My english is poor.
I want to set one master yun and two slave yun.
For example:
When master receive signal from the two slave(button or some thing else) then led on master turned on.
How to do that?
zixzixzix:
For example:
Funny: When the master turns on a led based on a signal from the slave the master is the slave and the slave is the master.
In other words: Master is the one who gives the orders; slave is the one that executes the orders.
zixzixzix:
How to do that?
With the yun there are so many ways. Most of those ways can also be done with other Arduino's. The real yun way is using HTTP.
In other words the MASTER does a HTTP call to the slave who turns on a led based on the HTTP call.
The biggest advantage is that you do not need any additional hardware.
Best regards
Jantje
thank you.
I can see some example between two arduino.
But 3 or more yun used wifi I can not find
