Code:
#include "SPI.h"
#define SPI_SCK 13 // SPI clock - must be pin 13
#define SPI_MOSI 11 // SPI data out - must be pin 11
#define SR_LATCH 3 // shift register latch - any non SPI pin
#define SR_BLANK 2 // shift register output enable - any non SPI pin
#define TD1 80 // time delay 1 - 100ms
#define TD2 3000 // time delay 2 - 3 seconds
#define TD3 1000 // time delay 3 - 1 second
#define TD4 20 // time delay 4 - 20ms
#define TD5 400 // time delay 5 - 400ms
#define TD6 120 // time delay 5 - 400ms
#define TD7 100 // time delay 5 - 400ms
// variables used by Inturrupt Service Routine (ISR), must be volatile
volatile byte shiftRegisterRed[64]; // red shift register data, 8 bytes, 1 byte per common anode
volatile byte shiftRegisterGrn[64]; // green shift register data, 8 bytes, 1 byte per common anode
volatile byte shiftRegisterBlu[64]; // blue shift register data, 8 bytes, 1 byte per common anode
volatile byte anodeIndex = 0; // keeps track of which common anode is active
volatile byte anodeLevel[] = { // used by 74HC595N shift register to control the anode multiplexing
B11111110, // This is not an efficient use of variable memory, but what the heck!
B11111101, // at least it shows how the anode multiplexing is done.
B11111011,
B11110111,
B11101111,
B11011111,
B10111111,
B01111111};
byte colours[] = { 1, 2, 4, 3, 6, 5, 7 };
// font definition
char font8x8_basic[95][8] = {
{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, // Ascii ( )
{0x04, 0x04, 0x04, 0x04, 0x04, 0x00, 0x04, 0x00}, // Ascii (!)
{0x14, 0x14, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00}, // Ascii (")
{0x14, 0x14, 0x3E, 0x14, 0x3E, 0x14, 0x14, 0x00}, // Ascii (#)
{0x08, 0x3C, 0x0A, 0x1C, 0x28, 0x1E, 0x08, 0x00}, // Ascii ($)
{0x06, 0x26, 0x10, 0x08, 0x04, 0x32, 0x30, 0x00}, // Ascii (%)
{0x0C, 0x12, 0x0A, 0x04, 0x2A, 0x12, 0x2C, 0x00}, // Ascii (&)
{0x0C, 0x08, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00}, // Ascii (')
{0x08, 0x04, 0x02, 0x02, 0x02, 0x04, 0x08, 0x00}, // Ascii (()
{0x02, 0x04, 0x08, 0x08, 0x08, 0x04, 0x02, 0x00}, // Ascii ())
{0x00, 0x14, 0x08, 0x3E, 0x08, 0x14, 0x00, 0x00}, // Ascii (*)
{0x00, 0x08, 0x08, 0x3E, 0x08, 0x08, 0x00, 0x00}, // Ascii (+)
{0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x04, 0x02}, // Ascii (,)
{0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00}, // Ascii (-)
{0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x06, 0x00}, // Ascii (.)
{0x00, 0x20, 0x10, 0x08, 0x04, 0x02, 0x00, 0x00}, // Ascii (/)
{0x1C, 0x22, 0x32, 0x2A, 0x26, 0x22, 0x1C, 0x00}, // Ascii (0)
{0x08, 0x0C, 0x08, 0x08, 0x08, 0x08, 0x1C, 0x00}, // Ascii (1)
{0x1C, 0x22, 0x20, 0x18, 0x04, 0x02, 0x3E, 0x00}, // Ascii (2)
{0x1C, 0x22, 0x20, 0x18, 0x20, 0x22, 0x1C, 0x00}, // Ascii (3)
{0x10, 0x18, 0x14, 0x12, 0x3E, 0x10, 0x10, 0x00}, // Ascii (4)
{0x3E, 0x02, 0x1E, 0x20, 0x20, 0x22, 0x1C, 0x00}, // Ascii (5)
{0x18, 0x04, 0x02, 0x1E, 0x22, 0x22, 0x1C, 0x00}, // Ascii (6)
{0x3E, 0x20, 0x10, 0x08, 0x04, 0x04, 0x04, 0x00}, // Ascii (7)
{0x1C, 0x22, 0x22, 0x1C, 0x22, 0x22, 0x1C, 0x00}, // Ascii (8)
{0x1C, 0x22, 0x22, 0x3C, 0x20, 0x10, 0x0C, 0x00}, // Ascii (9)
{0x00, 0x0C, 0x0C, 0x00, 0x0C, 0x0C, 0x00, 0x00}, // Ascii (
{0x00, 0x00, 0x0C, 0x0C, 0x00, 0x0C, 0x08, 0x04}, // Ascii (
{0x10, 0x08, 0x04, 0x02, 0x04, 0x08, 0x10, 0x00}, // Ascii (<)
{0x00, 0x00, 0x3E, 0x00, 0x3E, 0x00, 0x00, 0x00}, // Ascii (=)
{0x02, 0x04, 0x08, 0x10, 0x08, 0x04, 0x02, 0x00}, // Ascii (>)
{0x1C, 0x22, 0x20, 0x10, 0x08, 0x00, 0x08, 0x00}, // Ascii (?)
