dkim360:
Ah okay thanks. I did try connecting the TX pin of the altimeter to the RX pin of the Arduino. It said uploading, but never did. Any ideas?
When you set up the altimeter parameters with the PC program you had to tell it when to begin sending telemetery. What did you set it to? And have you activated what ever you set it to? If that has not taken place your altimeter will never begin to transmit and when that setting becomes true, the altimeter will just begin to dump data. Or at least that is what the manual indicates.
You are powering the altimeter?
Paul
cattledog:
What pin is connected to the TXpin of the altimeter?
Please post the code you are using to read the sensor.
Did you enable Telemetry as discussed on page 27 of the manual.
So I connected the TX pin of the altimeter to the RX (d. pin 0) of the arduino Mega. I did post the code before but here it is again. And yes I did enable telemetry.
int foo; // Useless declaration to molify the IDE
#define isdigit(X) (((X) >= '0') && ((X) <= '9'))
int AGL=read_int();
// Do math
int read_int()
static byte c;
static int i;
i = 0;
while (1)
while (!Serial.available())
c = Serial.read();
if (c == '\r')
return i;
if (isdigit(c))
i = i * 10 + c - '0';
Serial.print("\r\nERROR: \"");
Serial.print(c);
Serial.println("\" is not a digit\r\n");
return -1;
Paul_KD7HB:
Paul
So I set it up by connecting the altimeter to my PC, opening the software and setting it to "OnPad" per the manual instructions and applied the new settings, and yes I am powering the altimeter.
dkim360:
And have you done this: "Connect a suitable ON/OFF switch to the altimeter’s power
switch terminals.".
Paul
dkim360:
Ah I see. So should I connect TX pin to the additional ports?
So I used TX 1and RX 1 and used the code. I did finally get something out of the serial monitor. But its just spitting out 56 and 57 not the ASCII format.
