Hi all.
I am fairly new to Arduino. I was working on a project where I use a GSM SIM900a modem interfaced with an Arduino. The AT commands are sent via the Arduino to the GSM Modem. The problem, however, is that the commands are only sent when I open the Serial Monitor. I have an IR proximity sensor and I would like the AT commands to be sent when the sensor detects an object. I am putting the code for the GSM modem below (I have not yet put in the code for the IR sensor).I want to know how to send the AT commands when the Arduino is hooked up to a battery and not to a PC
#include <SoftwareSerial.h>
SoftwareSerial myGsm(7,8);
float temp;
int tempPin = 0;
myGsm.begin(9600);
myGsm.println("AT+CIPSHUT");
printSerialData();
myGsm.println("AT+CIPMUX=0");
delay(2000);
printSerialData();
myGsm.println("AT+CGATT=1");
printSerialData();
myGsm.println("AT+CSTT=\"bsnlnet\",\"\",\"\"");//setting the APN,2nd parameter empty works for all networks
delay(5000);
printSerialData();
myGsm.println();
myGsm.println("AT+CIICR");
delay(6000);
printSerialData();
myGsm.println("AT+CIFSR"); //init the HTTP request
delay(2000);
printSerialData();
myGsm.println("AT+CIPSTART=\"TCP\",\"122.178.80.228\",\"350\"");
delay(5000);
printSerialData();
delay(5000);
myGsm.println("AT+CIPSEND");
delay(2000);
printSerialData();
sendtemp();
delay(3000);
myGsm.println("AT+CIPCLOSE");
printSerialData();
printSerialData();
void printSerialData()
while(myGsm.available()!=0)
Serial.write(myGsm.read());
void sendtemp()
temp = analogRead(tempPin);
temp = temp * 0.48828125;
Serial.print("TEMPERATURE = ");
Serial.print(temp);
Serial.print("*C");
delay(5000);
myGsm.println(temp);
delay(3000);
printSerialData();
myGsm.write(0x1A);
delay(3000);
printSerialData();
