Thanks for your suggestion.
However, that doesn't work. I think it is due to wrong wiring.
So, I tried to wire it as an Anode instead:
Blue wire: 5 V
Yellow wire: PWM 8
Red wire: PWM 10
Black wire: PWM 12
And now this code works:
digitalWrite(redPin, LOW); // RED on
digitalWrite(greenPin, HIGH);
digitalWrite(bluePin, HIGH);
delay(200);
digitalWrite(redPin, HIGH); // GREEN on
digitalWrite(greenPin, LOW);
delay(200);
digitalWrite(redPin, HIGH); // BLUE on
digitalWrite(bluePin, LOW);
delay(200);
So my main question must then be: How can I tell if my LED is a Anode or a Cathode, if I do not have the datasheet, and nor can I see the legs of the LED?
With this setup (wire to 5V), it seems like it works. But with the old setup (wire to GND) I could still get something to light up...
What difference does it do, whether the resistor is on all the wires, or only the common one?
And why is the resistor even necessary?
I have now all the colors working with this wiring:
Blue wire: 5 V
Yellow wire: PWM 8
Red wire: PWM 10
Black wire: PWM 12
So that must mean, that I have an Anode LED. I just think it is weird to have the blue wire connected to +5V?
Connect a 330 or 470 Ohm resistor to +5v
Touch the anode to the resistor and one lead to ground. If it lights up then it's Anode.
If it won't light up, reverse it and if it lights up then it's Cathode.
When a LED lights up the + is Anode and the - is Cathode.
Because with only one resistor :-
the brightness will change depending on the number of LEDs that are lit.
the voltage drop across each colour is different and it prevents some from coming on when others are no irrespective of how the digital output lines are set.
Thanks for your replies, and good links for documentation.
As I read it, we only need to resistor to limit the current.
It seems like, I only use 10mA on each pin. If I use a resistor, doesn't that mean, that the LED will get less current (the output pin will output the same amount of current no matter the resistor?)?
This means that the LED will not light as bright as it does now. So with only 10mA current usages - is a resistor still mandatory?
A quick comment about the Arduino code. I found a function called analogWrite, which writes a PWM signal to the digital lines. Why is it called something with analog?? What am I missing here to understand that name?
What makes you think that?
Did you read that link?
How do you think you are limiting the current to 10mA?
Yes resistors are mandatory unless you use a constant current drive. As you are not yet up to using resistors a constant current drive is way out of your league at the moment.
I tried to measure it with a multimeter.
It varies between 10 - 16 mA, so I don't think I limited the current to 10mA, that is just what I am measuring
I understand what a PWM signal is, but I just don't understand why they called the function analogWrite
Are you measuring it with the resistor in the common line? That is what is limiting the current. That is the resistor you should remove and replace by a short circuit. Then put a resistor in each colour, have you done this?
Because the smoothed version of the signal can be used as an analogue signal.
Okay, so in order to make this correct, I found the old control box that comes with these LEDs.
As you can see from the PCB, the LEDs must be Anode, since they are connected directly to +5V.
But I cannot see what resistor size they used. Maybe you can help explaining the PCB?
Components used:
R1: 390 (orange, white, brown, gold)
R2: 27k (red, violet, orange, gold)
R3,R4,R5: 100k (brown,black,yellow,gold)
Q1,Q3: S8050 D 136
Q2: S8050 D 131
Q4,Q5,Q6; S8550 D 331
So based on this, I would say they use a 100k resistor for each color, but then again; that does sounds a really big resistor? So maybe they are doing something fancy on the PCB??
After reading up on how a transistor works, it seems like they uses the transistors with the 100k resistors to form a switch. This makes since since they need to be able to switch between the different colors.
I guess they then use R1 (390 ohm) as their resistor, and thus they are only using one resistor for all colors.
I tried to add the 100k resistor to my Arduino setup, and just as expected, nothing lights up. When adding the 390 ohm resistor, the LED is still able to light up.
I can see that it does not light up just as bright as without the resistor. Does that mean that I can try to use a resistor with less resistance? If so, when is enough enough?
The blob thing covered with resin on the right angled board is an integrated circuit. That can be doing anything so you can not assume that the current limiting device for the LED is a resistor either on the board or in the LED circuit.
Yes that is what the 100K resistors are they are base resistors for the transistor.
I assume what you mean here is that the LEDs are common anode.
So you have taken the LEDs out of something and want to use it with the arduino, is that correct?
If so, connect the common line to +5, connect each colour to a 220R resistor and the other end of the resistor to a separate digital output. You should then be able to switch any colour or combinations of colour on and off. With digital pins these will be 7 different colours.
If you use PWM pins then you will be able to get almost unlimited colours by writing various values of PWM duty cycle to the pins.