{0x1C, 0x22, 0x20, 0x2C, 0x2A, 0x2A, 0x1C, 0x00}, // Ascii (@)
{0x1C, 0x22, 0x22, 0x3E, 0x22, 0x22, 0x22, 0x00}, // Ascii (A)
{0x1E, 0x22, 0x22, 0x1E, 0x22, 0x22, 0x1E, 0x00}, // Ascii (B)
{0x1C, 0x22, 0x02, 0x02, 0x02, 0x22, 0x1C, 0x00}, // Ascii (C)
{0x0E, 0x12, 0x22, 0x22, 0x22, 0x12, 0x0E, 0x00}, // Ascii (D)
{0x3E, 0x02, 0x02, 0x1E, 0x02, 0x02, 0x3E, 0x00}, // Ascii (E)
{0x3E, 0x02, 0x02, 0x1E, 0x02, 0x02, 0x02, 0x00}, // Ascii (F)
{0x1C, 0x22, 0x02, 0x02, 0x32, 0x22, 0x3C, 0x00}, // Ascii (G)
{0x22, 0x22, 0x22, 0x3E, 0x22, 0x22, 0x22, 0x00}, // Ascii (H)
{0x0E, 0x04, 0x04, 0x04, 0x04, 0x04, 0x0E, 0x00}, // Ascii (I)
{0x38, 0x10, 0x10, 0x10, 0x10, 0x12, 0x0C, 0x00}, // Ascii (J)
{0x22, 0x12, 0x0A, 0x06, 0x0A, 0x12, 0x22, 0x00}, // Ascii (K)
{0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x3E, 0x00}, // Ascii (L)
{0x22, 0x36, 0x2A, 0x2A, 0x22, 0x22, 0x22, 0x00}, // Ascii (M)
{0x22, 0x22, 0x26, 0x2A, 0x32, 0x22, 0x22, 0x00}, // Ascii (N)
{0x1C, 0x22, 0x22, 0x22, 0x22, 0x22, 0x1C, 0x00}, // Ascii (O)
{0x1E, 0x22, 0x22, 0x1E, 0x02, 0x02, 0x02, 0x00}, // Ascii (P)
{0x1C, 0x22, 0x22, 0x22, 0x2A, 0x12, 0x2C, 0x00}, // Ascii (Q)
{0x1E, 0x22, 0x22, 0x1E, 0x0A, 0x12, 0x22, 0x00}, // Ascii (R)
{0x1C, 0x22, 0x02, 0x1C, 0x20, 0x22, 0x1C, 0x00}, // Ascii (S)
{0x3E, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x00}, // Ascii (T)
{0x22, 0x22, 0x22, 0x22, 0x22, 0x22, 0x1C, 0x00}, // Ascii (U)
{0x22, 0x22, 0x22, 0x22, 0x22, 0x14, 0x08, 0x00}, // Ascii (V)
{0x22, 0x22, 0x22, 0x2A, 0x2A, 0x2A, 0x14, 0x00}, // Ascii (W)
{0x22, 0x22, 0x14, 0x08, 0x14, 0x22, 0x22, 0x00}, // Ascii (X)
{0x22, 0x22, 0x14, 0x08, 0x08, 0x08, 0x08, 0x00}, // Ascii (Y)
{0x3E, 0x20, 0x10, 0x08, 0x04, 0x02, 0x3E, 0x00}, // Ascii (Z)
{0x0E, 0x02, 0x02, 0x02, 0x02, 0x02, 0x0E, 0x00}, // Ascii ([)
{0x00, 0x02, 0x04, 0x08, 0x10, 0x20, 0x00, 0x00}, // Ascii ()
{0x0E, 0x08, 0x08, 0x08, 0x08, 0x08, 0x0E, 0x00}, // Ascii (])
{0x08, 0x14, 0x22, 0x00, 0x00, 0x00, 0x00, 0x00}, // Ascii (^)
{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3E}, // Ascii (_)
{0x02, 0x04, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00}, // Ascii (`)
{0x00, 0x00, 0x1C, 0x20, 0x3C, 0x22, 0x3C, 0x00}, // Ascii (a)
{0x02, 0x02, 0x1A, 0x26, 0x22, 0x22, 0x1E, 0x00}, // Ascii (b)
{0x00, 0x00, 0x0C, 0x12, 0x02, 0x12, 0x0C, 0x00}, // Ascii (c)
{0x20, 0x20, 0x2C, 0x32, 0x22, 0x22, 0x3C, 0x00}, // Ascii (d)
{0x00, 0x00, 0x1C, 0x22, 0x3E, 0x02, 0x1C, 0x00}, // Ascii (e)
{0x08, 0x14, 0x04, 0x0E, 0x04, 0x04, 0x04, 0x00}, // Ascii (f)
{0x00, 0x00, 0x3C, 0x22, 0x22, 0x3C, 0x20, 0x1C}, // Ascii (g)
{0x02, 0x02, 0x1A, 0x26, 0x22, 0x22, 0x22, 0x00}, // Ascii (h)
{0x04, 0x00, 0x04, 0x04, 0x04, 0x04, 0x04, 0x00}, // Ascii (i)
{0x08, 0x00, 0x0C, 0x08, 0x08, 0x08, 0x08, 0x06}, // Ascii (j)
{0x02, 0x02, 0x12, 0x0A, 0x06, 0x0A, 0x12, 0x00}, // Ascii (k)
{0x06, 0x04, 0x04, 0x04, 0x04, 0x04, 0x0E, 0x00}, // Ascii (l)
{0x00, 0x00, 0x16, 0x2A, 0x2A, 0x22, 0x22, 0x00}, // Ascii (m)
{0x00, 0x00, 0x1A, 0x16, 0x12, 0x12, 0x12, 0x00}, // Ascii (n)
{0x00, 0x00, 0x0C, 0x12, 0x12, 0x12, 0x0C, 0x00}, // Ascii (o)
{0x00, 0x00, 0x0E, 0x12, 0x12, 0x0E, 0x02, 0x02}, // Ascii (p)
{0x00, 0x00, 0x1C, 0x12, 0x12, 0x1C, 0x10, 0x10}, // Ascii (q)
{0x00, 0x00, 0x14, 0x0C, 0x04, 0x04, 0x04, 0x00}, // Ascii (r)
{0x00, 0x00, 0x1C, 0x02, 0x0C, 0x10, 0x0E, 0x00}, // Ascii (s)
{0x04, 0x04, 0x0E, 0x04, 0x04, 0x04, 0x0C, 0x00}, // Ascii (t)
{0x00, 0x00, 0x12, 0x12, 0x12, 0x12, 0x1C, 0x00}, // Ascii (u)
{0x00, 0x00, 0x22, 0x22, 0x22, 0x14, 0x08, 0x00}, // Ascii (v)
{0x00, 0x00, 0x22, 0x22, 0x2A, 0x2A, 0x14, 0x00}, // Ascii (w)
{0x00, 0x00, 0x22, 0x14, 0x08, 0x14, 0x22, 0x00}, // Ascii (x)
{0x00, 0x00, 0x12, 0x12, 0x12, 0x1C, 0x10, 0x0C}, // Ascii (y)
{0x00, 0x00, 0x3E, 0x10, 0x08, 0x04, 0x3E, 0x00}, // Ascii (z)
{0x08, 0x04, 0x04, 0x02, 0x04, 0x04, 0x08, 0x00}, // Ascii ({)
{0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x00}, // Ascii (|)
{0x02, 0x04, 0x04, 0x08, 0x04, 0x04, 0x02, 0x00}, // Ascii (})
{0x2C, 0x12, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}}; // Ascii (~)
// ~~~ START of SETUP ~~~
// set up IO pins as outputs
pinMode(SPI_SCK, OUTPUT);
pinMode(SPI_MOSI, OUTPUT);
pinMode(SR_LATCH, OUTPUT);
pinMode(SR_BLANK, OUTPUT);
digitalWrite(SR_BLANK, HIGH); // temporarily disable all shift register outputs
digitalWrite(SR_LATCH, LOW); // set shift register latch to initial state
// set up Timer 2 for 8KHz (125uS) interrupt
// code example from Amanda Ghassaei
// http://www.instructables.com/id/Arduino-Timer-Interrupts/?ALLSTEPS
cli(); // stop interrupts
TCCR2A = 0; // set entire TCCR2A register to 0
TCCR2B = 0; // same for TCCR2B
TCNT2 = 0; // initialize counter value to 0
OCR2A = 249; // Set compare match register for 16KHz. Increments calculated as follows:
// Arduino clk frequency 16MHz / (required frequency * Prescaler of 8) - 1, Result must be < 256.
