how to combine this arduino sketch..
  1. FIRST SKETCH… (fingerprint+lcd+sd)
#include <SPI.h>
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11,8, 7, 6, 5);
const int chipSelect = 4;
File myFile;
int x=0;
int y=0;
int getFingerprintIDez();
uint8_t getFingerprintEnroll(uint8_t id);
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
void setup()  {
lcd.begin(16,2); lcd.setCursor(0,0); lcd.print("Scanear Huella");
pinMode(13,OUTPUT);
pinMode(12,OUTPUT);
pinMode(9,OUTPUT);
pinMode(11, OUTPUT);
pinMode(0, OUTPUT);
pinMode(0, OUTPUT);// sd
pinMode(A0, INPUT);
Serial.print("initializing SD card...");
pinMode(4, OUTPUT);
if (!SD.begin(4))
 Serial.println("initializing error!");
 return;
Serial.println("initializing ok.");
finger.begin(57600);
if (finger.verifyPassword())
lcd.clear();
lcd.print(" Inicializando");
Serial.println("Found fingerprint sensor!!");
 Serial.println("Did not find fingerprint sensor ");
 while (1);
} // run over and over again
lcd.clear();
lcd.print(" id=");
Serial.println("Type in the ID # you want to save this finger as......");
uint8_t id = 0;
while (true)
 while (! Serial.available());
 char c = Serial.read();
 if (! isdigit(c)) break;
 id *= 10;
 id += c - '0';
lcd.clear();
lcd.print(id);
Serial.print("Enrolling ID #");
Serial.println(id);
while (!  getFingerprintEnroll(id) );
uint8_t p = -1;
Serial.println("Waiting for valid finger to enroll");
lcd.clear();
lcd.print(" waiting......¡");
while (p != FINGERPRINT_OK)
 p = finger.getImage();
 switch (p) {
 case FINGERPRINT_OK:
 lcd.clear();
 lcd.print(" Image taken¡");
 Serial.println("Image taken");
 case FINGERPRINT_NOFINGER:
 Serial.println(".");
 case FINGERPRINT_PACKETRECIEVEERR:
 Serial.println("Communication error");
 case FINGERPRINT_IMAGEFAIL:
 Serial.println("Imaging error");
 default:
 Serial.println("Unknown error");
}// OK success!
p = finger.image2Tz(1);
switch (p)
 lcd.clear();
 lcd.print("Image converted");
 Serial.println("Image converted");
 case FINGERPRINT_IMAGEMESS:
 Serial.println("Image too messy");
 return p;
 return p;
 case FINGERPRINT_FEATUREFAIL:
 Serial.println("Could not find fingerprint features");
 return p;
 case FINGERPRINT_INVALIDIMAGE:
 return p;
 default:
 return p;
lcd.clear();
lcd.print(" Remove finger¡");
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER)
p = -1;
lcd.clear();
lcd.print(" Place same finger again...¡");
Serial.println("Place same finger again");
 switch (p) {
 Serial.print(".");
 default:
}// OK success!
p = finger.image2Tz(2);
switch (p)
 lcd.clear();
 lcd.print(" Image converted¡");
 return p;
 return p;
 return p;
 return p;
 default:
 return p;
}// OK converted!
p = finger.createModel();
if (p == FINGERPRINT_OK)
 lcd.clear();
 lcd.print(" Prints matched¡");
 Serial.println("Prints matched!");
else if (p == FINGERPRINT_PACKETRECIEVEERR)
 return p;
else if (p == FINGERPRINT_ENROLLMISMATCH)
 Serial.println("Fingerprints did not match");
 return p;
 return p;
p = finger.storeModel(id);
myFile = SD.open("sensor.txt", FILE_WRITE);//  Stored! en sd
if (myFile) // if the file opened okay, write to it:
 Serial.print("Writing to sensor.txt...");
 myFile.println("sensor 1, 2, 3.");// close the file:
 myFile.close();
 Serial.println("done.");
 Serial.println("error openingsensor.txt");// if the file didn't open, print an error:
myFile = SD.open("sensor.txt");
if (myFile)
 Serial.println("sensor.txt:");
 while (myFile.available()) // read from the file until there's nothing else in it:
  Serial.write(myFile.read());
 // close the file:
 myFile.close();
 Serial.println("error opening test.txt");// if the file didn't open, print an error:
lcd.clear();/// end sd
lcd.print("Stored!");
Serial.println("¡¡ informacion Guardada");
 return p;
else if (p == FINGERPRINT_BADLOCATION)
 Serial.println("Could not store in that location");
 return p;
} else if (p == FINGERPRINT_FLASHERR)
 Serial.println("Error writing to flash");
 return p;
 return p;
can anyone help me???
