Hi there.
I’m hoping to use a ItsyBitsy M0 to drive a somewhat large number of PWM outputs that control current on a bunch of LED drivers. However, I can’t seem to successfully setup PWMs on all the pins that should allow it… the python fails to compile with a runtime error “all timers in use”.
Is it possible that despite the promised 13 PWM capable pins, only a smaller number can be used simultaneously? - If so, I am happy for 12 of them to share same duty cycle/frequency if that helps?
I need a total of 13 PWM outputs. Using CircuitPython, I have the following pins working (or at least the init is accepted):
D1,D2,D3,D5,D7,D9,D10,D11,D12,D13,A2,SCL - so I am one short!
According to the Adafruit page (Pinouts | Introducing ItsyBitsy M0 Express | Adafruit Learning System) I should also be able to use A1 - however, configuring this results in a “Invalid pin error”.
Other pins such as D4 should also be available for PWM - but the init results in the “all timers in use” error.
Basic sample code attached for reference - any suggestions much apreciated!
sample.txt (422 Bytes)