// So for this instance we calculate 16,000,000 / (8,000 * 8) - 1 = 249
TCCR2A |= (1 << WGM21); // turn on CTC mode
TCCR2B |= (1 << CS21); // Set CS21 bit for 8 pre-scalar
TIMSK2 |= (1 << OCIE2A); // enable timer compare interrupt
sei(); // allow interrupts
// end code example from Amanda Ghassaei
// initialise SPI
SPI.setDataMode (SPI_MODE0 ); // mode 0 rising edge of data, keep clock low
SPI.setBitOrder (MSBFIRST ); // most significant bit first
SPI.setClockDivider(SPI_CLOCK_DIV2); // run the data in at 16MHz/2 - 8MHz (max speed)
SPI.begin(); // start up SPI
// initialise Serial Port for de-bugging
Serial.begin (115200 ); // set up serial port for 115200 baud rate
Serial.println("Start"); // display Start in Terminal Window
randomSeed(analogRead(0)); // set random seed
// display some text, only runs once
//displaySomeText("WELCOME TO THE 8x8 RGB LED PANEL TESTING... ", TD5);
// ~~~ END of SETUP ~~~
byte colourIndex = 0;
// ~~~ START of LOOP ~~~
// while (1) { setPixel(0,0,0,1,0,0); setPixel(7,2,0,0,1,0); setPixel(7,4,7,0,0,1); setPixel(0,6,7,1,1,0); }
//while(1){
//drawRectangleFilled(0, 0, 0, 7, 7, 7, 1, 0, 0); // clear the cube
//delay(1000);
//drawRectangleFilled(0, 0, 0, 7, 7, 7, 0, 1, 0); // clear the cube
//delay(1000);
//drawRectangleFilled(0, 0, 0, 7, 7, 7, 0, 0, 1); // clear the cube
//delay(1000);
//drawRectangleFilled(0, 0, 0, 7, 7, 7, 0, 0, 0); // clear the cube
//delay(500000);
// Outline expanding contracting cubes
for (int i = 0; i < 8; i++) {
drawRectangleOutline(0, 0, 0, i, i, i, 1, 0, 0); delay (TD1);
drawRectangleOutline(0, 0, 0, i, i, i, 0, 0, 0);
drawRectangleOutline(i, i, i, 7, 7, 7, 1, 0, 0); delay (TD1);
drawRectangleOutline(i, i, i, 7, 7, 7, 0, 0, 0);
drawRectangleOutline(0, 0, 7 - i, i, i, 7, 0, 0, 1); delay (TD1);
drawRectangleOutline(0, 0, 7 - i, i, i, 7, 0, 0, 0);
drawRectangleOutline(i, i, 0, 7, 7, 7 - i, 0, 0, 1); delay (TD1);
drawRectangleOutline(i, i, 0, 7, 7, 7 - i, 0, 0, 0);
for (int i = 0; i < 8 ; i++) {
drawRectangleOutline(7 - i, 0, 0, 7, i, i, 0, 1, 0); delay (TD1);
drawRectangleOutline(7 - i, 0, 0, 7, i, i, 0, 0, 0);
for (int i = 7; i > -1; i--) {
drawRectangleOutline(0, 7 - i, 7 - i, i, 7, 7, 0, 1, 0); delay (TD1);
drawRectangleOutline(0, 7 - i, 7 - i, i, 7, 7, 0, 0, 0);
drawRectangleOutline(0, 7 - i, 0, i, 7, i, 1, 1, 1); delay (TD1);
drawRectangleOutline(0, 7 - i, 0, i, 7, i, 0, 0, 0);
drawRectangleOutline(i, 0, i, 7, 7 - i, 7, 1, 1, 1); delay (TD1);
drawRectangleOutline(i, 0, i, 7, 7 - i, 7, 0, 0, 0);
// small r cube spin
for (int i = 0; i < 6; i++) {
drawRectangleOutline(i, 0, 0, i + 1, 1, 1, 1, 0, 0); delay (TD1);
drawRectangleOutline(i, 0, 0, i, 1, 1, 0, 0, 0);
drawRectangleOutline(6, i, 0, 7, i + 1, 1, 1, 0, 0); delay (TD1);
drawRectangleOutline(6, i, 0, 7, i, 1, 0, 0, 0);
drawRectangleOutline(6 - i, 6, 0, 7 - i, 7, 1, 1, 0, 0); delay (TD1);
drawRectangleOutline(7 - i, 6, 0, 7 - i, 7, 1, 0, 0, 0);
drawRectangleOutline(0, 6 - i, 0, 1, 7 - i, 1, 1, 0, 0); delay (TD1);
drawRectangleOutline(0, 7 - i, 0, 1, 7 - i, 1, 0, 0, 0);
// small rg cube spin
drawRectangleOutline(6, i, 2, 7, i + 1, 3, 0, 1, 0); delay (TD1);
drawRectangleOutline(6, i, 2, 7, i, 3, 0, 0, 0);
drawRectangleOutline(6 - i, 6, 2, 7 - i, 7, 3, 0, 1, 0); delay (TD1);
drawRectangleOutline(7 - i, 6, 2, 7 - i, 7, 3, 0, 0, 0);
drawRectangleOutline(0, 6 - i, 2, 1, 7 - i, 3, 0, 1, 0); delay (TD1);
drawRectangleOutline(0, 7 - i, 2, 1, 7 - i, 3, 0, 0, 0);
drawRectangleOutline(i, 0, 2, i + 1, 1, 3, 0, 1, 0); delay (TD1);
drawRectangleOutline(i, 0, 2, i, 1, 3, 0, 0, 0);
// small rgb cube spin
drawRectangleOutline(6 - i, 6, 4, 7 - i, 7, 5, 0, 0, 1); delay (TD1);
drawRectangleOutline(7 - i, 6, 4, 7 - i, 7, 5, 0, 0, 0);
drawRectangleOutline(0, 6 - i, 4, 1, 7 - i, 5, 0, 0, 1); delay (TD1);
drawRectangleOutline(0, 7 - i, 4, 1, 7 - i, 5, 0, 0, 0);
drawRectangleOutline(i, 0, 4, i + 1, 1, 5, 0, 0, 1); delay (TD1);
drawRectangleOutline(i, 0, 4, i, 1, 5, 0, 0, 0);
drawRectangleOutline(6, i, 4, 7, i + 1, 5, 0, 0, 1); delay (TD1);
drawRectangleOutline(6, i, 4, 7, i, 5, 0, 0, 0);
// small rgby cube spin
for(int l = 0; l < 1; l++) {
drawRectangleOutline(0, 6 - i, 6, 1, 7 - i, 7, 1, 1, 0); delay (TD1);
drawRectangleOutline(0, 7 - i, 6, 1, 7 - i, 7, 0, 0, 0);
drawRectangleOutline(i, 0, 6, i + 1, 1, 7, 1, 1, 0); delay (TD1);
drawRectangleOutline(i, 0, 6, i, 1, 7, 0, 0, 0);
drawRectangleOutline(6, i, 6, 7, i + 1, 7, 1, 1, 0); delay (TD1);
drawRectangleOutline(6, i, 6, 7, i, 7, 0, 0, 0);
drawRectangleOutline(6 - i, 6, 6, 7 - i, 7, 7, 1, 1, 0); delay (TD1);
drawRectangleOutline(7 - i, 6, 6, 7 - i, 7, 7, 0, 0, 0);
//grow
drawRectangleFilled(0, 0, 0, 1, 1, 1, 1, 0, 0);
drawRectangleFilled(6, 0, 2, 7, 1, 3, 0, 1, 0);
