HOW TO COMPARE 2 HEX VALUES STORE IN THE EEPROM
hey guys,
So i stored Hex values in 4 bytes into the eeprom and i am trying to compare the 2 hex values here is my code
#include <EEPROM.h>
  for (int i = 2; i < 6; i++) {  //
int a=EEPROM.read(i);
    Serial.println(a,HEX);
  for (int i = 6; i < 10; i++) {  //
int v=EEPROM.read(i);
    Serial.print(v,HEX);
  if(a != v){
Serial.print(1);
And the error im getting is
sketch_mar15a:22: error: 'a' was not declared in this scope
   if(a != v){
sketch_mar15a:22: error: 'v' was not declared in this scope
   if(a != v){
exit status 1
You’re variables are local to the for loop and not known outside it
#include <EEPROM.h>
  int a;
  int v;
    a = EEPROM.read(i);
    v = EEPROM.read(i);
  if(a != v){
Serial.print(1);
The assigning of the value to an int is also not correct; your for loop will repeat and at the end only the last value is stored in a or v.
A better approach (based on your code) will be
  bool result = true;
  for (int i = 0; i < 4; i++) {
    int a = EEPROM.read(i + 2);
    Serial.println(a, HEX);
    int v = EEPROM.read(i + 6);
    Serial.print(v, HEX);
    if (a != v)
      // indicate no match
      result = false;
  if(result == false)
    Serial.print(1);
