperature in Celcius is " );             //send the data to the computer
Serial.println(maxi);//send the data to the computer
Serial.print(" MIN Temperature in Celcius is " );             //send the data to the computer
Serial.println(mini);//send the data to the computer
// Send results to LCD.
lcd.print("Av.T   Max   Min");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
// print the measured temp average
lcd.print(tempC);
lcd.setCursor(6, 1);
// print the maximum temp
lcd.print(maxi);
lcd.setCursor(12, 1);
// print the minimum temp
lcd.print(mini);
digitalWrite(13, HIGH);    // set the LED off
delay(2000);   // Wait about 3 seconds to display the results to LCD screen befor starting the loop again
tempC = 0; // Set tempC to 0 so calculations can be done again
Read this before posting a programming question
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the # button above the posting area.
any kind soul can help me asap??
For various reasons, any statement like that has to go. When is our assignment due?
AWOL: delay(2000);   // Wait about 3 seconds
thursday :(
This is ironic. 8)
any soul help me pls????
What have you tried?
Show us your attempts at combining them.
Combining is essentially just interleaving the two, but the first thing you need is both codes to be kosher. The simon one baulks at the second line Tone speakerpin and won't compile.
i tried it combine but it only works 1 step by 1 step i dunno how to do the loop together
all_together.ino (11 KB)
samples[i] = ( 4.4 * analogRead(tempPin) * 100.0) / 1024.0; // conversion math of LM35 sample to readable temperature and stores result to samples array. 1024 is the Bit depth (quantization) of Arduino.
// 5 is the supply volts of LM35. Change appropriatelly to have correct measurement. My case is 4.4Volts.
If your Arduino is operating at 4.4 volts, it’s either damaged or needs new batteries powering it. It should be at very close to 5.0 V or 3.3 V, depending on which Arduino you have.
That’s 400 bytes of the 2048 that you have available.
How many times is this going to loop?
You need to do more than say that you are frustrated. You need to say exactly what the code does, and does not, do.
mian91: i tried it combine but it only works 1 step by 1 step i dunno how to do the loop together
Did it compile OK?
What Arduino do you have?
People, I fear we may be too late. See reply #6.
He didn't say which Thursday. :P
Besides, it's still Thursday here. Late Thursday, admittedly.
The OP might want to Google "assignment extension".
[quote author=Nick Gammon link=topic=130611.msg996989#msg996989 date=1352977195]
Did it compile OK? [/quote]
yes no error
[quote author=Nick Gammon link=topic=130611.msg996990#msg996990 date=1352977268]
What Arduino do you have? [/quote]
i using arduino mega
AWOL: People, I fear we may be too late. See reply #6.
i have few more weeks before i grauate fyi.....last thursday was my presentation i did not show the combine codes
