how to combine ultrasonic sensor and pir sensor by using one arduino uno
can you guys help me how to combine those sensor by using only one arduino uno for my final year project as i have tried it many times but still did not get any output
this is the code that i have tried before
#include <NewPing.h>
#define MAX_DISTANCE 400 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
int echoPin = 10; // Echo Pin of the ultrasonic sensor
int trigPin = 9; // Trigger pin ofthe ultrasonic sensor
int pir = 3; // PIR sensor Pin
int led = 7;
int distance = 0; // Default distance measured by ultrasonic sensor
// the time when the sensor outputs a low impulse
long unsigned int lowIn;
// the amount of milliseconds the sensor has to be low
// before we assume all motion has stopped
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int calibrationTime = 30;
// Instance creation for the New ping Library
NewPing sonar(trigPin, echoPin, MAX_DISTANCE);
pinMode(pir, INPUT);
pinMode(led, OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
// activation of the pull up resistor for the PIR pin
digitalWrite(pir, HIGH);
// give the sensor some time to calibrate
Serial.print("calibrating sensor ");
for (int i = 0; i < calibrationTime; i++) {
Serial.print(".");
Serial.println(" done");
Serial.println("SENSOR ACTIVE");
delay(50);
//LOOP
if(digitalRead(pir) == HIGH){
digitalWrite(led, HIGH); //the led visualizes the sensors output pin state
if(lockLow){
//makes sure we wait for a transition to LOW before any further output is made:
lockLow = false;
Serial.println("---");
Serial.print("motion detected at ");
Serial.print(millis()/1000);
Serial.println(" sec");
delay(10);
takeLowTime = true;
if(digitalRead(pir) == LOW){
digitalWrite(led, LOW); //the led visualizes the sensors output pin state
if(takeLowTime){
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print("motion ended at "); //output
Serial.print((millis() - pause)/1000);
delay(10);
if(digitalRead(trigPin) == HIGH){
long duration, distance;
digitalWrite(trigPin,HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration=pulseIn(echoPin, HIGH);
distance =(duration/2)/29.1;
Serial.print(distance);
Serial.println("CM");
delay(10);
if((distance<=5))
else if(distance>2)
First do each piece of code separately with different pins, then be sure it works, adding more only makes it harder. Put as much as you can into functions. At that point you should be able to get to work. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
