How to combine two codes for a boat with waypoint gps navigation?
I have a project to build a boat with waypoint gps navigation. I've made 2 source codes, the first is the code for the GPS waypoint and the other is the code for the compass heading with the motor. but I'm confused how to combine the two codes so that the program can run using the l298n motor driver. The two codes are as follows:
  1. coding for gps waypoint
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#define RX_PIN 4 // GPIO 4=D2(conneect Tx of GPS)
#define TX_PIN 5 // GPIO 5=D1(Connect Rx of GPS
#define LED_PIN D3
#define GPS_BAUD 9600
#define WAYPOINT_THRESHHOLD 5
TinyGPSPlus gps;
SoftwareSerial ss(RX_PIN, TX_PIN);
char ssid[] = "...";                                       // Name of your network (HotSpot or Router name)
char pass[] = "....";
  ss.begin(GPS_BAUD);
  pinMode(LED_PIN, OUTPUT); //LED
  Serial.println("Waypoint Tracker");
 double targetLat = -7.014921;
 double targetLon = 107.74658943;
 while(ss.available() > 0)
  gps.encode(ss.read());
double dist = 99999999;
 if (gps.location.isValid()){
  double dist = distance(targetLat, targetLon, gps.location.lat(), gps.location.lng());
  Serial.print("distance to target: ");
  Serial.println(dist);
  if (dist < WAYPOINT_THRESHHOLD)
digitalWrite(LED_PIN, HIGH);
  if (dist > WAYPOINT_THRESHHOLD)
digitalWrite(LED_PIN, LOW);
double distance(double lat1, double lon1, double lat2, double lon2)
  // Conversion factor from degrees to radians (pi/180)
  const double toRadian = 0.01745329251;
  // First coordinate (Radians)
  double lat1_r = lat1 * toRadian;
  double lon1_r = lon1 * toRadian;
  // Second coordinate (Radians)
  double lat2_r = lat2 * toRadian;
  double lon2_r = lon2 * toRadian;
  // Delta coordinates
  double deltaLat_r = (lat2 - lat1) * toRadian;
  double deltaLon_r = (lon2 - lon1) * toRadian;
  // Distance
  double a = sin(deltaLat_r/2)*sin(deltaLat_r/2) + cos(lat1_r) * cos(lat2_r) * sin(deltaLon_r/2) * sin(deltaLon_r/2);
  double c = 2 * atan2(sqrt(a), sqrt(1-a));
  double distance = 6371 * c * 1000;
  return distance;
  1. coding for heading compass with motor
#include <Wire.h>
#include <QMC5883LCompass.h>
#define LEFT_MOTOR 5
#define RIGHT_MOTOR 6
QMC5883LCompass compass;
int calcLeftMotor(double relBearing) {
  if (relBearing > 0)
    return 255;
    return 1.425 * relBearing + 255;
int calcRightMotor(double relBearing) {
  if (relBearing <= 0)
    return 255;
    return -1.425 * relBearing + 255;
//KALAU NGASIH RAW DATA MAGNETIK
double calcHeading (int x, int y) {
  return -atan2(x, y) * 180 / 3.141592654;
    Wire.begin(D6, D5);
   pinMode(LEFT_MOTOR, OUTPUT);
   pinMode(RIGHT_MOTOR, OUTPUT);
   //init compass
   compass.init();
  double bearing = 0; //target angle
  compass.read(); // reads from compass
  double heading = calcHeading(compass.getX(), compass.getY());
  double relBearing = bearing - heading;
  int leftSpeed = calcLeftMotor(relBearing);
  int rightSpeed = calcRightMotor(relBearing);
  Serial.print(" Heading: "); Serial.println(heading);
  Serial.print("Left: "); Serial.print(leftSpeed); Serial.print(" Right: "); Serial.println(rightSpeed);
  Serial.println(" ");
  //analogWrite(LEFT_MOTOR, leftSpeed);
  //analogWrite(RIGHT_MOTOR, rightSpeed);
You need to compute the bearing (desired heading) from the current (lat, lon) to the target (lat, lon), then drive in that direction, using the electronic compass to tell you the current heading.
The simplest approach to driving is to use PID to differentially control twin motors, something like this code fragment:
   heading = get_heading();
   float error = heading - bearing;  //make sure sign is correct
   float correction = Kp*error;
   set_left_speed(base_speed + correction);
   set_right_speed(base_speed - correction);
You can determine Kp by trial and error. When the distance to the target is "small enough" then stop.