(Sure - I put in code tags for you. Moderator)
2)second sketch web server is this
(here too. Moderator)
#include <SPI.h>
#include <Ethernet.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 2); // IP address, may need to change depending on network
EthernetServer server(80);  // create a server at port 80
String HTTP_req;          // stores the HTTP request
boolean LED_status = 0;   // state of LED, off by default
   Ethernet.begin(mac, ip);  // initialize Ethernet device
   server.begin();           // start to listen for clients
   Serial.begin(9600);       // for diagnostics
   pinMode(2, OUTPUT);       // LED on pin 2
   EthernetClient client = server.available();  // try to get client
   if (client) {  // got client?
       boolean currentLineIsBlank = true;
       while (client.connected()) {
           if (client.available()) {   // client data available to read
               char c = client.read(); // read 1 byte (character) from client
               HTTP_req += c;  // save the HTTP request 1 char at a time
               // last line of client request is blank and ends with \n
               // respond to client only after last line received
               if (c == '\n' && currentLineIsBlank) {
                   // send a standard http response header
                   client.println("Content-Type: text/html");
                   client.println("Connection: close");
                   client.println();
                   // send web page
                   client.println("<!DOCTYPE html>");
                   client.println("<html>");
                   client.println("<head>");
                   client.println("<title>Arduino LED Control</title>");
                   client.println("</head>");
                   client.println("<body>");
                   client.println("<h1>LED</h1>");
                   client.println("<p>Click to switch LED on and off.</p>");
                   client.println("<form method=\"get\">");
                   ProcessCheckbox(client);
                   client.println("</form>");
                   client.println("</body>");
                   client.println("</html>");
                   Serial.print(HTTP_req);
                   HTTP_req = "";    // finished with request, empty string
               // every line of text received from the client ends with \r\n
               if (c == '\n') {
                   // last character on line of received text
                   // starting new line with next character read
               else if (c != '\r') {
                   // a text character was received from client
                   currentLineIsBlank = false;
           } // end if (client.available())
       } // end while (client.connected())
       delay(1);      // give the web browser time to receive the data
       client.stop(); // close the connection
   } // end if (client)
// switch LED and send back HTML for LED checkbox
void ProcessCheckbox(EthernetClient cl)
   if (HTTP_req.indexOf("LED2=2") > -1) {  // see if checkbox was clicked
       // the checkbox was clicked, toggle the LED
       if (LED_status) {
           LED_status = 0;
       else {
           LED_status = 1;
   if (LED_status) {    // switch LED on
       digitalWrite(2, HIGH);
       // checkbox is checked
       cl.println("<input type=\"checkbox\" name=\"LED2\" value=\"2\" \
       onclick=\"submit();\" checaked>LED2");
   else {              // switch LED off
       digitalWrite(2, LOW);
       // checkbox is unchecked
       onclick=\"submit();\">LED2");
Now combine the stuff before setup(), the stuff in setup(), the stuff in loop(). Functions can be left alone. Then, compile & test.
#include <SPI.h>
#include <SD.h>
#include <SPI.h>
File myFile;
int x=0;
int y=0;
void setup()  {
pinMode(13,OUTPUT);
pinMode(12,OUTPUT);
pinMode(9,OUTPUT);
pinMode(0, OUTPUT);
pinMode(A0, INPUT);
pinMode(4, OUTPUT);
if (!SD.begin(4))
 return;
lcd.clear();
 while (1);
lcd.clear();
lcd.print(" id=");
uint8_t id = 0;
while (true)
 id *= 10;
 id += c - '0';
lcd.clear();
lcd.print(id);
Serial.println(id);
uint8_t p = -1;
lcd.clear();
 switch (p) {
 lcd.clear();
 default:
}// OK success!
switch (p)
 lcd.clear();
 return p;
 return p;
 return p;
 return p;
 default:
 return p;
lcd.clear();
delay(2000);
p = 0;
p = -1;
lcd.clear();
 switch (p) {
 Serial.print(".");
 default:
}// OK success!
switch (p)
 lcd.clear();
 return p;
 return p;
 return p;
 return p;
 default:
 return p;
}// OK converted!
 lcd.clear();
 return p;
 return p;
 return p;
 myFile.close();
if (myFile)
 // close the file:
 myFile.close();
 return p;
 return p;
 return p;
 return p;
client.println();
// send web page
if (c == '\n') {
if (LED_status) {
LED_status = 0;
else {
LED_status = 1;
Go thru, get rid of duplicate library calls, resolve any duplicate pin usage, etc. Good luck.
thank you.. no error..
but, the output is it not what i expected.. the fingerprint not found, and the web web server not available..
my expectation is data fingerprint show in web server.. can you do that.. design coding fingerprint and web server.. of course i already do that but nothing come out..
Sorry, I am not familiar with the Fingerprint, LCD, and Ethernet libraries.
I'll move this to the Programming forum, you're more likely to get help there.
Some of the Arduino libraries interfere with each other.
...R
The Ethernet shield uses SPI, pin 10-13. Your LCD is using some of those pins. You’ll have to change your LCD pins to something else.
