How to connect Ardunio ESP8266 wifi server with asp.net application
I want to develop asp.net application then can send data to ESP8266 which will be act as to show that message. What I have done, I have fully function Esp8266 board which show Ip address it is connect and any message which can be send from this web page which is coded with it.
here is the code
#include <ESP8266WiFi.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#define PRINT_CALLBACK  0
#define DEBUG 0
#define LED_HEARTBEAT 0
#if DEBUG
#define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
#define PRINTS(s)   { Serial.print(F(s)); }
#else
#define PRINT(s, v)
#define PRINTS(s)
#endif
#if LED_HEARTBEAT
#define HB_LED  D2
#define HB_LED_TIME 500 // in milliseconds
#endif
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 4
#define CLK_PIN   14 // or SCK
#define DATA_PIN  13 // or MOSI
#define CS_PIN    15 // or SS
const char* ssid = "Honor 7C";
const char* password = "fawaz@123";
WiFiServer server(80);
const uint8_t MESG_SIZE = 255;
const uint8_t CHAR_SPACING = 1;
const uint8_t SCROLL_DELAY = 200;
char curMessage[MESG_SIZE];
char newMessage[MESG_SIZE];
bool newMessageAvailable = false;
const char WebResponse[] = "HTTP/1.1 200 OK\nContent-Type: text/html\n\n";
const char WebPage[] =
"<!DOCTYPE html>" \
"<html>" \
"<head>" \
"<title>MajicDesigns Test Page</title>" \
"<script>" \
"strLine = \"\";" \
"function SendText()" \
"  nocache = \"/&nocache=\" + Math.random() * 1000000;" \
"  var request = new XMLHttpRequest();" \
"  strLine = \"&Message=\" + document.getElementById(\"txt_form\").Message.value;" \
"  request.open(\"GET\", strLine + nocache, true);" \
"  request.send(null);" \
"</script>" \
"</head>" \
"<body>" \
"<p><b>MD_MAX72xx set message</b></p>" \
"<form id=\"txt_form\" name=\"frmText\">" \
"<label>Msg:<input type=\"text\" name=\"Message\" maxlength=\"255\"></label>
"</form>" \
"<input type=\"submit\" value=\"Send Text\" onclick=\"SendText()\">" \
"</body>" \
"</html>";
const char *err2Str(wl_status_t code)
  switch (code)
  case WL_IDLE_STATUS:    return("IDLE");           break;
  case WL_NO_SSID_AVAIL:  return("NO_SSID_AVAIL");  break;
  case WL_CONNECTED:      return("CONNECTED");      break;
  case WL_CONNECT_FAILED: return("CONNECT_FAILED"); break;
  case WL_DISCONNECTED:   return("CONNECT_FAILED"); break;
  default: return("??");
uint8_t htoi(char c)
  c = toupper(c);
  if ((c >= '0') && (c <= '9')) return(c - '0');
  if ((c >= 'A') && (c <= 'F')) return(c - 'A' + 0xa);
  return(0);
boolean getText(char *szMesg, char *psz, uint8_t len)
  boolean isValid = false;   char *pStart, *pEnd;
  pStart = strstr(szMesg, "/&Message=");
  if (pStart != NULL)
    pStart += 10;
    pEnd = strstr(pStart, "/&");
    if (pEnd != NULL)
      while (pStart != pEnd)
        if ((*pStart == '%') && isdigit(*(pStart+1)))
          // replace %xx hex code with the ASCII character
          char c = 0;
          pStart++;
          c += (htoi(*pStart++) << 4);
          c += htoi(*pStart++);
          *psz++ = c;
          *psz++ = *pStart++;
      *psz = '\0'; // terminate the string
      isValid = true;
  return(isValid);
void handleWiFi(void)
  static enum { S_IDLE, S_WAIT_CONN, S_READ, S_EXTRACT, S_RESPONSE, S_DISCONN } state = S_IDLE;
  static char szBuf[1024];
  static uint16_t idxBuf = 0;
  static WiFiClient client;
  static uint32_t timeStart;
  switch (state)
  case S_IDLE:   // initialize
    PRINTS("\nS_IDLE");
    idxBuf = 0;
    state = S_WAIT_CONN;
  case S_WAIT_CONN:
      client = server.available();
      if (!client) break;
      if (!client.connected()) break;
#if DEBUG
      char szTxt[20];
      sprintf(szTxt, "%03d:%03d:%03d:%03d", client.remoteIP()[0], client.remoteIP()[1], client.remoteIP()[2], client.remoteIP()[3]);
      PRINT("\nNew client @ ", szTxt);
#endif
      timeStart = millis();
      state = S_READ;
  case S_READ:
    PRINTS("\nS_READ");
    while (client.available())
      char c = client.read();
