#include <OneWire.h>
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
//Temperature chip i/o
OneWire ds(DS18S20_Pin); // on digital pin 2
void setup(void) {
void loop(void) {
float temperature = getTemp();
Serial.println(temperature);
delay(100); //just here to slow down the output so it is easier to read
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println(“CRC is not valid!”);
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print(“Device is not recognized”);
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data = ds.read();
ds.reset_search();*
byte MSB = data[1];*
byte LSB = data[0];*
float tempRead = ((MSB << 8) | LSB); //using two’s compliment*
float TemperatureSum = tempRead / 16;*
return TemperatureSum;*
THIS IS MY PROGRAM FOR TEMPERATURE SENSOR.
#include “DFRobot_PH.h”
#include <EEPROM.h>
#define PH_PIN A1
float voltage,phValue,temperature = 25;
DFRobot_PH ph;
- Serial.begin(115200); *
- ph.begin();*
{ - static unsigned long timepoint = millis();*
- if(millis()-timepoint>1000U){ //time interval: 1s*
- timepoint = millis();*
- //temperature = readTemperature(); // read your temperature sensor to execute temperature compensation*
voltage = analogRead(PH_PIN)/1024.0*5000; // read the voltage - phValue = ph.readPH(voltage,temperature); // convert voltage to pH with temperature compensation*
- Serial.print(“temperature:”);*
- Serial.print(temperature,1);*
- Serial.print("^C pH:");*
- Serial.println(phValue,2);*
- ph.calibration(voltage,temperature); // calibration process by Serail CMD*
float readTemperature()
{ - //add your code here to get the temperature from your temperature sensor*
AND THIS IS FOR PH SENSOR.
HOW TO COMBINE THESE TWO PROGRAMS SO THAT SERIAL MONITOR SHOWS BOTH TEMPERATURE AND PH VALUE OF ANY LIQUID?
