How to connect A. Mega + 8266 and browse webpage from out of my home?
Hello,
I’m triing Arduino Mega + 8266 webserver using this sketch:
Arduino Mega 2560 + ESP-05(ESP8266)
ESP-05 running firmware:
AT version:0.40.0.0(Aug  8 2015 14:45:58)
SDK version:1.3.0
Ai-Thinker Technology Co.,Ltd.
Build:1.3.0.2 Sep 11 2015 11:48:04
Connection between Mega & ESP-05,
refer "Connect with Arduino Mega 2560 via Level Converter" in:
http://goo.gl/wtG89i
Mega + ESP_05 act as station, join WiFi AP of my phone.
Once server setup, you can visit the webpage in ESP-05
by visit the IP show in Serial Monitor, under the command:
AT+CIFSR
+CIFSR:STAIP,"192.168.43.15"
If always show "Module have no response.",
check your connection, or reset ESP-05 by power OFF and ON.
#define ASCII_0 48
#define ESP8266 Serial3
//WiFi hotspot setting on my phone
String SSID = "Neffos";
String PASSWORD = "password";
int LED = 10;
int RESET_8266 = 8;
boolean FAIL_8266 = false;
String strHTML1 = "<!doctype html>\
<html>\
<head>\
<title>arduino-er</title>\
</head>\
<body>\
<H1>Arduino web server</H1>";
String strHTML2 = "</body>\
</html>";
//String strHTML = "arduino-er.blogspot.com";
#define BUFFER_SIZE 128
char buffer[BUFFER_SIZE];
  pinMode(LED, OUTPUT);
  pinMode(RESET_8266, OUTPUT);
  digitalWrite(RESET_8266, HIGH);
  digitalWrite(LED, LOW);
  delay(300);
  digitalWrite(RESET_8266, LOW);
  digitalWrite(LED, HIGH);
  delay(200);
  delay(300);
  delay(200);
  do{
    ESP8266.begin(115200);
    //Wait Serial Monitor to start
    while(!Serial);
    Serial.println("--- Start ---");
    ESP8266.println("AT+RST");
    if(ESP8266.find("ready"))
      Serial.println("Module is ready");
      ESP8266.println("AT+GMR");
      clearESP8266SerialBuffer();
      ESP8266.println("AT+CWMODE=1");
      delay(2000);
      //Quit existing AP, for demo
      Serial.println("Quit AP");
      ESP8266.println("AT+CWQAP");
      if(cwJoinAP())
        Serial.println("CWJAP Success");
        FAIL_8266 = false;
        delay(3000);
        //Get and display my IP
        sendESP8266Cmdln("AT+CIFSR", 1000);
        //Set multi connections
        sendESP8266Cmdln("AT+CIPMUX=1", 1000);
        //Setup web server on port 80
        sendESP8266Cmdln("AT+CIPSERVER=1,80",1000);
        Serial.println("Server setup finish");
      }else{
        Serial.println("CWJAP Fail");
        FAIL_8266 = true;
    }else{
      Serial.println("Module have no response.");
  delay(300);
  delay(200);
      FAIL_8266 = true;
  }while(FAIL_8266);
  //set timeout duration ESP8266.readBytesUntil
  ESP8266.setTimeout(1000);
void loop(){
  int connectionId;
  if(ESP8266.readBytesUntil('\n', buffer, BUFFER_SIZE)>0)
    Serial.println("Something received");
    Serial.println(buffer);
    if(strncmp(buffer, "+IPD,", 5)==0){
      Serial.println("+IPD, found");
      sscanf(buffer+5, "%d", &connectionId);
      Serial.println("connectionId: " + String(connectionId));
      sendHTTPResponse(connectionId, strHTML1);
      sendHTTPResponse(connectionId, "<hr/>-END-
      sendHTTPResponse(connectionId, strHTML2);
      //Close TCP/UDP
      String cmdCIPCLOSE = "AT+CIPCLOSE=";
      cmdCIPCLOSE += connectionId;
      sendESP8266Cmdln(cmdCIPCLOSE, 1000);
void sendHTTPResponse(int id, String response)
  String cmd = "AT+CIPSEND=";
  cmd += id;
  cmd += ",";
  cmd += response.length();
  Serial.println("--- AT+CIPSEND ---");
  sendESP8266Cmdln(cmd, 1000);
  Serial.println("--- data ---");
  sendESP8266Data(response, 1000);
boolean waitOKfromESP8266(int timeout)
  do{
    Serial.println("wait OK...");
    if(ESP8266.find("OK"))
      return true;
  }while((timeout--)>0);
  return false;
boolean cwJoinAP()
  String cmd="AT+CWJAP=\"" + SSID + "\",\"" + PASSWORD + "\"";
  ESP8266.println(cmd);
  return waitOKfromESP8266(10);
//Send command to ESP8266, assume OK, no error check
//wait some time and display respond
void sendESP8266Cmdln(String cmd, int waitTime)
  delay(waitTime);
//Basically same as sendESP8266Cmdln()
//But call ESP8266.print() instead of call ESP8266.println()
void sendESP8266Data(String data, int waitTime)
  //ESP8266.print(data);
  delay(waitTime);
//Clear and display Serial Buffer for ESP8266
void clearESP8266SerialBuffer()
  Serial.println("= clearESP8266SerialBuffer() =");
  while (ESP8266.available() > 0) {
    char a = ESP8266.read();
    Serial.write(a);
  Serial.println("==============================");
All work fine, and i can connect HotSpot of my phone, then from browser I can see webpage at ip address.
Now the question: if I connect this webserver at my home wi-fi internet router, then is possible see web page from internet? How to?
Best regards
you need to set up your router to port forward requests from the internet to the machine running the web server - for a web server it would usualy be TCP port 80
Thank you, since I do not have any experience about, could you suggest me a tutorial to learn how to do this?
how you set up port forwarding depends on the router you need to login to it as administrator and the work thru the the menus do you have an instruction manual for it?
my doubt is knowing exactly what I have to do step by step, so as to understand the philosophy about
router is tp-link TD-W8961N
manual is https://www.google.it/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiy55GfqZzZAhUBbhQKHfjSC4YQFggoMAA&url=https%3A%2F%2Fwww.vanilla.co.za%2Fpdf%2FTD-W8961N.pdf&usg=AOvVaw013cECUGafHZnigLQOLpdM
have a look at section 4.4.3.2 Virtual Server the application will be HTTP_Server protocol ALL start port and end port 80 and the IP address of your server
this online guide may help Opening Ports on the TP-Link TD-W8961N
