How to combine two libraries?
I would like to combine two libraries in order to run the DHT11 temperature/humidity sensor and the SEN0161 pH sensor at the same time. I’ve got each sensor running separately using the libraries but now i want to combine them together XD
I think i need to combine them using a loop, how would i do this? :~
Also how would i add another loop and a third piece of sample code if i wanted to add a third sensor? ]:slight_smile:
Data sheet for the DHT11 temperature sensor:
http://www.micro4you.com/files/sensor/DHT11.pdf
Wiki page for the SEN0161:
http://www.dfrobot.com/wiki/index.php/PH_meter(SKU:_SEN0161)
Sample code for DHT11 temperature and humidity sensor:
YourDuino.com Example Software Sketch
   DHT11 Humidity and Temperature Sensor test
   Credits: Rob Tillaart
   http://arduino-direct.com/sunshop/index.php?l=product_detail&p=162
   terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <dht11.h>
/*-----( Declare objects )-----*/
dht11 DHT11;
/*-----( Declare Constants, Pin Numbers )-----*/
#define DHT11PIN 2
void setup()   /*----( SETUP: RUNS ONCE )----*/
  Serial.println("DHT11 TEST PROGRAM ");
  Serial.print("LIBRARY VERSION: ");
  Serial.println(DHT11LIB_VERSION);
}/*--(end setup )---*/
void loop()   /*----( LOOP: RUNS CONSTANTLY )----*/
  Serial.println("\n");
  int chk = DHT11.read(DHT11PIN);
  Serial.print("Read sensor: ");
  switch (chk)
    case 0: Serial.println("OK"); break;
    case -1: Serial.println("Checksum error"); break;
    case -2: Serial.println("Time out error"); break;
    default: Serial.println("Unknown error"); break;
  Serial.print("Humidity (%): ");
  Serial.println((float)DHT11.humidity, 2);
  Serial.print("Temperature (oC): ");
  Serial.println((float)DHT11.temperature, 2);
  Serial.print("Temperature (oF): ");
  Serial.println(Fahrenheit(DHT11.temperature), 2);
  Serial.print("Temperature (K): ");
  Serial.println(Kelvin(DHT11.temperature), 2);
  Serial.print("Dew Point (oC): ");
  Serial.println(dewPoint(DHT11.temperature, DHT11.humidity));
  Serial.print("Dew PointFast (oC): ");
  Serial.println(dewPointFast(DHT11.temperature, DHT11.humidity));
  delay(2000);
}/* --(end main loop )-- */
/*-----( Declare User-written Functions )-----*/
//Celsius to Fahrenheit conversion
double Fahrenheit(double celsius)
	return 1.8 * celsius + 32;
//Celsius to Kelvin conversion
double Kelvin(double celsius)
	return celsius + 273.15;
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
	double A0= 373.15/(273.15 + celsius);
	double SUM = -7.90298 * (A0-1);
	SUM += 5.02808 * log10(A0);
	SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
	SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
	SUM += log10(1013.246);
	double VP = pow(10, SUM-3) * humidity;
	double T = log(VP/0.61078);   // temp var
	return (241.88 * T) / (17.558-T);
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
	double a = 17.271;
	double b = 237.7;
	double temp = (a * celsius) / (b + celsius) + log(humidity/100);
	double Td = (b * temp) / (a - temp);
	return Td;
/* ( THE END ) */
Here is the code for the SEN0161:
# This sample codes is for testing the pH meter V1.0.
 # Editor : Pseudo-judo
 # Date   : 2013.10.12
 # Ver    : 0.1
 # Product: pH meter
 # SKU    : SEN0161
#define SensorPin 0          //pH meter Analog output to Arduino Analog Input 0
unsigned long int avgValue;  //Store the average value of the sensor feedback
float b;
int buf[10],temp;
  pinMode(13,OUTPUT);
  Serial.println("Ready");    //Test the serial monitor
  for(int i=0;i<10;i++)       //Get 10 sample value from the sensor for smooth the value
    buf[i]=analogRead(SensorPin);
    delay(10);
  for(int i=0;i<9;i++)        //sort the analog from small to large
    for(int j=i+1;j<10;j++)
      if(buf[i]>buf[j])
        temp=buf[i];
        buf[i]=buf[j];
        buf[j]=temp;
  avgValue=0;
  for(int i=2;i<8;i++)                      //take the average value of 6 center sample
    avgValue+=buf[i];
  float phValue=(float)avgValue*5.0/1024/6; //convert the analog into millivolt
  phValue=3.5*phValue;                      //convert the millivolt into pH value
  Serial.print("    pH:");
  Serial.print(phValue,2);
  Serial.println(" ");
  digitalWrite(13, HIGH);
  delay(800);
  digitalWrite(13, LOW);
{/code}
I tried copy/pasting the libraries together but this returned an error message which says redefinition of 'void setup()', is this because 'void setup()' has been declared twice?
You don't combine libraries. Libraries are elements to be combined within your sketch.
Look at how you are using the two libraries in your two separate sketches and work out which elements you can copy from one sketch to the other to achieve your desired results.
Generally you put all the setup() stuff form both sketches into one setup() and the loop() stuff from both sketches into one loop().
 # Date   : 2013.10.12
 # Ver    : 0.1
 # Product: pH meter
 # SKU    : SEN0161
/* YourDuino.com Example Software Sketch
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN 2
  double a = 17.271;
  double b = 237.7;
  return Td;
/* ( THE END ) */
float b;
int buf[10],temp;
  pinMode(13,OUTPUT);
    delay(10);
      if(buf[i]>buf[j])
        temp=buf[i];
        buf[i]=buf[j];
        buf[j]=temp;
  avgValue=0;
    avgValue+=buf[i];
  delay(800);
  switch (chk)
  case 0:
  case -1:
  case -2:
  default:
  delay(2000);
I was able to chuck some things around and get something to compile.
Realized i needed to put the loops and the setups together but i appreciate the help guys.
pseudo-judo:
Read this:-
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
