my CNC Shield v3 heats up and I want to cool it down. I have a 12V 1.0W fan with 2 pins and I want to use it to circulate air over my stepper motor drivers. What is the proper way to connect the fan to the CNC Shield? If possible I want to use connect it over D12 or D13 so that I can control the speed with code.
I am sending the pulses with my custom code (i.e., I am not using any libraries) for about 24 hours. The steppers are extracted from flat scanners. Since it is a long working time for the steppers, I just want to learn how to use fan from D12 or D13.
Thank you very much jim-p. So, an alternative could be LR7843 Mosfet Control Module? Do you think I can also connect a dc motor driver such as L298N Motor Driver?
Dear jim-p, I have obtained LR7843, I will connect it to the circuit as in your post #7. I believe it will work that way. I can see a diode on the fan side. What should be the properties of that diode?