      if ((c == '\r') || (c == '\n'))
        szBuf[idxBuf] = '\0';
        client.flush();
        PRINT("\nRecv: ", szBuf);
        state = S_EXTRACT;
        szBuf[idxBuf++] = (char)c;
    if (millis() - timeStart > 1000)
      PRINTS("\nWait timeout");
      state = S_DISCONN;
  case S_EXTRACT: // extract data
    PRINTS("\nS_EXTRACT");
        newMessageAvailable = getText(szBuf, newMessage, MESG_SIZE);
    PRINT("\nNew Msg: ", newMessage);
    state = S_RESPONSE;
  case S_RESPONSE:
    PRINTS("\nS_RESPONSE");
    client.print(WebResponse);
    client.print(WebPage);
    state = S_DISCONN;
  case S_DISCONN: // disconnect client
    PRINTS("\nS_DISCONN");
    client.flush();
    client.stop();
    state = S_IDLE;
  default:  state = S_IDLE;
void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col)
#if PRINT_CALLBACK
  Serial.print("\n cb ");
  Serial.print(dev);
  Serial.print(' ');
  Serial.print(t);
  Serial.print(' ');
  Serial.println(col);
#endif
uint8_t scrollDataSource(uint8_t dev, MD_MAX72XX::transformType_t t)
  static enum { S_IDLE, S_NEXT_CHAR, S_SHOW_CHAR, S_SHOW_SPACE } state = S_IDLE;
  static char *p;
  static uint16_t curLen, showLen;
  static uint8_t  cBuf[8];
  uint8_t colData = 0;
  switch (state)
  case S_IDLE:     PRINTS("\nS_IDLE");
    p = curMessage;
    if (newMessageAvailable)     {
      strcpy(curMessage, newMessage); // copy it in
    state = S_NEXT_CHAR;
  case S_NEXT_CHAR:
    PRINTS("\nS_NEXT_CHAR");
    if (*p == '\0')
      state = S_IDLE;
      showLen = mx.getChar(*p++, sizeof(cBuf) / sizeof(cBuf[0]), cBuf);
      curLen = 0;
      state = S_SHOW_CHAR;
  case S_SHOW_CHAR: // display the next part of the character
    PRINTS("\nS_SHOW_CHAR");
    colData = cBuf[curLen++];
    if (curLen < showLen)
  showLen = (*p != '\0' ? CHAR_SPACING : (MAX_DEVICES*COL_SIZE)/2);
    curLen = 0;
    state = S_SHOW_SPACE;
  case S_SHOW_SPACE:
    PRINT("\nS_ICSPACE: ", curLen);
    PRINT("/", showLen);
    curLen++;
    if (curLen == showLen)
  default:
    state = S_IDLE;
  return(colData);
void scrollText(void)
  static uint32_t  prevTime = 0;
  if (millis() - prevTime >= SCROLL_DELAY)
    mx.transform(MD_MAX72XX::TSL);
    prevTime = millis();    }
#if DEBUG
  PRINTS("\n[MD_MAX72XX WiFi Message Display]\nType a message for the scrolling display from your internet browser");
#endif
#if LED_HEARTBEAT
  pinMode(HB_LED, OUTPUT);
  digitalWrite(HB_LED, LOW);
#endif
  mx.begin();
  mx.setShiftDataInCallback(scrollDataSource);
  mx.setShiftDataOutCallback(scrollDataSink);
  curMessage[0] = newMessage[0] = '\0';
  PRINT("\nConnecting to ", ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    PRINT("\n", err2Str(WiFi.status()));
  PRINTS("\nWiFi connected");
  // Start the server
  server.begin();
  PRINTS("\nServer started");
  // Set up first message as the IP address
  sprintf(curMessage, "%03d:%03d:%03d:%03d", WiFi.localIP()[0], WiFi.localIP()[1], WiFi.localIP()[2], WiFi.localIP()[3]);
  PRINT("\nAssigned IP ", curMessage);
  handleWiFi();
  scrollText();
<%@ Page  Language="C#" AutoEventWireup="true" CodeBehind="QueueForm.aspx.cs" Inherits="WebApplication1.QueueForm" %>
<!DOCTYPE html>
<html>
<head>
    <script>
        strLine = "";
        function SendText() {
            nocache = "/&nocache=" + Math.random() * 1000000;
            strLine ="http://192.168.43.133/"+"&Message=" + document.getElementById("txt_form").Message.value;
            request.open("GET", strLine + nocache, true); request.send(null);
    </script>
</head>
<body>
    <form id="txt_form" name="frmText">
        <label>
            Msg:
    <input type="text" name="Message" maxlength="255">
        </label>
    </form>
    <input type="submit" value="Send Text" onclick="SendText()"></body></html>
I'm not sure if I understand.
You have a ESP based web server and you have an (IIS?) web server running some ASP.net code?
Web servers can't talk to each other; you need a client (usually a browser) to talk to a server.