Short video example of exactly the above method: http://www.uoxray.uoregon.edu/orangutan/boat2.mp4
where do i put the pid code?
sorry, may i see the code you made for the project? just for reference, because I'm already frustrated with my project
Here is the main program. It was written for Atmel Studio, not for an Arduino, but it would not be difficult to convert the code to standard Arduino setup() and loop() structure.
differential drive motorboat autopilot, using GPS & BNO055 9DOF sensor
This version decodes $GPGGA sentences to get position and number of satellites in use
LV168 @ 20 MHz  Atmel Studio IV/ avr-gcc
sjr  7-9/2015
build options for floating point output:
add -Wl,-u,vfprintf to the LINKER options. It appears to only cater to printf but not scanf.
add -lprintf_flt or -lscanf_flt to the linker options which is done by including printf_flt as a library.
need to set -lm if using float in any case
compiler.c.elf.extra_flags= -Wl,-u,vfprintf -lprintf_flt -lm   -Wl,-u,vfscanf -lscanf_flt -lm
#include <ctype.h>
#include <stdint.h>
#include <stdio.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <pololu/orangutan.h>
#include <util/delay.h>
#include <math.h>
#include <stdlib.h>
#include <string.h>
#include <avr/interrupt.h>
// serial I/O on UART
#include "uarto.c"
// set up uart as STDOUT
static FILE uart_str = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE);
// basic I2C routines
#include "I2C.c"
// BNO055 I2C extras
#include "bno055_I2C.c"
// GPS routines
#include "gps_gga.c"
#define gps_parse_enable() gps_parse_enable=1
// routine to calculate heading error in degrees, taking into account compass wrap
int heading_error(int bearing, int current_heading)
 int error = current_heading - bearing;
// if (error >  180) error -= 360;
// if (error < -180) error += 360;
 error = (error + 540)%360-180;
 return error;
// routine to correct for compass wrap
int wrap360(int direction) {
//	while (direction > 359) direction -= 360;
//	while (direction <   0) direction += 360;
    direction=(direction+360)%360;
	return direction;
int main( void ) {
	unsigned char result;
	int i,v[3];
//predetermined BNO055 calibration constants
	int precal[]={-6,3,17,-2,395,112,0,1,0,1000,832}; //averages of 9 in situ calibration runs
	int motorSpeed=150, kp=40, bias=0, error=0;
	unsigned long timeout=50000UL; //max run time per leg in milliseconds
	unsigned long gps_last_fix=0;  //time since start of last GPS fix
	unsigned long gps_timeout=5000UL; //5 seconds since last fix
	int leg=0;  //current course leg
	int start_bearing = 0, point_bearing=0, gps_bearing=0, imu_heading=0;
	int yaw_offset = 13; //calibration factor to correct compass readings to true North
    double leg_dist=20.0, distance=0.0;
	int dist_to_go=0;
    long lat=0,lon=0;   //where we are now
	long lat1=0,lon1=0; //course start
	long lat2=0,lon2=0; //current destination
	int num_sats=0;
//  setup
  	gps_parse_init(9600); //enable uart
	stdout = &uart_str; //standard out for printf
	delay(1000); //wait for BNO055 power up
 	I2C_Init();
// check for BNO055 presence
	if (0xa0 != (result=I2C_ReadRegister(BNO055_A0,BNO055_WHO_AM_I))) { //check internal device ID
		clear();
		print(" No BNO");
		while(1); //hang here
// reset BNO055, in case of soft reboot
	I2C_WriteRegister(BNO055_A0, BNO055_SYS_TRIGGER, 0x20); //BNO055 system reset
	delay(1000); //required reset delay
// store earlier derived calibration parameters
	I2C_WriteCal(BNO055_A0, BNO055_CAL_DATA, (int *)precal);
	I2C_WriteRegister(BNO055_A0, BNO055_SYS_TRIGGER, 0x80); //use external 32 kHz crystal.
// set to measurement mode
	I2C_WriteRegister(BNO055_A0,BNO055_OPER_MODE,BNO055_OPER_MODE_NDOF);
	delay(10); //minimum 7 ms delay
//  end of setup. Now,
// get/set default initial heading using compass
	sei(); //enable interrupts
	gps_parse_status = 0; //ignore old results
	gps_parse_enable(); //(re)enable parsing
	lcd_goto_xy(0,1);
	print(" no fix");
// wait till GPS has fix
	while (gps_parse_status != 1);
	gps_parse_enable();
	clear();
	print("Aim");
	lcd_goto_xy(0,1);
	print("Push B");
// get compass reading, wait for button press
	unsigned long timer=millis();
	do {
		I2C_Read3Vectors(BNO055_A0,BNO055_FUSED_EULER, (int16_t *)v);
		if(gps_parse_status == 1) {
		num_sats = gga_num_sats();
		clear();
		imu_heading = wrap360((v[0]>>4) + yaw_offset);
		print_long(imu_heading); //yaw
		lcd_goto_xy(1,1);
		print_long(num_sats);
		print("s ");
		delay(300);
	 while (button_is_pressed(ANY_BUTTON)==0);  //HANG HERE until button pressed
// wait for next GPS fix
// start the run
	gps_last_fix = millis();
	gps_latlon(&lat1, &lon1); //record start point in lat1, lon1
	gps_parse_enable();
	point_bearing = imu_heading; //this is where we will go
	start_bearing = point_bearing; //save it for calculating next leg
// project new waypoint "distance" meters ahead -> (lat2, lon2)
	bearing_shoot((float)start_bearing, leg_dist, lat1, lon1, &lat2, &lon2);
// check!
