How to connect 4wd in one l298n motor board
Hello, everyone. I am new in arduino please notice that when you explain smh, so I have 4wd dc motors like this, and i have one l298n motor driver like this I wanted to connect them but only if i connect 2 motots they work when it is 3 or 4 it doesn't. I tried a lot of examples from this forum and inet but they are kind of useless for my situation Does somebody have idea about it ? Also i have Sensor Shield v4.0 maybe i can connect 2 pair of motors to sensor. Thank you for your help.
My pictures somehow did not appear so my L298N motor driver: https://www.google.com/search?q=l298&rlz=1C1GCEA_enUZ871UZ871&sxsrf=ALeKk005RLvT8NfgZoeHDrPiZbSKeFJe_w:1594982728901&source=lnms&tbm=isch&sa=X&ved=2ahUKEwieiOrXjdTqAhUd5KYKHUTaBvwQ_AUoAXoECA0QAw&biw=1360&bih=625#imgrc=iTQJPE40s458sM DC motor: https://www.google.com/imgres?imgurl=https%3A%2F%2Fae01.alicdn.com%2Fkf%2FHTB1LEh4XZfrK1RkSmLyq6xGApXa9.jpg&imgrefurl=https%3A%2F%2Fwww.aliexpress.com%2Fitem%2F32932380139.html&tbnid=hTXmqaGazX8OeM&vet=12ahUKEwjVrtvsjtTqAhVMZ5oKHVPtAZMQMygMegUIARDAAQ..i&docid=jE58FvPlfMx-cM&w=1000&h=1000&q=dc%20motors%20arduino&hl=en&ved=2ahUKEwjVrtvsjtTqAhVMZ5oKHVPtAZMQMygMegUIARDAAQ Sensor Shield: https://www.google.com/search?q=sensor+shield+v4&rlz=1C1GCEA_enUZ871UZ871&sxsrf=ALeKk02xgk3jUVZrrR5MjQI2ieb2U1BnMw:1594983451199&tbm=isch&source=iu&ictx=1&fir=gRC0tOkgXmmD7M%252CNA0C0GVRraP_LM%252C_&vet=1&usg=AI4_-kRb69lHrpd37lvyUUcSNmDGLua3pA&sa=X&ved=2ahUKEwi90J-wkNTqAhV0wcQBHVoDC-AQ9QEwAHoECAoQHA&biw=1360&bih=625#imgrc=gRC0tOkgXmmD7M
Please read the links below to help you post pictures, links etc. etc.
Could you take a few moments to Learn How To Use The Forum. It will help you get the best out of the forum in the future. Other general help and troubleshooting advice can be found here.
The ancient, extremely inefficient L298 motor driver can't provide much current, and is probably inadequate for your motors. Fortunately, Pololu has a great selection of modern, efficient motor drivers.
You need to know the start/stall current for your motors, in order to select the proper driver.
jremington: You need to know the start/stall current for your motors, in order to select the proper driver.
Thank u for replay, how do i know current for my motor ?
Either find the stall current in the motor data sheet or on the product page for the motor, or [u]carefully[/u] measure the motor winding resistance with your multimeter. Very slowly rotate the motor shaft while making the measurement, and take the lowest reading.
The start/stall current is (motor supply voltage)/(winding resistance)
jremington: Either find the stall current in the motor data sheet or on the product page for the motor, or [u]carefully[/u] measure the motor winding resistance with your multimeter. Very slowly rotate the motor shaft while making the measurement, and take the lowest reading.
Thank you
