how to connect amp to speaker to uno
Hey guys another noob here, I'm going to get this amp to use with an 8 ohm speaker https://www.sparkfun.com/products/11044
But I'm having trouble visualizing how the speaker and the amp and the uno hook up
Thanks for the help
Read the Quickstart Guide. Seems to cover the connections pretty well.
Thanks for the advice! but i still have a question, what line level audio? is that on the arudino?
stephencampbell:
No analog line level outputs on an arduino. There are digital outputs and analog input pins.
so would I put those in place of the line level outputs? the quickstart guide is confusing me
https://www.sparkfun.com/tutorials/392#gain_resistors
Two resistors in series, 10K each.
Arduino to 10K, then 10K to Gnd. Junction to the amplifier.
Signal is divided between the 2 resistors.
Better: 10K potentiometer.
Arduino output on one outer leg, other outer leg to Gnd.
Middle leg to amp. Can lower 5V output as needed.
Awesome thanks for the advice! im getting a 10k potentiometer. Would i just not use the In + - header on the amp?
Yes, middle leg to +, gnd leg to -.
Thanks!
I just hooked one up for an alarm clock. I just put the 10K pot right on the board like the quickstart says. It works fine.