	gps_bearing = (int) (course_to(lat1, lon1, lat2, lon2, &distance)+0.5);
	dist_to_go = distance + 0.5;
// start telemetry
	printf("S,%lu,%ld,%ld,%ld,%ld,%d,%d\n",millis(),lat1,lon1,lat2,lon2,gps_bearing,dist_to_go);
// start the course leg clock
	timer = millis();
// run course
	while(2) {
        switch (gps_parse_status)
		case 0: break;  //still decoding
		case 1:  //good fix
			gps_latlon(&lat, &lon);
			gps_parse_enable(); //re-enable parsing
			gps_bearing = (int) (course_to(lat, lon, lat2, lon2, &distance)+0.5);
// To take into account wind and currents,
// substitute calculated GPS bearing for point_bearing
			point_bearing = gps_bearing;
// telemetry
			 printf("G,%lu,%ld,%ld,%d,%d,%d\n",millis(),lat,lon,gps_bearing,dist_to_go,num_sats);
		 case 2:  //no fix
			clear();
			print(" no fix");
			printf("E,%lu,2,0,0,0,0\n",millis()); //error dump
		case 3:  //chksum error
    		clear();
			print("?chk");
			printf("E,%lu,3,0,0,0,0\n",millis()); //error dump
		default:  //shouldn't happen
			clear();
			print("-E-");
			printf("E,%lu,4,0,0,0,0\n",millis()); //error dump
		} //end switch
// continue to run this leg, steering with IMU
// (may not have recent GPS info in the following)
		I2C_Read3Vectors(BNO055_A0,BNO055_FUSED_EULER, (int16_t *)v);  //get Euler angles
		result=I2C_ReadRegister(BNO055_A0,BNO055_CALIB_STAT); //check calibration status
		for(i=0; i<3; i++) v[i] >>= 4;
		imu_heading = wrap360(v[0] + yaw_offset);
// update LCD display
		clear();
		print_long(point_bearing);
		print(" ");
		lcd_goto_xy(1,1);
		print("s ");
		print_long(dist_to_go);
// heading error and PID steering
		error = heading_error(point_bearing, imu_heading);
		//error is positive if current_heading > bearing (compass direction)
		//positive bias acts to reduce left motor speed, so bear left
		bias = (kp*error)/10;  //Kp in tenths (Ki, Kd not necessary in water)
		printf("I,%lu,%d,%d,%d,%d,%d,%d,%u,\n",millis(),
		point_bearing,imu_heading,error,bias,v[1],v[2],result);
		// the motor routines internally limit the argument to {-255, 255}
		set_m1_speed(motorSpeed-bias); //left motor
		set_m2_speed(motorSpeed+bias); //right motor
// check for recent GPS fix
		if (millis() - gps_last_fix > gps_timeout) //5 seconds, currently
			set_motors(0,0); //stop motors
			clear();
			print(" GPS-to"); //timeout!
			printf("E,%lu,5,0,0,0,0\n",millis()); //error dump
			delay(300);//wait a bit
		else {
			if ((millis()-timer) > timeout || dist_to_go < 3)
// leg timeout or at goal, stop motors
			clear();
			if (dist_to_go < 3) print("DIST");
			else print("TIME");
			set_motors(0,0);
			delay(1000); //drift a bit
			leg++;  //count course legs accomplished
// course is an equilateral triangle. Compute next goal
			start_bearing = wrap360(start_bearing+120);
			// calculate coordinates of next target, from where we should be
			if (leg==1) {
				 bearing_shoot((float)start_bearing, leg_dist, lat2, lon2, &lat2, &lon2);
			if (leg == 2) {
				 lat2=lat1; //third leg, set destination coords to
				 lon2=lon1; //start point
			if (leg == 3) break; //done
			//telemetry
			printf("S,%lu,%ld,%ld,%ld,%ld\n",millis(),lat,lon,lat2,lon2);
			// recalculate course from where we are now to current destination
			point_bearing = (int) (course_to(lat, lon, lat2, lon2, &distance) + 0.5);
			timer=millis();
			} //if(timeout)
		} //if gps_timeout else
	}  //while(2)
	clear();
	print("stop");
	char cz=26;
	printf("%c%c%c",cz,cz,cz); //end log file
	while(1); //hang
	return 0;
} //main
thank you sir, at least I have a reference to work on this project
