How to combine these two codes
How do I combine these two codes so they work properly together without malfunction? I've gotten very close at a few attempts where they work combined but not in a proper way.
int greenLed = 7;
int yellowLed = 6;
int redLed = 5;
int analogValue = 0;
float voltage = 0;
int ledDelay = 1000;
#define Tone_G 392 // Define Tone G
#define Tone_A 440 // Define Tone A
#define Tone_B 494 // Define Tone B
const int buttonPin = 11;
const int Sound = 12; // For the speakers - sound will occur on Pin 11
const int ledPin4 = 4;
const int ledPin3 = 3;
const int ledPin2 = 2;
int buttonState = 0;
  pinMode(ledPin4, INPUT);
  pinMode(ledPin3, INPUT);
  pinMode(ledPin2, INPUT);
  pinMode(greenLed, INPUT);
  pinMode(yellowLed,INPUT);
  pinMode(redLed, INPUT);
  pinMode(buttonPin, INPUT);
  pinMode(Sound, INPUT); //speaker
  digitalWrite(ledPin4, HIGH); // Turn built-in LED on
  tone(Sound, Tone_G, LOW); // Tone to play out of speaker. This Tone is G
  delay(200);
  digitalWrite(ledPin3, HIGH); // Turn built-in LED on
  tone(Sound, Tone_A, LOW); // Tone to play out of speaker. This Tone is A
  delay(200);
  digitalWrite(ledPin2, HIGH); // Turn built-in LED on
  tone(Sound, Tone_B, LOW); // Tone to play out of speaker. This Tone is B
  delay(200);
  noTone(Sound); // No Sound
  digitalWrite(ledPin2, LOW); // Turn built-in LED on
  delay(200);
  digitalWrite(ledPin3, LOW); // Turn built-in LED on
  delay(200);
  digitalWrite(ledPin4, LOW); // Turn built-in LED on
  delay(200);
void loop(){
  delay(ledDelay);
  digitalWrite(redLed, LOW);
  delay(100);
  digitalWrite(yellowLed, LOW);
  delay(100);
  digitalWrite(greenLed, LOW);
  delay(100);
   // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LEDS on:
    delay(200);
    delay(200);
    delay(200);
  else {
    // turn LEDS off:
    delay(100);
    delay(100);
    delay(100);
SECOND CODE
int Pin13 = 13;
// the setup routine runs once when you press reset:
  pinMode(Pin13, OUTPUT);
  // initialize serial communication at 9600 bits per second:
  int sensorValue = analogRead(A0);
  float voltage = sensorValue * (5.0 / 1023.0);
  Serial.println(voltage);
if (voltage <3.00){
  digitalWrite(Pin13, LOW);
  digitalWrite(Pin13, HIGH);
Define "work together" and "malfunction"
But you didn't post any of them
pinMode(greenLed, INPUT); Unusual..
@OP
greenLed is an output device which is being driven by DPin-7; so, the direction of DPin-7 should be INPUT or OUTPUT?
Never mind got it to work :slight_smile:
