Arduino 1.0.1 is too old for the Arduino due board.
I Extracted the 1.5.5-r2 sources from git.
While running : /Arduino-1.5.5-r2/build $ ant
I receive the error :
Buildfile: /home/pi/ard55/Arduino-1.5.5-r2/build/build.xml
build:
BUILD FAILED
/home/pi/ard55/Arduino-1.5.5-r2/build/build.xml:55: The following error occurred while executing this line:
Target "${platform}-build" does not exist in the project "Arduino".
Could you inform me if the sources allow build to arm-linux platform (raspberry pi)
if i need to edit a configuration file or set an environment parameter.
devosalain:
A simpler process might be to use an amd64 or i386 version of Debian and either get the latest Arduino package source (apt-get source arduino) along with the build dependencies (apt-get build-dep arduino) and/or attempt to build it according to the build instructions documented somewhere on arduino.cc (I forget where the docs are, somewhere linked from the source download page, probably in a wiki). Then you can work out debian-related issues, such as installing dependency packages, and then finish up with raspbian-specific issues.
the only thing I can think of at the moment is that you don't have all of the necessary build tools or dependencies installed on raspbian.