drawRectangleFilled(6, 6, 4, 7, 7, 5, 0, 0, 1);
drawRectangleFilled(0, 6, 6, 1, 7, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 0, 0, 2, 2, 2, 1, 0, 0);
drawRectangleFilled(5, 0, 2, 7, 2, 4, 0, 1, 0);
drawRectangleFilled(5, 5, 3, 7, 7, 5, 0, 0, 1);
drawRectangleFilled(0, 5, 5, 2, 7, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 0, 0, 3, 3, 3, 1, 0, 0);
drawRectangleFilled(4, 0, 2, 7, 3, 5, 0, 1, 0);
drawRectangleFilled(4, 4, 2, 7, 7, 5, 0, 0, 1);
drawRectangleFilled(0, 4, 4, 3, 7, 7, 1, 1, 0); delay (TD7);
// slide g&b into corners
drawRectangleFilled(4,0,2,7,3,2,0,0,0);
drawRectangleFilled(4,4,5,7,7,5,0,0,0);
drawRectangleFilled(4, 0, 3, 7, 3, 6, 0, 1, 0);
drawRectangleFilled(4, 4, 1, 7, 7, 4, 0, 0, 1); delay (TD7);
drawRectangleFilled(4,0,3,7,3,3,0,0,0);
drawRectangleFilled(4,4,4,7,7,4,0,0,0);
drawRectangleFilled(4, 0, 4, 7, 3, 7, 0, 1, 0);
drawRectangleFilled(4, 4, 0, 7, 7, 3, 0, 0, 1); delay (TD7);
// slide rgb&y
// move 1
drawRectangleFilled(0, 0, 0, 0, 3, 3, 0, 0, 0);
drawRectangleFilled(7, 0, 4, 7, 3, 7, 0, 0, 0);
drawRectangleFilled(7, 4, 0, 7, 7, 3, 0, 0, 0);
drawRectangleFilled(0, 4, 4, 0, 7, 7, 0, 0, 0);
drawRectangleFilled(1, 0, 0, 4, 3, 3, 1, 0, 0);
drawRectangleFilled(3, 0, 4, 6, 3, 7, 0, 1, 0);
drawRectangleFilled(3, 4, 0, 6, 7, 3, 0, 0, 1);
drawRectangleFilled(1, 4, 4, 4, 7, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(1, 0, 0, 1, 3, 3, 0, 0, 0);
drawRectangleFilled(6, 0, 4, 6, 3, 7, 0, 0, 0);
drawRectangleFilled(6, 4, 0, 6, 7, 3, 0, 0, 0);
drawRectangleFilled(1, 4, 4, 1, 7, 7, 0, 0, 0);
drawRectangleFilled(2, 0, 0, 5, 3, 3, 1, 0, 0);
drawRectangleFilled(2, 0, 4, 5, 3, 7, 0, 1, 0);
drawRectangleFilled(2, 4, 0, 5, 7, 3, 0, 0, 1);
drawRectangleFilled(2, 4, 4, 5, 7, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(2, 0, 0, 2, 3, 3, 0, 0, 0);
drawRectangleFilled(5, 0, 4, 5, 3, 7, 0, 0, 0);
drawRectangleFilled(5, 4, 0, 5, 7, 3, 0, 0, 0);
drawRectangleFilled(2, 4, 4, 2, 7, 7, 0, 0, 0);
drawRectangleFilled(3, 0, 0, 6, 3, 3, 1, 0, 0);
drawRectangleFilled(1, 0, 4, 4, 3, 7, 0, 1, 0);
drawRectangleFilled(1, 4, 0, 4, 7, 3, 0, 0, 1);
drawRectangleFilled(3, 4, 4, 6, 7, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(3, 0, 0, 3, 3, 3, 0, 0, 0);
drawRectangleFilled(4, 0, 4, 4, 3, 7, 0, 0, 0);
drawRectangleFilled(4, 4, 0, 4, 7, 3, 0, 0, 0);
drawRectangleFilled(3, 4, 4, 3, 7, 7, 0, 0, 0);
drawRectangleFilled(4, 0, 0, 7, 3, 3, 1, 0, 0);
drawRectangleFilled(0, 0, 4, 3, 3, 7, 0, 1, 0);
drawRectangleFilled(0, 4, 0, 3, 7, 3, 0, 0, 1);
drawRectangleFilled(4, 4, 4, 7, 7, 7, 1, 1, 0); delay (TD7);
// move 2
drawRectangleFilled(4, 0, 0, 7, 3, 0, 0, 0, 0);
drawRectangleFilled(0, 0, 7, 3, 3, 7, 0, 0, 0);
drawRectangleFilled(0, 4, 0, 3, 7, 0, 0, 0, 0);
drawRectangleFilled(4, 4, 7, 7, 7, 7, 0, 0, 0);
drawRectangleFilled(4, 0, 1, 7, 3, 4, 1, 0, 0);
drawRectangleFilled(0, 0, 3, 3, 3, 6, 0, 1, 0);
drawRectangleFilled(0, 4, 1, 3, 7, 4, 0, 0, 1);
drawRectangleFilled(4, 4, 3, 7, 7, 6, 1, 1, 0); delay (TD7);
drawRectangleFilled(4, 0, 1, 7, 3, 1, 0, 0, 0);
drawRectangleFilled(0, 0, 6, 3, 3, 6, 0, 0, 0);
drawRectangleFilled(0, 4, 1, 3, 7, 1, 0, 0, 0);
drawRectangleFilled(4, 4, 6, 7, 7, 6, 0, 0, 0);
drawRectangleFilled(4, 0, 2, 7, 3, 5, 1, 0, 0);
drawRectangleFilled(0, 0, 2, 3, 3, 5, 0, 1, 0);
drawRectangleFilled(0, 4, 2, 3, 7, 5, 0, 0, 1);
drawRectangleFilled(4, 4, 2, 7, 7, 5, 1, 1, 0); delay (TD7);
drawRectangleFilled(4, 0, 2, 7, 3, 2, 0, 0, 0);
drawRectangleFilled(0, 0, 5, 3, 3, 5, 0, 0, 0);
drawRectangleFilled(0, 4, 2, 3, 7, 2, 0, 0, 0);
drawRectangleFilled(4, 4, 5, 7, 7, 5, 0, 0, 0);
drawRectangleFilled(4, 0, 3, 7, 3, 6, 1, 0, 0);
drawRectangleFilled(0, 0, 1, 3, 3, 4, 0, 1, 0);
drawRectangleFilled(0, 4, 3, 3, 7, 6, 0, 0, 1);
drawRectangleFilled(4, 4, 1, 7, 7, 4, 1, 1, 0); delay (TD7);
drawRectangleFilled(4, 0, 3, 7, 3, 3, 0, 0, 0);
drawRectangleFilled(0, 0, 4, 3, 3, 4, 0, 0, 0);
drawRectangleFilled(0, 4, 3, 3, 7, 3, 0, 0, 0);
drawRectangleFilled(4, 4, 4, 7, 7, 4, 0, 0, 0);
drawRectangleFilled(4, 0, 4, 7, 3, 7, 1, 0, 0);
drawRectangleFilled(0, 0, 0, 3, 3, 3, 0, 1, 0);
drawRectangleFilled(0, 4, 4, 3, 7, 7, 0, 0, 1);
drawRectangleFilled(4, 4, 0, 7, 7, 3, 1, 1, 0); delay (TD7);
// move 3
drawRectangleFilled(3, 0, 4, 6, 3, 7, 1, 0, 0);
drawRectangleFilled(1, 0, 0, 4, 3, 3, 0, 1, 0);
drawRectangleFilled(1, 4, 4, 4, 7, 7, 0, 0, 1);
drawRectangleFilled(3, 4, 0, 6, 7, 3, 1, 1, 0); delay (TD7);
drawRectangleFilled(2, 0, 4, 5, 3, 7, 1, 0, 0);
drawRectangleFilled(2, 0, 0, 5, 3, 3, 0, 1, 0);
drawRectangleFilled(2, 4, 4, 5, 7, 7, 0, 0, 1);
drawRectangleFilled(2, 4, 0, 5, 7, 3, 1, 1, 0); delay (TD7);
drawRectangleFilled(1, 0, 4, 4, 3, 7, 1, 0, 0);
drawRectangleFilled(3, 0, 0, 6, 3, 3, 0, 1, 0);
drawRectangleFilled(3, 4, 4, 6, 7, 7, 0, 0, 1);
drawRectangleFilled(1, 4, 0, 4, 7, 3, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 0, 4, 3, 3, 7, 1, 0, 0);
drawRectangleFilled(4, 0, 0, 7, 3, 3, 0, 1, 0);
drawRectangleFilled(4, 4, 4, 7, 7, 7, 0, 0, 1);
drawRectangleFilled(0, 4, 0, 3, 7, 3, 1, 1, 0); delay (TD7);
// move 4
drawRectangleFilled(0, 0, 3, 3, 3, 6, 1, 0, 0);
drawRectangleFilled(4, 0, 1, 7, 3, 4, 0, 1, 0);
drawRectangleFilled(4, 4, 3, 7, 7, 6, 0, 0, 1);
drawRectangleFilled(0, 4, 1, 3, 7, 4, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 0, 2, 3, 3, 5, 1, 0, 0);
drawRectangleFilled(0, 4, 2, 3, 7, 5, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 0, 1, 3, 3, 4, 1, 0, 0);
drawRectangleFilled(0, 4, 3, 3, 7, 6, 1, 1, 0); delay (TD7);
// move 1
drawRectangleFilled(0, 0, 0, 3, 0, 3, 0, 0, 0);
drawRectangleFilled(4, 0, 4, 7, 0, 7, 0, 0, 0);
drawRectangleFilled(4, 7, 0, 7, 7, 3, 0, 0, 0);
drawRectangleFilled(0, 7, 4, 3, 7, 7, 0, 0, 0);
drawRectangleFilled(0, 1, 0, 3, 4, 3, 1, 0, 0);
drawRectangleFilled(4, 1, 4, 7, 4, 7, 0, 1, 0);
drawRectangleFilled(4, 3, 0, 7, 6, 3, 0, 0, 1);
drawRectangleFilled(0, 3, 4, 3, 6, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 1, 0, 3, 1, 3, 0, 0, 0);
drawRectangleFilled(4, 1, 4, 7, 1, 7, 0, 0, 0);
drawRectangleFilled(4, 6, 0, 7, 6, 3, 0, 0, 0);
drawRectangleFilled(0, 6, 4, 3, 6, 7, 0, 0, 0);
drawRectangleFilled(0, 2, 0, 3, 5, 3, 1, 0, 0);
drawRectangleFilled(4, 2, 4, 7, 5, 7, 0, 1, 0);
drawRectangleFilled(4, 2, 0, 7, 5, 3, 0, 0, 1);
drawRectangleFilled(0, 2, 4, 3, 5, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 2, 0, 3, 2, 3, 0, 0, 0);
drawRectangleFilled(4, 2, 4, 7, 2, 7, 0, 0, 0);
drawRectangleFilled(4, 5, 0, 7, 5, 3, 0, 0, 0);
drawRectangleFilled(0, 5, 4, 3, 5, 7, 0, 0, 0);
drawRectangleFilled(0, 3, 0, 3, 6, 3, 1, 0, 0);
drawRectangleFilled(4, 3, 4, 7, 6, 7, 0, 1, 0);
drawRectangleFilled(4, 1, 0, 7, 4, 3, 0, 0, 1);
drawRectangleFilled(0, 1, 4, 3, 4, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 3, 0, 3, 3, 3, 0, 0, 0);
drawRectangleFilled(4, 3, 4, 7, 3, 7, 0, 0, 0);
drawRectangleFilled(4, 4, 0, 7, 4, 3, 0, 0, 0);
drawRectangleFilled(0, 4, 4, 3, 4, 7, 0, 0, 0);
drawRectangleFilled(0, 4, 0, 3, 7, 3, 1, 0, 0);
drawRectangleFilled(4, 4, 4, 7, 7, 7, 0, 1, 0);
drawRectangleFilled(4, 0, 0, 7, 3, 3, 0, 0, 1);
drawRectangleFilled(0, 0, 4, 3, 3, 7, 1, 1, 0); delay (TD7);
// move 2
drawRectangleFilled(0, 4, 0, 0, 7, 7, 0, 0, 0);
drawRectangleFilled(7, 4, 4, 7, 7, 7, 0, 0, 0);
drawRectangleFilled(7, 0, 0, 7, 3, 3, 0, 0, 0);
drawRectangleFilled(0, 0, 4, 0, 3, 7, 0, 0, 0);
drawRectangleFilled(1, 4, 0, 4, 7, 3, 1, 0, 0);
drawRectangleFilled(3, 4, 4, 6, 7, 7, 0, 1, 0);
drawRectangleFilled(3, 0, 0, 6, 3, 3, 0, 0, 1);
drawRectangleFilled(1, 0, 4, 4, 3, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(1, 4, 0, 1, 7, 7, 0, 0, 0);
drawRectangleFilled(6, 4, 4, 6, 7, 7, 0, 0, 0);
drawRectangleFilled(6, 0, 0, 6, 3, 3, 0, 0, 0);
drawRectangleFilled(1, 0, 4, 1, 3, 7, 0, 0, 0);
drawRectangleFilled(2, 4, 0, 5, 7, 3, 1, 0, 0);
drawRectangleFilled(2, 4, 4, 5, 7, 7, 0, 1, 0);
drawRectangleFilled(2, 0, 0, 5, 3, 3, 0, 0, 1);
drawRectangleFilled(2, 0, 4, 5, 3, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(2, 4, 0, 2, 7, 7, 0, 0, 0);
drawRectangleFilled(5, 4, 4, 5, 7, 7, 0, 0, 0);
drawRectangleFilled(5, 0, 0, 5, 3, 3, 0, 0, 0);
drawRectangleFilled(2, 0, 4, 2, 3, 7, 0, 0, 0);
drawRectangleFilled(3, 4, 0, 6, 7, 3, 1, 0, 0);
drawRectangleFilled(1, 4, 4, 4, 7, 7, 0, 1, 0);
drawRectangleFilled(1, 0, 0, 4, 3, 3, 0, 0, 1);
drawRectangleFilled(3, 0, 4, 6, 3, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(3, 4, 0, 3, 7, 7, 0, 0, 0);
drawRectangleFilled(4, 4, 4, 4, 7, 7, 0, 0, 0);
drawRectangleFilled(4, 0, 0, 4, 3, 3, 0, 0, 0);
drawRectangleFilled(3, 0, 4, 3, 3, 7, 0, 0, 0);
drawRectangleFilled(4, 4, 0, 7, 7, 3, 1, 0, 0);
drawRectangleFilled(0, 4, 4, 3, 7, 7, 0, 1, 0);
drawRectangleFilled(0, 0, 0, 3, 3, 3, 0, 0, 1);
drawRectangleFilled(4, 0, 4, 7, 3, 7, 1, 1, 0); delay (TD7);
// move 3
drawRectangleFilled(4, 3, 0, 7, 6, 3, 1, 0, 0);
drawRectangleFilled(0, 3, 4, 3, 6, 7, 0, 1, 0);
drawRectangleFilled(0, 1, 0, 3, 4, 3, 0, 0, 1);
drawRectangleFilled(4, 1, 4, 7, 4, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(4, 2, 0, 7, 5, 3, 1, 0, 0);
drawRectangleFilled(0, 2, 4, 3, 5, 7, 0, 1, 0);
drawRectangleFilled(0, 2, 0, 3, 5, 3, 0, 0, 1);
drawRectangleFilled(4, 2, 4, 7, 5, 7, 1, 1, 0); delay (TD7);
drawRectangleFilled(4, 1, 0, 7, 4, 3, 1, 0, 0);
drawRectangleFilled(0, 1, 4, 3, 4, 7, 0, 1, 0);
drawRectangleFilled(0, 3, 0, 3, 6, 3, 0, 0, 1);
drawRectangleFilled(4, 3, 4, 7, 6, 7, 1, 1, 0); delay (TD7);
// move 4
drawRectangleFilled(0, 4, 0, 0, 7, 3, 0, 0, 0);
drawRectangleFilled(1, 4, 0, 1, 7, 3, 0, 0, 0);
drawRectangleFilled(2, 4, 0, 2, 7, 3, 0, 0, 0);
drawRectangleFilled(3, 4, 0, 3, 7, 3, 0, 0, 0);
// move 1
drawRectangleFilled(0, 0, 0, 3, 3, 0, 0, 0, 0);
drawRectangleFilled(4, 0, 7, 7, 3, 7, 0, 0, 0);
drawRectangleFilled(4, 4, 0, 7, 7, 0, 0, 0, 0);
drawRectangleFilled(0, 4, 7, 3, 7, 7, 0, 0, 0);
drawRectangleFilled(0, 0, 1, 3, 3, 1, 0, 0, 0);
drawRectangleFilled(4, 0, 6, 7, 3, 6, 0, 0, 0);
drawRectangleFilled(4, 4, 1, 7, 7, 1, 0, 0, 0);
drawRectangleFilled(0, 4, 6, 3, 7, 6, 0, 0, 0);
drawRectangleFilled(0, 0, 2, 3, 3, 2, 0, 0, 0);
drawRectangleFilled(4, 0, 5, 7, 3, 5, 0, 0, 0);
drawRectangleFilled(4, 4, 2, 7, 7, 2, 0, 0, 0);
drawRectangleFilled(0, 4, 5, 3, 7, 5, 0, 0, 0);
drawRectangleFilled(0, 0, 3, 3, 3, 3, 0, 0, 0);
drawRectangleFilled(4, 0, 4, 7, 3, 4, 0, 0, 0);
drawRectangleFilled(4, 4, 3, 7, 7, 3, 0, 0, 0);
drawRectangleFilled(0, 4, 4, 3, 7, 4, 0, 0, 0);
// move 2
drawRectangleFilled(0, 0, 4, 3, 0, 7, 0, 0, 0);
drawRectangleFilled(4, 0, 0, 7, 0, 4, 0, 0, 0);
drawRectangleFilled(4, 7, 4, 7, 7, 7, 0, 0, 0);
drawRectangleFilled(0, 7, 0, 3, 7, 3, 0, 0, 0);
drawRectangleFilled(0, 1, 4, 3, 4, 7, 1, 0, 0);
drawRectangleFilled(4, 1, 0, 7, 4, 3, 0, 1, 0);
drawRectangleFilled(4, 3, 4, 7, 6, 7, 0, 0, 1);
drawRectangleFilled(0, 3, 0, 3, 6, 3, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 1, 4, 3, 1, 7, 0, 0, 0);
drawRectangleFilled(4, 1, 0, 7, 1, 4, 0, 0, 0);
drawRectangleFilled(4, 6, 4, 7, 6, 7, 0, 0, 0);
drawRectangleFilled(0, 6, 0, 3, 6, 3, 0, 0, 0);
drawRectangleFilled(0, 2, 4, 3, 5, 7, 1, 0, 0);
drawRectangleFilled(4, 2, 0, 7, 5, 3, 0, 1, 0);
drawRectangleFilled(4, 2, 4, 7, 5, 7, 0, 0, 1);
drawRectangleFilled(0, 2, 0, 3, 5, 3, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 2, 4, 3, 2, 7, 0, 0, 0);
drawRectangleFilled(4, 2, 0, 7, 2, 4, 0, 0, 0);
drawRectangleFilled(4, 5, 4, 7, 5, 7, 0, 0, 0);
drawRectangleFilled(0, 5, 0, 3, 5, 3, 0, 0, 0);
drawRectangleFilled(0, 3, 4, 3, 6, 7, 1, 0, 0);
drawRectangleFilled(4, 3, 0, 7, 6, 3, 0, 1, 0);
drawRectangleFilled(4, 1, 4, 7, 4, 7, 0, 0, 1);
drawRectangleFilled(0, 1, 0, 3, 4, 3, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 3, 4, 3, 3, 7, 0, 0, 0);
drawRectangleFilled(4, 3, 0, 7, 3, 4, 0, 0, 0);
drawRectangleFilled(4, 4, 4, 7, 4, 7, 0, 0, 0);
drawRectangleFilled(0, 4, 0, 3, 4, 3, 0, 0, 0);
drawRectangleFilled(0, 4, 4, 3, 7, 7, 1, 0, 0);
drawRectangleFilled(4, 4, 0, 7, 7, 3, 0, 1, 0);
drawRectangleFilled(4, 0, 4, 7, 3, 7, 0, 0, 1);
drawRectangleFilled(0, 0, 0, 3, 3, 3, 1, 1, 0); delay (TD7);
// move 3
drawRectangleFilled(0, 4, 3, 3, 7, 6, 1, 0, 0);
drawRectangleFilled(4, 4, 1, 7, 7, 4, 0, 1, 0);
drawRectangleFilled(4, 0, 3, 7, 3, 6, 0, 0, 1);
drawRectangleFilled(0, 0, 1, 3, 3, 4, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 4, 2, 3, 7, 5, 1, 0, 0);
drawRectangleFilled(4, 4, 2, 7, 7, 5, 0, 1, 0);
drawRectangleFilled(4, 0, 2, 7, 3, 5, 0, 0, 1);
drawRectangleFilled(0, 0, 2, 3, 3, 5, 1, 1, 0); delay (TD7);
drawRectangleFilled(0, 4, 1, 3, 7, 4, 1, 0, 0);
drawRectangleFilled(4, 4, 3, 7, 7, 6, 0, 1, 0);
drawRectangleFilled(4, 0, 1, 7, 3, 4, 0, 0, 1);
drawRectangleFilled(0, 0, 3, 3, 3, 6, 1, 1, 0); delay (TD7);
// move 4
drawRectangleFilled(4, 0, 0, 7, 0, 3, 0, 0, 0);
drawRectangleFilled(4, 1, 0, 7, 1, 3, 0, 0, 0);
drawRectangleFilled(4, 2, 0, 7, 2, 3, 0, 0, 0);
drawRectangleFilled(4, 3, 0, 7, 3, 3, 0, 0, 0);
// for (int x = 0; x < 8; x++) {
// for (int y = 0; y < 8; y++) {
// delay(50);
// for (int z = 7; z > -1; z--) {
// setPixel(x, y, z, 1, 1, 1);
// delay(50);
// for (int z = 0; z < 8; z++) {
// setPixel(y, z, x, 0, 0, 0);
// delay(50);
// setPixel(z, x, y, 1, 0, 1);
yzPlaneFill(i, colours[0] );
delay(TD1);
yzPlaneFill(i, 0); }
for (int i = 6; i > -1; i--) {
delay(TD1);
xyPlaneFill(i, colours[1] );
delay(TD1);
xyPlaneFill(i, 0); }
delay(TD1);
xzPlaneFill(i, colours[2] );
delay(TD1);
xzPlaneFill(i, 0); }
delay(TD1);
delay(TD1);
yzPlaneFill(i, 0);
// for (int i = 6; i > 0; i--) {
// yzPlaneFill(i, colours[0] );
// xyPlaneFill(i, colours[1] );
// delay(TD1);
// yzPlaneFill(i, 0);
// xyPlaneFill(i, 0); }
delay(TD1);
yzPlaneFill(i, 0);
// xzPlaneFill(i, colours[2] );
// delay(TD1);
// xzPlaneFill(i, 0); }
delay(TD1);
xyPlaneFill(i, 0);
// delay(TD1);
delay(TD1);
yzPlaneFill(i, 0);
xyPlaneFill(i, 0);
delay(TD1);
yzPlaneFill(i, 0);
xyPlaneFill(i, 0);
drawRectangleSides(3, 3, 3, 4, 4, 4, 1, 0, 0);
drawRectangleSides(2, 2, 2, 5, 5, 5, 0, 0, 0);
drawRectangleSides(1, 1, 1, 6, 6, 6, 0, 0, 0);
drawRectangleSides(0, 0, 0, 7, 7, 7, 0, 0, 0); delay(TD6);
drawRectangleSides(2, 2, 2, 5, 5, 5, 1, 0, 0);
drawRectangleSides(1, 1, 1, 6, 6, 6, 1, 0, 0);
drawRectangleSides(3, 3, 3, 4, 4, 4, 0, 1, 0);
drawRectangleSides(0, 0, 0, 7, 7, 7, 1, 0, 0); delay(TD6);
for (int count= 0; count < 2; count++) {
drawRectangleSides(2, 2, 2, 5, 5, 5, 0, 1, 0);
drawRectangleSides(1, 1, 1, 6, 6, 6, 0, 1, 0);
drawRectangleSides(3, 3, 3, 4, 4, 4, 0, 0, 1);
drawRectangleSides(0, 0, 0, 7, 7, 7, 0, 1, 0); delay(TD6);
drawRectangleSides(2, 2, 2, 5, 5, 5, 0, 0, 1);
drawRectangleSides(1, 1, 1, 6, 6, 6, 0, 0, 1);
drawRectangleSides(3, 3, 3, 4, 4, 4, 1, 0, 1);
drawRectangleSides(0, 0, 0, 7, 7, 7, 0, 0, 1); delay(TD6);
drawRectangleSides(2, 2, 2, 5, 5, 5, 1, 0, 1);
drawRectangleSides(1, 1, 1, 6, 6, 6, 1, 0, 1);
drawRectangleSides(3, 3, 3, 4, 4, 4, 1, 1, 0);
drawRectangleSides(0, 0, 0, 7, 7, 7, 1, 0, 1); delay(TD6);
drawRectangleSides(2, 2, 2, 5, 5, 5, 1, 1, 0);
drawRectangleSides(1, 1, 1, 6, 6, 6, 1, 1, 0);
drawRectangleSides(3, 3, 3, 4, 4, 4, 0, 1, 1);
drawRectangleSides(0, 0, 0, 7, 7, 7, 1, 1, 0); delay(TD6);
drawRectangleSides(2, 2, 2, 5, 5, 5, 0, 1, 1);
drawRectangleSides(1, 1, 1, 6, 6, 6, 0, 1, 1);
drawRectangleSides(3, 3, 3, 4, 4, 4, 1, 1, 1);
drawRectangleSides(0, 0, 0, 7, 7, 7, 0, 1, 1); delay(TD6);
drawRectangleSides(2, 2, 2, 5, 5, 5, 1, 1, 1);
drawRectangleSides(1, 1, 1, 6, 6, 6, 1, 1, 1);
drawRectangleSides(0, 0, 0, 7, 7, 7, 1, 1, 1); delay(TD6);
drawRectangleSides(3, 3, 3, 4, 4, 4, 0, 0, 0);
String f= "fuck";
displaySomeText(f, 10);
loop();
// ~~~ END of LOOP ~~~
// ~~~ START of DISPLAY SOME TEXT ~~~
// takes a string of text and displays it one character at a time with each new word a random colour
void displaySomeText(String someText, int pauseTime) {
byte aChar; // grabs one character at a time from the message string
int stringLen; // length of text message
byte myColour; // random colour
uint16_t charScroll[8] = {0x0000, 0x0000, // 8 row 16 bit display buffer
0x0000, 0x0000, // 8x8 panel maps to the 8 MSB's
0x0000, 0x0000, // aChar loads into 8 LSB's
0x0000, 0x0000}; // bit shifts to the left to scroll new char in and old char out
stringLen = someText.length(); // find length of text message
myColour = random(7) + 1; // select first random colour
for(int i = 0; i < stringLen; i++){ // loop for as many characters in text message
aChar = int(someText[i] - 0x20); // get ascii value for each character and remove offset
// load a character into buffers 8 Least Significant Bits
for(int j = 0; j < 8; j++){
charScroll[j] += font8x8_basic[aChar][7 - j] << 8;
// shift buffer left one bit then load shift registers with the buffers 8 Most Significant Bits
for(int j = 0; j < 7; j++){
for(int k = 0; k < 8; k++){
charScroll[k] = charScroll[k] >> 1;
if(myColour & 0x01) {shiftRegisterRed[k] = 0x00ff & charScroll[k];} else {shiftRegisterRed[k] = 0;}
if(myColour & 0x02) {shiftRegisterGrn[k] = 0x00ff & charScroll[k];} else {shiftRegisterGrn[k] = 0;}
if(myColour & 0x04) {shiftRegisterBlu[k] = 0x00ff & charScroll[k];} else {shiftRegisterBlu[k] = 0;}
delay(60);
// if a space is detected chose a new random colour for the next word
if(aChar == 0x00){ myColour = random(7) + 1; }
// ~~~ END of DISPLAY SOME TEXT ~~~
//String f= "fuck";
//displaySomeText(f, 10);
// ~~~ START Draw Rectanle Outline ~~~
// draw a 3d wireframe rectangle
void drawRectangleOutline(int xMin, int yMin , int zMin, int xMax, int yMax, int zMax, boolean red, boolean grn, boolean blu) {
for (int x = xMin; x < xMax + 1; x++) {
setPixel( x, yMin, zMin, red, grn, blu);
setPixel( x, yMin, zMax, red, grn, blu);
setPixel( x, yMax, zMax, red, grn, blu);
setPixel( x, yMax, zMin, red, grn, blu);
for (int y = yMin; y < yMax + 1; y++) {
setPixel( xMin, y, zMin, red, grn, blu);
setPixel( xMin, y, zMax, red, grn, blu);
setPixel( xMax, y, zMax, red, grn, blu);
setPixel( xMax, y, zMin, red, grn, blu);
for (int z = zMin; z < zMax + 1; z++) {
setPixel( xMin, yMin, z, red, grn, blu);
setPixel( xMin, yMax, z, red, grn, blu);
setPixel( xMax, yMax, z, red, grn, blu);
setPixel( xMax, yMin, z, red, grn, blu);
// ~~~ END Draw Rectanle Outline ~~~
// ~~~ START Draw Rectanle Sides ~~~
// draw a 3d rectangle filled sides
void drawRectangleSides(int xMin, int yMin , int zMin, int xMax, int yMax, int zMax, boolean red, boolean grn, boolean blu) {
setPixel( x, y, zMin, red, grn, blu);
setPixel( x, y, zMax, red, grn, blu);
setPixel( xMin, y, z, red, grn, blu);
setPixel( xMax, y, z, red, grn, blu);
setPixel( x, yMin, z, red, grn, blu);
setPixel( x, yMax, z, red, grn, blu);
// ~~~ END Draw Rectanle Sides ~~~
// ~~~ START Draw Rectanle Filled ~~~
void drawRectangleFilled(int xMin, int yMin , int zMin, int xMax, int yMax, int zMax, boolean red, boolean grn, boolean blu) {
setPixel(x, y, z, red, grn, blu);
// ~~~ END Draw Rectanle Filled ~~~
// ~~~ Start Flood Fill ~~~
// fills entire panel with chosen colour via direct manipulation of the shift register arrays
// (much faster than setting individual pixels)
void floodFill(boolean red, boolean grn, boolean blu) {
for ( int indexY = 0; indexY < 8; indexY++ ) {
if(red == 1) {shiftRegisterRed[indexY] = B11111111;} else {shiftRegisterRed[indexY] = B00000000;}
if(grn == 1) {shiftRegisterGrn[indexY] = B11111111;} else {shiftRegisterGrn[indexY] = B00000000;}
if(blu == 1) {shiftRegisterBlu[indexY] = B11111111;} else {shiftRegisterBlu[indexY] = B00000000;}
// ~~~ END of Flood Fill ~~~
// ~~~ Start Fill YZ Axis Plane ~~~
void yzPlaneFill(byte xIndex, byte colour) {
boolean red = colour & B00000001;
boolean grn = colour & B00000010;
boolean blu = colour & B00000100;
Serial.print("red = ");
Serial.print(red);
// test column index is within boundary
if ( xIndex < 0) xIndex = 0;
if ( xIndex > 7) xIndex = 7;
// set the register arrays using bit manipulation
for ( int i = 0; i < 8; i++ ) {
for ( int j = 0; j < 8; j++ ) {
if ( red == 0 ) shiftRegisterRed[i + (j * 8)] &= ~(1 << xIndex); else shiftRegisterRed[i + (j * 8)] |= (1 << xIndex);
if ( grn == 0 ) shiftRegisterGrn[i + (j * 8)] &= ~(1 << xIndex); else shiftRegisterGrn[i + (j * 8)] |= (1 << xIndex);
if ( blu == 0 ) shiftRegisterBlu[i + (j * 8)] &= ~(1 << xIndex); else shiftRegisterBlu[i + (j * 8)] |= (1 << xIndex);
// ~~~ END Fill YZ Axis Plane ~~~
// ~~~ Start Fill XZ Axis Plane ~~~
void xzPlaneFill(byte yIndex, byte colour) {
Serial.print(red);
if ( yIndex < 0 ) yIndex = 0;
if ( yIndex > 7 ) yIndex = 7;
if(red == 0) {shiftRegisterRed[i + (yIndex * 8)] = 0;} else {shiftRegisterRed[i + (yIndex * 8)] = 255;}
if(grn == 0) {shiftRegisterGrn[i + (yIndex * 8)] = 0;} else {shiftRegisterGrn[i + (yIndex * 8)] = 255;}
if(blu == 0) {shiftRegisterBlu[i + (yIndex * 8)] = 0;} else {shiftRegisterBlu[i + (yIndex * 8)] = 255;}
// ~~~ END Fill XZ Axis Plane ~~~
void xyPlaneFill(byte zIndex, byte colour) {
if ( zIndex < 0 ) zIndex = 0;
if ( zIndex > 7 ) zIndex = 7;
if ( red == 0 ) {shiftRegisterRed[zIndex + ( 8 * i)] = 0;} else {shiftRegisterRed[zIndex + ( 8 * i)] = 255;}
if ( grn == 0 ) {shiftRegisterGrn[zIndex + ( 8 * i)] = 0;} else {shiftRegisterGrn[zIndex + ( 8 * i)] = 255;}
if ( blu == 0 ) {shiftRegisterBlu[zIndex + ( 8 * i)] = 0;} else {shiftRegisterBlu[zIndex + ( 8 * i)] = 255;}
// ~~~ END of Fill Row ~~~
// ~~~ Start Set Pixel ~~~
// take a pixels x & y co-ordinate, R, G & B binary values and assigns to appropriate shift register bit
void setPixel(byte pixelX, byte pixelY, byte pixelZ, boolean red, boolean grn, boolean blu) {
// test pixel x & co-ordinates are within boundary
if(pixelX < 0) pixelX = 0;
if(pixelX > 7) pixelX = 7;
if(pixelY < 0) pixelY = 0;
if(pixelY > 7) pixelY = 7;
if(pixelZ < 0) pixelZ = 0;
if(pixelZ > 7) pixelZ = 7;
// set appropriate registers using bit manipulation.
// just Google 'bit shifting in c'
// to find tutorials and explanations of the following:
if(red == 1) shiftRegisterRed[(8 * pixelY) + (7 - pixelZ)] |= (1 << pixelX); // if red is 1 set appropriate bit within appropriate red byte to 1
else shiftRegisterRed[(8 * pixelY) + (7 - pixelZ)] &= ~(1 << pixelX); // otherwise set appropriate bit within appropriate red byte to 0
if(grn == 1) shiftRegisterGrn[(8 * pixelY) + (7 - pixelZ)] |= (1 << pixelX); // if grn is 1 set appropriate bit within appropriate grn byte to 1
else shiftRegisterGrn[(8 * pixelY) + (7 - pixelZ)] &= ~(1 << pixelX); // otherwise set appropriate bit within appropriate grn byte to 0
if(blu == 1) shiftRegisterBlu[(8 * pixelY) + (7 - pixelZ)] |= (1 << pixelX); // if blu is 1 set appropriate bit within appropriate blu byte to 1
else shiftRegisterBlu[(8 * pixelY) + (7 - pixelZ)] &= ~(1 << pixelX); // otherwise set appropriate bit within appropriate blu byte to 0
// ~~~ END Set Pixel ~~~
// ~~~ START 0f ISR ~~~
// Updates the panel. Called every 125uS (8KHz), each row is lit for 1/8th of the time (1KHz)
ISR(TIMER2_COMPA_vect) {
PORTD |= (1 << SR_BLANK); // temporarely disable the SR outputs
SPI.transfer(shiftRegisterRed[i + anodeIndex * 8]); // send the red SR byte for the given anode level
SPI.transfer(shiftRegisterGrn[i + anodeIndex * 8]); // send the grn SR byte for the given anode level
SPI.transfer(shiftRegisterBlu[i + anodeIndex * 8]); // send the blu SR byte for the given anode level
SPI.transfer(anodeLevel[anodeIndex]); // send the anode multiplex byte
anodeIndex = (anodeIndex + 1) % 8; // incrument anode index ready for next ISR
PORTD |= (1 << SR_LATCH); // set latch pin LOW
PORTD &= ~(1 << SR_LATCH); // set latch pin HIGH - SR outputs now have new data
PORTD &= ~(1 << SR_BLANK); // re-enable the SR outputs
// ~~~ END of ISR ~~~
